12-06-2019, 09:30 AM | #1 |
Rep 58
white smoke, smell of burning oil from engine bay
I take it this is not good :-\ Haven't taken the car in yet, but any idea what problem I am looking at here? Last edited by Gel214th; 12-06-2019 at 09:38 AM.. Reason: vimeo video not working |
12-06-2019, 11:13 AM | #4 |
Rep 2,432
Drives: 2021 M2C
And clean your engine bay!!!
12-06-2019, 11:16 AM | #5 |
Rep 2,671
^^Any specific steps for say, a deep clean of the engine bay? I keep mine wiped down, but often wonder if I could do more.
12-06-2019, 01:02 PM | #6 |
Rep 387
If you have access to a hot pressure washer, that would be the way to go. I fortunately have one at work, but it's more convenient to just go to the local self-serve car wash. Many of these have an "engine clean" option on the selector.
12-07-2019, 05:00 AM | #8 |
Rep 58
12-07-2019, 07:23 PM | #9 | |
Rep 540
11127570292 N55 valve cover 11367609963 Valvetronic screw (2) 11127599753 Vent hose 11377502022 Valvetronic seal Please notice parts will be different on your car. It was $1,033 USD OTD. |
12-26-2019, 09:59 AM | #10 |
Rep 58
Update on this, it was the tappet pan gasket cover, not sure if this is the same thing as the Valve cover gasket.
Apparently it was an easy fix, no more oil. Did an engine wash one time Changed rear brakes. He told me about a pending issue with the steering rack and that there was a kit for it. So may have to look into that in the new year. Not as bad as I feared it would be. |
Jayden_F87901.50 floridaorange10168.00 |
12-26-2019, 12:38 PM | #11 |
Rep 258
There's a cleaner sold here in the US called Purple Power, and it's fantastic for engine cleaning. You can find it at most auto parts stores. Remove the large plastic engine cover on a slightly warm engine (not a hot engine!!!) and generously spray the Purple Power all over. Loads and loads. Let it soak about 15 minutes and hose it off. Don't spray it on painted surfaces, but it won't harm hoses or plastics.
The front of the N55 and other BMW engines has an aluminum part; I think it's the oil filter housing. There's no good way to keep aluminum parts shiny clean. They are easily rusted and stained. You can finish off by wiping Armor All on all the plastic pieces. It will look really good, but it attracts dust, so it's kind of a 50-50 choice. Otherwise, I'm a huge consumer of Clorox wipes and any time I remove any part from my engine for maintenance work it gets thoroughly cleaned with Clorox wipes. |
12-26-2019, 05:48 PM | #12 |
Rep 139
good news ... glad you got it taken care of. Yes the tappet pan gasket is the same as the valve cover gasket.
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150 2021 RnineT 2022 K1600B |
engine bay, engine bay smoke, oil, smoke |
