04-11-2020, 08:47 AM | #3125 | |
Rep 1,048
You have to set "Aux switching mode" to manual, and best is to set AUX-Input to one of the shortcut keys of your OEM HU. Kri |
F20_M135i100.50 |
04-11-2020, 02:23 PM | #3126 |
Rep 551
Kri,
the problem is that these are all the players (Spotify / KswPlayer / Es Explorer ...) that pauses as soon as I go to the BMW OEM side, so manual and shortcut key unfortunately do not change anything. Which is abnormal because on my old PX6 unit, I did not have this problem. And on the OEM side BMW when I put the USB key in listening, and that I switch to Android = it works |
04-11-2020, 02:25 PM | #3127 | |
Rep 1,048
Kri |
04-11-2020, 05:43 PM | #3128 |
Rep 86
Its not because of the source. When you switch to OEM side you still see on the top right that Aux is still active. The audio source dont get switched by switching to OEM or to Android. Its because the Android System gets the Intent to Pause the music when you switch.
F20_M135i100.50 |
04-12-2020, 03:33 AM | #3129 | |
Rep 551
And when I go from ANDROID to OEM, a few seconds then appears AUX at the top in OEM (I'll make you a video). It is very curious as a behavior, especially since the opposite direction works perfectly well... Do you think this is Hardware or Software ? |
04-12-2020, 03:48 AM | #3130 | |
Rep 1,048
Edit: maybe its the way how the switch from Android to OEM has been done ? Kri |
F20_M135i100.50 |
04-12-2020, 04:12 AM | #3131 | |
Rep 86
F20_M135i100.50 |
04-12-2020, 11:33 AM | #3132 |
Rep 551
To get things done, I took a few photos after saving: I am with the Android media player => I go to the BMW OEM side. We can see that the STOP command is sent, but I don't know how to counter this order, or create a new one so that the music continues on the BMW OEM side :
One observation: the ANDROID audio player remembers its position! And when we restart it, it waver, and starts again from the cut to the OEM video: I did a factory reset to see = I lost all my applications, all my configuration, and more than 2 hours to put everything back in place without its solution to this problem ... the GPS sound from the ANDROID system goes well on the BMW OEM side (I don't understand anything anymore) |
04-12-2020, 12:42 PM | #3133 |
Rep 606
sint the music player killed when switching and it just restarts quickly on re-selection?
I had something likewise that, as soon as I switched apps, it killed my previous apps. It wouldnt allow apps to run in the background... it was a background service killer. |
04-12-2020, 04:42 PM | #3134 |
Rep 5
Anyone have a MCU for my unit? it got messed up after a crash and had to factory restore and its now a different mcu and dont work well whit my car X3 E83 whit factory navi screen, now i cant get the original info on the unit, it just say no signal!
My mcu is: 615043bALS HW7 and android 9 rk3399 unit And can i i update whit any px6 andoird 9 updates? |
04-13-2020, 01:14 AM | #3135 | |
Rep 551
Thank you for your help, it's a very good track (in addition to sending the intention, found via TASKER, which indicates that the music player has switched to STOP) Can you tell us which application did you see killed in the background on your unit please ? |
04-13-2020, 03:01 AM | #3136 | |
Rep 606
I stopped following the subject due to other priorities... |
04-13-2020, 04:47 AM | #3137 |
Rep 86
Hi, These logcat i found for switching to OEM side: Code:
IPowerManagerAppService IContentObserver - Key:systemMode - com.wits.pms.custom.KswStatusHandler$3@7804560 Code:
IPowerManagerAppService sendStatus Msg: {"jsonArg":"{\"acc\":0 |
F20_M135i100.50 |
04-13-2020, 12:56 PM | #3138 |
Rep 551
Well,
well I have to find a way, because according to the seller ".. It is quite normal that the sound does not pass from ANDROID to OEM." Ah good? And how do you explain that if I plug into this same AUX a mobile phone that plays music, it goes to the OEM side? In short, just that when we go from ANDROID to OEM an order is sent via MCU to the unit as follows: - Saves the position of the media player - Stop the media player - Stop all media - Kills all media - deactivates the tone on 2 speakers So I found a way to reactivate the media, to make it replay, but the display switches back to ANDROID at this time. I have to find a way to play the music in service or background application, but I can't find how to do it ... the picture TASKER : any suggestions or explanation of "background service" on TASKER are welcome friends! |
04-13-2020, 03:30 PM | #3139 |
Rep 86
Mhhh it gotta be related to the internal Music Player.
With other apps its working, for example Spotify. Someone have to decompile the KSWMedia App and look into the code |
04-14-2020, 03:24 AM | #3140 |
Rep 3
no connection to E60 CCC
Hello friends,
I have a problem. I have BMW E60 and bought Android Radio CCC through NaviFly. I made updates several times and installed different MCU versions on it. Unfortunately I have no connection to my car, steering wheel and menu button and the wheel does not work. I have already measured the cables there are no problems, I also got new cables from the seller, also no success . Then I tried the radio on my friend's BMW E60, but it was not a success either. what do you think it could be? Last edited by zehirlioglu; 04-14-2020 at 03:37 AM.. |
04-14-2020, 03:56 AM | #3141 |
Rep 551
04-14-2020, 04:52 AM | #3143 |
Rep 86
04-14-2020, 06:35 AM | #3144 |
Rep 3
Yes I tried the Can protocols too, no success
04-14-2020, 07:19 AM | #3145 | |
Rep 551
What I can say here, in my progress, is that it passes this sequence in the S625 ANDROID unit when we press the MENU button to return to OEM: - OutSideCommandManager: access $ 1300: 50 (which could be translated as going to OEM) - OutSideCommandManager: close MediaType = 11 (which could be translated as closing all media) - OutSideCommandManager: CloseMusic (which could be translated as closing all music) - Audio_hw_primary: disable_snd_device (2: speaker) (which could be translated as closing the audio channel) So I think these orders can / should be changed to leave the sound (music or media) continuous GPS background services continue to exist, so sound is still playing, media services are being killed, so sound is no longer playing ... |
04-14-2020, 09:12 AM | #3146 | |
Rep 86
Please try this one: Code:
IPowerManagerAppService IContentObserver - Key:systemMode - com.wits.pms.custom.KswStatusHandler$3@7804560 |
