04-14-2020, 12:51 PM | #3147 |
Rep 551
I will be happy to try your code, but I don't understand it, because if I use this code, what should I put next?
If I tell TASKER that this is a variable, and that it should launch the "kswMediaPlayer" application = it switches to the Android side If I tell TASKER that this is a variable, and that it must "put the loudspeaker on ON" and "launch the keyboard input Play Media" = nothing happens ... I've been going around in circles for 2 days, it's been busy during this difficult period, but I can't find a solution ... |
04-14-2020, 02:17 PM | #3148 | |
Rep 399
If you don't have DAB-Z, ask someone to get the logfile for you (I don't have root, so can't help). Last edited by Mjam; 04-14-2020 at 03:31 PM.. |
F20_M135i100.50 |
04-15-2020, 05:29 AM | #3150 |
Rep 1
CCC iDrive Display Not Working
Hiya,
I'm having a problem with my install. Everything works fine except the iDrive side. I've tried selecting all the different CCC types and they all produce a similar effect, although very slightly different. I also found this cable, should it be connected to something? Any help would be greatly appreciated! I had this installed as my iDrive screen was not working, this then revealed the iDrive unit was broken (stuck in a boot loop thing). I had this repaired and now the screen is as above, but all sounds, idrive controller and steering wheel works. The car is an e87 with CCC iDrive 2005/2006 model. |
04-15-2020, 06:11 AM | #3151 |
Rep 399
You have tried all CCC display types? In my E87 2009, number 13 is the right choice. Maybe number 10 or 11 in your 2005-6 model. My guess is that the monitor cable isn't correctly inserted, check for bent pins.
04-15-2020, 07:38 AM | #3152 | |
Rep 23
04-15-2020, 09:08 AM | #3153 |
Rep 43
04-15-2020, 09:13 AM | #3154 |
Rep 43
Sorry for double post.. Now i see the pictures, thank you First i will remove the main unit, if is still no signal message, i will cut the blue wire from the unit to screen.. I spoke with the seller and i gave him sygic and waze apk to install and test if it crash.. But it past 9days.. No answer |
04-15-2020, 12:07 PM | #3155 | |
Rep 20
can you tell me if what i created in tasker is correct for my low volume problem on my device? Because I don't have the impression that the volume is at maximum, when I turn on the radio of the bmw system I can increase the volume even louder. in the system the media setting is set to the maximum (40) thank you in advance for your help |
04-16-2020, 03:14 AM | #3156 |
Rep 2
what about this one? what do you think http://smarty-trend.com/bmw-3-series...head-unit.html
04-16-2020, 03:47 AM | #3157 | |
Rep 80
04-16-2020, 03:49 AM | #3158 | |
Rep 220
Drives: MINI Cooper, 2020 X1
04-16-2020, 04:03 AM | #3159 | |
Rep 1,048
Kri |
04-16-2020, 04:08 AM | #3160 |
Rep 80
04-16-2020, 04:21 AM | #3161 | |
Rep 220
https://mega.nz/file/5BsFWAjJ#6MPpZG...7BShBSiET5nWGM |
04-16-2020, 04:26 AM | #3162 | |
Rep 1,048
nothing more to do, reboot your device to see if it will work. Kri |
04-16-2020, 06:10 AM | #3164 | |
Rep 551
laimarc3.00 |
04-17-2020, 03:14 AM | #3165 |
Rep 86
Here is the newest Update for the Snapdragon 9.0 device:
Ksw-P-Userdebug_OS_v3.9.4-ota https://mega.nz/file/nkcRySBR#SQkL-M...PayImWx5Q_TuVA |
04-17-2020, 05:26 AM | #3168 |
Rep 11
Hi I'm new. I have been following forums for a long time, I want to thank you for all the information you are the best. Thanks "kri" for all the tests you do you are better. Android 9 CCC e60 v.3.9.4 I'm curious
