04-23-2020, 05:48 PM | #23 |
Rep 78
Mine's at that same temp as well and my drive to work is a 15 min 8 mile drive but I never seem to be able to hit it even during this summer time.. That's what got me wondering. When am I able to really drive it and have fun outside of cruising around for no reason during this lock down
04-23-2020, 05:51 PM | #24 |
Rep 78
I'm a month into owning a BMW and this is my first turbos'd engine. How do I know at what RPMs do turbos start to kick in for the N55 engine? Can't exactly tell stock with MPE exhaust
04-23-2020, 05:55 PM | #25 | |
Rep 78
04-23-2020, 05:58 PM | #26 | |
Rep 78
04-23-2020, 06:09 PM | #27 | |
Rep 3,748
Under 3k rpm is fine....try keeping an eye how the car shift during normal driving in comfort mode.. usually 1st gear to 2nd gear happens at 2200 to 2500 rpm then the same on to 3rd gear and probably 2k going to 4th and so on. That the shift behavior of my car anyway. So what I do is just follow it when the car is cold (that's because I go sport mode right away with paddle shift) |
04-23-2020, 06:19 PM | #28 |
Rep 1,597
If the N55 is like the B58, then in Sport I think its around 2500RPM and in Sport+ its 2000RPM or just drive in eco mode until the temperature reaches over 200.
04-23-2020, 06:26 PM | #29 | |
Rep 3,748
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered |
04-23-2020, 06:28 PM | #30 | |
Rep 2,499
The newer G body cars have a sports display that will display a bunch of temperatures on the iDrive screen but that isn't available on our cars. |
BoyOhBoyyy17.00 |
04-23-2020, 06:29 PM | #31 |
Rep 78
Smart! Ok let me do that for now. I didn't know Sport and Sport+ were different in terms of the rpm shifting. I always thought one had traction control and one didn't so I never used Sport+. Super interesting!
04-23-2020, 06:31 PM | #32 |
Rep 78
04-23-2020, 06:37 PM | #33 |
Rep 1,597
I am sorry I mean in Sport/+ the car runs in higher cruise-RPMS to keep the turbos near-spooled. Just drive in eco or comfort and don't get on it until temperatures are over 200.
04-25-2020, 09:59 AM | #34 |
Rep 125
Drives: 2024 BMW 228i Gran Coupe
I keep it below 3,000 until I start to see the needle move. Then, below 4,000 until full temperature. I had an E46 M3 (2003) new and always liked the series of lights they used, to show progressive warming. If memory serves, you were coached to stay below 4,000 until the first light came on. Unless, of course, you lived in very cold climate and then the advice was to stay below even 4,000 for the first several minutes (remember, it isn't just the crankcase oil but transmission and differential that needs to get some heat in it). When I was with the Olive Garden team in ALMS, we had a very specific warm up process for our 550 Maranello, so there is something to all this. Of course, that was a $1M dollar engine that we did not want to break..........
04-25-2020, 10:24 AM | #35 |
Rep 231
Once the oil temp lifts off the 160 mark is when I'll start to not worry about it (still not taking it to redline yet). My RS4 would limit RPM's until the same temp and I've been using the same oil in the BMW.
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
04-28-2020, 10:47 AM | #36 |
Tom2TerrE
Rep 108
I start my engine, i let heat up for few minutes (3-5)
Then i drive 200 ish F is my target If i pull, i let my engine heat down before stoping it B58 i like it and i wanna keep it for a long time😍 |
04-29-2020, 12:08 PM | #37 |
Rep 276
My routine:
•start car •activate sport mode •shift in gear •shifter left •stay below 3xx rpms until gauge has lifted Not sure if anyone else has noticed this, but my gauge rarely goes about 205. N26 SULEV btw |
04-29-2020, 12:36 PM | #38 |
Rep 117
shouldn't warm up time be different based on the model, I may be incorrect here but I thought the 340i with fog light only had 1 radiator and the m sport models with no fog lights had smaller radiators instead of the fog lights. is that right? I sometimes notice the engine getting cold if I'm cruising slow in the winter, needle just goes back down a bit unless I push it harder. I don't have fog lights on my 340.
04-29-2020, 02:45 PM | #39 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
Normal operating temp for the B58 engine is 226 F. My steering wheel shows temperature for Oil and Coolant. Once it reaches 226 that's when i start driving aggressively if need be.
04-29-2020, 10:33 PM | #40 | |
Rep 4,724
That usually deletes the fog lights, and comes with m performance brakes on top of the oil cooler.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
05-18-2020, 07:35 AM | #42 | |
LawtonLaw
Rep 3
MY2013 F30 N26 328xi - Glacier Silver; Shadow-Trim; Easy-Access; Magnaflow axle-back; K&N drop-in air filter; M3 gloss-black double-slat kidney grilles;
*Upcoming Mods: Injen CAI; Wheel spacers (12mm); Bilstien Coilovers; 35% Ceramic Window Tint. |
jimbobiggens839.00 |
05-18-2020, 07:50 AM | #43 |
Rep 1,905
With internal combustion engine it is known/established that the vast proportion of engine wear occurs during initial startup- unavoidable, nature of the design.
Start car and drive away moderately for a few minutes then you're good to go as far as hitting the higher rev levels. With modern multi viscosity oils the oil is thinnest and therefore flows best to lube bearings when car needs it most, when motor is cool/cold. |
johnung4528.00 |
