07-25-2019, 01:39 PM | #309 | ||
Rep 10,473
They state they expect 2-3 months. Then again, when have we heard that before? Bilstein USA has no info on USA product. I told them that September looks like a go in UK and they stated that products are not released Worldwide at the same time. Said additional testing is often required for USA. Quite frankly, I suspect they are clueless and assuming. As for kamracing.co.uk I have verified with several BMW owners in UK that they are very legit. Some have been to their shop. "We separate the products by car so do not have a joint listing. For some reason it was not showing on the website but you can now get to the correct product listing here https://www.kamracing.co.uk/car-tuni...dc-models.html We are waiting for production to finish. This is unfortunately about 2-3 months away but you can still buy now and get it at the cheaper price. I'm tempted to order the ride control version for my 328i! Kindest regards Kev" |
07-26-2019, 03:23 AM | #310 | |
Rep 132
Totally agree with you if you are referring to the B4 and B6 Damptronic units though. |
07-26-2019, 03:28 AM | #311 | |
Rep 132
07-26-2019, 10:34 AM | #312 | ||
Rep 10,473
07-26-2019, 10:40 AM | #313 |
Rep 132
You can see for yourself here:
https://www.fahrwerke-stossdaempfer....ront-rear.html more expensive than Kamracing.co.uk |
07-26-2019, 02:04 PM | #314 | |
Rep 3,540
Also, the F8x B6/B16 monotube (says in TUV docs again) Damptronic products' front strut PNs start with 31- and the rears start with 26-. They also offer a twin-tube B4 for the F8x that starts with 23- for the front and 20- for the rear.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 07-26-2019 at 03:53 PM.. |
IK6SPEED4490.00 Matthewricha43.00 |
07-27-2019, 04:16 PM | #315 | |
Rep 132
So one might assume you would only buy the B16 kit over the B6 dampers if you want height adjustability and matching springs. |
07-27-2019, 11:25 PM | #316 |
Rep 3,540
The TUV docs also tell you the spring PNs. One thing I noticed looking through them is that B14, B16 PSS10 (normal/non-comfort), and B16 Ride Control all use the same springs.
The B16 Damptronic uses the same rear springs as the above, but has a different front spring. It's got a stronger wire (14mm vs 12mm), is shorter (215mm vs 220mm), has a larger diameter (154mm vs 121-95mm), and has fewer coils (5.5 vs 6.7). This leads me to believe it's more of a standard linear spring (even thought it says progressive in TUV), with a rate higher than F8x ZCP. I base that off of the comparative dimensions from Eibach's TUV docs.
Matthewricha43.00 |
07-28-2019, 06:26 AM | #317 |
Rep 141
I figured I would give everyone an update on my B6 Damptronic's install as I've put about 1200 miles on them so far. As previously mentioned, the spring perch on the B6's is about half an inch higher causing the front of my car to be raised up.
Thanks to FaRKle! having the Eibach F3x Pro-Kit Springs Documentation in his signature, I went out and bought the E10-20-031-03-22 kit which has the 11-20-031-01-VA front springs paired with the 11-20-031-03-HA rear springs. Compared to the 4-22 kit Tirerack recommends for my car, this kit comes with 10mm shorter front springs which has helped dropped the front by about 1/4" compared to the Dinan springs, overall the drop of the front springs is about 1.24" compared to the stock springs. The rear springs additionally have raised the back of my car by about 3/8", which is what I expected to happen as they only drop the car by 0.6" vs the 1" the Dinan's did. I will be watching for any settling as the front springs were installed last weekend, and the rear springs were this weekend. Overall I have to say the ride quality is phenomenal, even with the stiffer Dinan springs and M3 Bumpstops. There will probably be a small difference now that I have swapped to Eibach's, but I don't expect it to be much of one. I have a crazy amount of road construction to drive through and the ride has been extremely complaint.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
Kefka32.50 |
07-28-2019, 10:13 AM | #318 | |
Rep 129
Have you considered to keep "mixed" springs? Front eibachs with rear dinan? I made this with my e89 35i msport. I started using HR springs , lowered very nice but for daily driving was a nightmare due streets of my city , then I ended up installing front Eibach only (HR for the rear side).. Front rised up , but still looks good and friendly daily driving.. |
07-28-2019, 10:45 AM | #319 | |
Rep 132
On the B16 kit, I wonder if it'll look a bit like the VAG one (49-255874) Last edited by Matthewricha; 07-28-2019 at 10:59 AM.. |
07-28-2019, 11:47 AM | #320 |
Rep 141
Kefka the second reason I purchased new springs was to see about fixing another issue I had. My passenger side rear suspension was about half an inch lower than my drivers side. Unsure of the cause and wanting to fix the front drop issue at the same time I bought a new set of springs. As of right now I can say with a good amount of certainty that the Dinan spring was the issue after 70k miles.
Matthewricha as far as I know I'm riding with Dinan Shockware still on the car. What I can say is the OEM suspension struggled when I put on the 245/45r18 winter tires 4 years ago. It was unable to control the extra sidewall bounce the tires added to the equation. Dinan's Shockware helped significantly when I finally added it, however I was already at about 50k miles at that time. The bounce returned last year shortly after I put on the MP4S's, I just rode it out hoping for Bilstein to finally release their dampers. With the B6's installed the bounce has been eliminated, all while absorbing road imperfections. Sport mode is slightly firmer, but still not harsh. It's really surprising just how well these dampers absorb everything without feeling harsh. This is the finished product.
Kefka32.50 Matthewricha43.00 |
08-14-2019, 12:47 AM | #321 |
Rep 3
Interesting note is that ECS is showing the part number now with an ETA of Sept 9th.
https://www.ecstuning.com/b-bilstein...49-207323~bil/ |
08-15-2019, 08:39 AM | #322 |
Rep 132
B16 PDF
That is for the Ride Control kit: 49-207323, not the B16 PnP kit: 49-255935
incidentally this B16 kit (49-255935) is listed on several European sites now, so must be coming soon as discussed earlier. https://www.autodoc.co.uk/bilstein/9...%20(49-255935) ... and here is the PDF containing fitting instructions, diagrams and spring rates etc, which states "twin pipe" shocks: https://media.carparts-cat.com/pdf/E...M4-Y751A00.pdf Happy reading |
08-15-2019, 10:03 AM | #323 |
Car Hypochondriac
335
Rep 903
B6 damptronic kits appear to be on sale at x-ph:
https://x-ph.com/bilstein-b6-perform...bmw-f-chassis/ |
08-15-2019, 11:08 AM | #324 |
Rep 3,540
You had me excited there for a minute with "spring rates." Unfortunately they're not in the TUV document. That said, if you know how many coils are bound at static ride height you might be able to calculate it/get very close since the spring dimensions are there.
08-15-2019, 03:41 PM | #325 |
Car Hypochondriac
335
Rep 903
thisismikeyb
How has the ride been in comfort mode relative to stock edc? At first I was going to go to put my M3 springs on my stock edc and then upgrade the dampers later if needed, but with that x-hp sale... I'm really tempted to just do both at the same time. Edit: I just realized the comparison will most likely be moot for me, since you are on shockware.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 Last edited by Eschmacher; 08-15-2019 at 03:57 PM.. |
08-15-2019, 11:14 PM | #326 | |
Rep 10
Im having the same issue than you, driver side is higher than the the other side, you car sits right after how many days ? |
08-16-2019, 04:41 AM | #327 | |
Rep 141
08-16-2019, 05:47 AM | #328 | |
Rep 132
I believe these are listed a progressive springs same as the VW Golf MK7 B16 dampronic kit, which would mean any spring rate wouldn't be a constant anyway(?) |
08-16-2019, 06:58 AM | #329 | |
Rep 141
In the long run I ended up swapping to a different set of springs that did lower the front of the car a bit and then raised the back of the car some to mostly level it out. At this point I'm probably measuring the change in the suspension with regards to how full my gas tank is.
08-16-2019, 11:05 AM | #330 | |
Rep 3,540
For example, Bilstein front spring E4-FD1-Y226B00 (front spring on the B14, B16, and B16 ride control) is 399lbs/in if you ask Bilstein for the final rate. Using my method I estimated 378.75lbs/in, 5% off. I also did the same with Bilstein rear spring E4-FD1-Y183B00 (also used on the same coilovers as above), which is stated at 565.6lbs/in. My estimated value was 562.5lbs/in, less than 1% off.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 08-16-2019 at 11:33 AM.. |
Matthewricha43.00 |
