BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Advice on Eco Pro
      03-14-2014, 12:51 PM   #1
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
Advice on Eco Pro
Taking a road trip later today and thought I'd try and make my destination on one tank (426 mi).
Never having used Eco Pro on a trip, do you set it and let cruise control go at it, or run it manually and adjust your throttle/driving per the display instructions?
F30 Sapphire Black M-Sport 335i 6MT
      03-14-2014, 01:39 PM   #2
34.50
34.50's Avatar
Drives: 2013 335i xDrive Sport Line
You can do either. If you're driving primarily highways, I would set the cruise on eco pro. I have seen up to 38 mpg on the onboard trip computer, which is not bad for a 335i.
Edit: d'oh, just noticed you have 6MT. Sorry I have the 8SAT - it doesn't really give you many tips - just set it and go. I assume if you have MT, it tells you what gear you should shift to?
2013 BMW 335i xDrive Sport Line
      03-14-2014, 02:01 PM   #3
nicknaz
nicknaz's Avatar
3187
Drives: C6Z
I use cruise control.
Another good option to look into for max mpg is reduce cruising speed to speed limit
      03-14-2014, 02:10 PM   #4
snowghost
snowghost's Avatar
Yes it does say what gear you should be in and whether or not to back of the accelerator--probably the same for AT as well in that regard.
I will set cruise control on speed limit, forget it, and enjoy the radio When I get back I'll report the mileage.
      03-14-2014, 02:11 PM   #5
crono06
crono06's Avatar
Drives: 2013 335i and 2018 X3
I remember when I did a trip from Toronto to Windsor (across the river from Detroit for you folks who don't know), and I averaged 7.5L/100KM on both the tank there and the tank back. I'd say that is very impressive for a vehicle with 300hp.
      03-14-2014, 04:02 PM   #6
JJS
New Zealand
123
Drives: BMW F31 335i 6MT M-Sport
It'll tell you to change to 6th by the time you're doing 30mph. That's barely off idle. The only time I used ECO PRO in earnest was when I had less than 50km of range left and the next petrol station was further away.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional |
      03-14-2014, 05:46 PM   #7
X2 Monstah
X2 Monstah's Avatar
Drives: 2018 X2 XDrive 28i M Sport
Cruise Control will normally give better gas mileage, but in EcoPro if you let of the gas and coast down hills, the revs drop to idle speed. That doesn't happen if you have the Cruise on. I assume dropping the rpm to idle would save quite a bit, depending on how "hilly" your trip is. Not sure if it is the same with a manual tranny though. Either way, I think you can easily make the trip on a single tank.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather
Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!)
      03-14-2014, 06:19 PM   #8
Falafel Combo
Drives: X5 xDrive50i
It's not worth it man. It just isn't. The pain and the mental anguish of driving 426 miles in Eco pro mode will present itself in later life in the form of late stage dementia or mad cow Alzheimer's or something.
      03-14-2014, 06:33 PM   #9
justinnum1
Drives: 2018 330i Msport 6mt
I love eco pro. Keeps me from getting in trouble.
F30 330i Alpine white/Coral red Msport 6MT
      03-14-2014, 07:20 PM   #10
Frogman
Drives: 2012 F30 328i
I've found (at least for me) that Eco pro doesn't really buy me anything on the open road at steady highway speeds.
I only see the Eco Pro "benefit miles" increase in stop and go traffic where it deadens the throttle and changes the shift points on acceleration to improve gas mileage.
On the open road the throttle is basically fixed along with the gear, so I can't see much benefit of Eco Pro mode in this kind of driving. There may be some savings by de-tuning the A/C and other electrical draw, but I've never seen a measurable benefit from it.
As far as cruise control goes, I can get better MPG out of the car with CC off in moderately hilly areas by dropping my speed slightly on up hills and gaining speed on down hills where the cruise control doesn't/can't do that. On steeper down hills, the CC even applies the brakes to reduce speed which is even less efficient! I use cruise control to reduce fatigue, not save gas.
      03-14-2014, 07:25 PM   #11
ft1330
Drives: 2014 335i
If you're afraid to get in trouble you should not own this car man.
      03-14-2014, 07:31 PM   #12
listerone
Drives: 2018 BMW 540d
First of all...I've driven through Windsor.Doing so is the shortest route from Detroit to Buffalo.Windsor sure beats Detroit,that's for sure!
Next winter,when I've gotten a few more miles on my "d" I'm gonna drive it to Florida,which I also did with my Bluetec.On the southern stretch of I-95 (NC to FL) it's basically sea level..flat...and straight.On that stretch my Bluetec got 39mpg vs the EPA rating of 33mpg highway.I'll set my "d' to eco-pro and set the cruise control at 69mph and see if I can beat the EPA's 45mpg highway.
Current : 2018 540d
Formerly: 2014 328d
Formerly: 2011 MB E350 Bluetec
Formerly: 2009 335d
      03-14-2014, 07:51 PM   #13
claykin
Drives: various BMW
EcoPro is great for cruising or lazy day driving. I use it from time to time, but when I get into a situation where I need some power, I often cringe and need to change the mode selector so I don't feel like I'm in "limp mode".
2023 840GC | 2021 740i | 2019 X3
      03-14-2014, 11:22 PM   #14
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
I noticed Eco-Pro works well with Active Cruise Control because it accelerates more smoothly than Comfort mode.
      04-29-2014, 03:28 PM   #15
Ian138
Drives: F30
Totally agree
      04-29-2014, 03:44 PM   #16
ft1330
Drives: 2014 335i
These days I've been testing out the Eco Pro mode and yes I do get 38 mpg in a 335i (at least according to the computer). But I have to drive the speed limit and NO ONE else does. And driving like a grandma, can be really painful sometimes.
      04-29-2014, 03:50 PM   #17
paulbrenneman
paulbrenneman's Avatar
Drives: Mineral Grey 335i M-Sport ZF
Why? Drove down to San Diego the other day cruising at 80-90mph in sport with transmission in DS. Mpg was fluctuating between 35 and 45 the whole way... Unless we were accelerating. I don't see it being worth the pain of Eco pro when you can get MPG like that in attack mode
      04-29-2014, 04:08 PM   #18
adge7
adge7's Avatar
Australia
25
Drives: F30 330i MSport
I agree completely. I find on the open road, the apparent benefits of Eco pro are negated by the consistent high speed travel and so I tend to use it in start stop traffic.
My best on the highway, (cruise control in comfort mode) is 5.7L/100km (2012 328i).
      04-29-2014, 05:52 PM   #19
S4NoMore
S4NoMore's Avatar
2016 BMW 340i  [0.00]
2015 BMW X3 28d  [0.00]
1991 BMW 318i  [8.66]
The additional benefit of Eco Pro that I bet most people aren't aware of is that the thermostat adjusts to a higher temperature.
In section 4 of the N20 technical training manual (here) there is an explanation of a 29C / 52F degree difference in the thermostat setting between Sport and Eco mode (they refer to Sport as "high operation"). The same verbiage is in the N55 technical document.
"Internal engine friction is reduced at higher temperature" and likewise volumetric efficiency (power) is improved with a lower cylinder head temperature for Sport mode.
I haven't compared because I always cruise in Eco Pro, but the change in temperature is observable on the oil temp gauge. BMW engineered this and I believe a) no harm is done and b) every bit helps so why not when it's a simple button press.
      04-29-2014, 06:18 PM   #20
300hp
Drives: X5 & 335xi
I did 23mpg in my X5 35i driving 65-80 mph on +500 mike road trips. 26 mpg in a 335i is very achievable w/out eco pro.
My 2014 f 30 is at 23mpg in mixed driving
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs
Deep Sea Blue Metallic 2013 X5 35d Sport
Prem, Convenience, Cold and Premium Sound packages
      04-29-2014, 06:44 PM   #21
alienranch
Drives: 2012 BMW 335i
He's right. Trust me on this. I like cheese.
