BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      03-21-2020, 01:47 PM   #2971
davide18
Drives: BMW E87
Originally Posted by F20_M135i View Post
Thank you for these useful details; I do not yet have a perfect command of TASKER but the variable should actually be the solution because until now I used:
But the results were random ...
I will resume my TASKER test but not before 3 weeks! because I have bricked my PX6 RK3399 unit, and it's screwed up ... So I switched to the S625 unit.
I can talk here about the possible difference and improvements (I'm staying with Android 9.0 for now)
See you later friends !
haha S625 is the best.... 2 weeks with my unit and 0 problems... PX6 SUCKS!
      03-21-2020, 02:58 PM   #2972
Mjam
Drives: E87, i3, Taycan Cross Turismo
Fixed the stereo issue, where left and right is switched. Easy and permanent fix by switching cables in the AUX connector. Only trouble would be if the Chinese fixes the error programmatically.
Kri1083.50
      03-21-2020, 03:03 PM   #2973
Mjam
Perfect location for the LTE/4G antenna? I tried different locations, comparable to outside reception right behind the Android unit.
      03-21-2020, 03:27 PM   #2974
Mjam
Fixed microphone issue. First I bought a $3 mic from eBay. Better than the built in one, but only because you can have it closer to your face. Then I found this stiff priced $29 mic from Taiwan (company info). Must be quality for that price? Yes, very high build quality, sound is louder and clearer, and the directional function is working also. But even with this mic, there are issues when the car is running at high speed.
I finally had to cut the built in mic to get rid of echos and bad sound. You can do this without opening the chassis and brake the warranty label, just open the side where the mic is located, with a credit card or prying tool, and you can easily reach it from there. I got surprised when I pulled it out, only 3 mm! But it's actually quite good, it's the location that makes it bad. Works better already only by pulling it out of the chassis.
      03-21-2020, 08:14 PM   #2975
b777rky
Drives: f45
Originally Posted by b777rky View Post
i buy for my F45 an android chinese px6 rk3399 unit
this is the link for the unit :
https://a.aliexpress.com/_TJCTp
i install it, it works, but i have the problem with NO SIGNAL message, but this message it appear only when i run : WAZE or GMAPS(gmaps sometimes it works for 30min and after it gives me NO SIGNAL)
also i test with : tiktok(no signal), if i try youtube it works like a charm...
this is the photo with no signal message:
https://we.tl/t-1wvZNUT1F8
this is the photo for android version:
https://we.tl/t-63pk1lEtZr
this is the photo for MCU version:
https://we.tl/t-QAScIqAzdX
photo for factory settings menu
https://we.tl/t-baNnMHPOyk
photo for nbt screen option
https://we.tl/t-h6IqZXtlZi
Please tell me where to start, i buy this unit for the larger screen and navigation with WAZE
i talk with the seller and he provided me a link with the firmware .. if it help someone
http://w.mail.qq.com/cgi-bin/ftnExs_...1390d,0a90c310
i didn`t test it.
please help !!!
Up, it drives me crazy!🙄
      03-22-2020, 03:33 AM   #2976
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
start by checking the wiring of the main unit, then the screen and its GPS cable, and finally, update the firmware sent by the seller
      03-22-2020, 09:10 AM   #2977
pitoncho
Drives: bmw e87
hello, is there any update for the px6 radio?
I want to know if it is posibly to install the avin usa rom, my radio is for aliexpress, and the software is a bit laggy and old. I have the px6 4 gb ram and 32 gb.
Thank you!
      03-22-2020, 09:35 AM   #2978
nyacom
Japan
Drives: E92
No sim problem
Hi there,
I purchased SD625 64GB LTE CCC unit from MEKEDE in Aliexpress.
Since I was received the unit, my unit does not detect any sim cards.
(Initially I thought it is compatibility problem among sim cards, so I tried few sim cards from several countries but still no luck...)
I also checked android logcat via adb but it seems sim status check is once in the boot sequence and it says absent:
11-30 00:00:22.919 5372 5372 I Finsky : [2] SimStateReceiver.a(6): android.intent.action.SIM_STATE_CHANGED : simState = ABSENT
I guess my unit has hardware fatality or baseband firmware problem..
Anyone having same symptom?
      03-22-2020, 10:25 AM   #2979
zorglubxx
zorglubxx's Avatar
Netherlands
Drives: 2010 E91 Touring
Originally Posted by nyacom View Post
Hi there,
Try to insert the SIM card in different ways. It took me a few times to find the right way. Maybe this video helps you:
      03-22-2020, 11:00 AM   #2980
nyacom
Japan
Drives: E92
zorglubxx
Thank you for quick reply.
OMG, it actually works!!! (I insert my sim in 'reverse' way that like showing in the video..)
I thought the workaround is exception for my unit...
(because my unit is in-dash type like E9x CCC/CIC)
but it is same for this type unit too.
Anyway, thanks a lot!
      03-22-2020, 02:52 PM   #2981
b777rky
Drives: f45
Tried today. Not work...
1. I update the android ( it s same version) not am update
2. I remove the gps cable to see if it make again.. Same, it crash video with sygic: https://we.tl/t-3ZXN5yP0Fp?src=dnl
3. I checked the wires... They are connected ok, i think if it was a pb from a wire or connector, the problem was in all APps, also in stand-by mode..
4. I ve search on the web an update for the mcu, but not succes, mine is: 01204bJLY-NBT-HW7-190628(B1290_170325)
5. Now.. Also the camera it gives me no signal after the image keep moving like an old tv, it makes like this only when i take right or left on the wheel, video link: https://we.tl/t-D6sw5XA7sZ
      03-23-2020, 06:16 AM   #2982
F20_M135i
France
101
"NO SIGNAL" iis often linked to cables and rarely to software / firmware...
and your problem only comes when you try to connect either to the GPS or to the vehicle camera?
      03-23-2020, 08:24 AM   #2983
b777rky
Drives: f45
Only when i connect an application that need gps... Like sygic or waze
      03-23-2020, 11:03 AM   #2984
davide18
Drives: BMW E87
Hello, i have one question about a phone charging with the Head unit USB ports.... Anyone use this to charge our phones? the charging power
Is so low and slow, is possible to change or modify it to up the power at 2.1A?
I think adding out power to usb with a AC 5V 2.1A but don't touching the data cables?
Thanks
And sorry for my english.
      03-23-2020, 11:40 AM   #2985
F20_M135i
France
101
By default on the units there is an application called GPS TEST or something similar, try to launch it to see please
      03-23-2020, 02:44 PM   #2986
davide18
Drives: BMW E87
BAD NEWS....
I BRICKED MY SNAPDRAGRON UNIT trying to modify the launcher....
Please can anyone help me?..... im in this state...
HELP PLEASE!!! IS NEW UNIT =(
      03-23-2020, 03:51 PM   #2987
b777rky
Drives: f45
Ok, i will test it, thank you!
      03-23-2020, 04:47 PM   #2988
b777rky
Drives: f45
https://we.tl/t-mDiq1cUnsJ
Video with gps test... But same problem when i run waze or sygic after 5 minutes it gives me "no signal" and only thing i can do to acces the android menu is to turn off the car for 5mins and turn on again.. In this time if i press radio or menu, the car unit it works and it gives me image on the screen, if i press "navi" is no signal untill i turn off&on...
      03-24-2020, 05:09 AM   #2989
F20_M135i
France
101
Hello
it is indeed very curious as a defect, I can not find an explanation here. Try downloading a FIX GPS application from the google Play store and see how your unit reacted (that was the goal of my first message) Maybe you should update your unit, you will find in this thread what to do.
davide18 Very bad news, your unit is in FASTBOOT mode, i.e. it is waiting to receive either a download via computer / or physical manipulation (impossible on our unit) It seems that there is no possibility at this stage (see page before and my warning on this mode).
      03-24-2020, 07:21 AM   #2990
davide18
Drives: BMW E87
Originally Posted by seaman5705 View Post
Up to now, nobody has a solution . But fastboot mode only happens when Magisk updates .
Same here.... But i try testing to search a otg and now i only have NO SIGNAL....
      03-24-2020, 07:23 AM   #2991
davide18
Drives: BMW E87
Hello
lol... i Cry.....
I'm going to buy another unit ... and it's already my 3 unit ... AND THE LAST Do you recommend a seller? thx.
      03-24-2020, 11:04 AM   #2992
marcomdt
Drives: bmw m4
can anyone tell me how to solve the problem with the dashboard speedometer (and rpm) lag? SD625 unit android 9 (3.8.5 and mcu gs 191127) tks
