09-27-2022, 01:27 PM | #1 |
Rep 56
How to "change" how often to change oil?
2018 340i. Got the car in July and the "oil change interval" was set to 9k miles. Do not want that. Put 4.3k on the car and the low oil light went on. Car said to top off the oil by adding a liter but I just went and got it changed the next day (No leaks, just drove it aggressively so it ate through some oil).
Issue: I cannot reset the oil change interval. When I hold the button to the left of the gauge cluster, it prompts me with "9k, Reset Impossible". What can I do to reset this, then set it to 5k. Does this have something to do with resetting the trip computer back to 0? I don't want to mess with any of the other intervals in the menu like brake pads etc. Please let me know, Thanks! |
09-27-2022, 01:39 PM | #2 |
Rep 140
my BMW SA advised me to just changed in between the recommended oil change intervals and not to reset it. when I had my oil change (since i still have the mainenance warranty) they set the interval to 12K miles. so when it hits 6K I will do my in between oil change.
09-27-2022, 01:39 PM | #3 |
Rep 1,798
You'll need a higher level tool than just your dashboard to set the interval lower... The reset should be able to be done at the dash though. Just google it. These cars use condition based service, the oil quality is monitored by sensors in the engine and will tell you when it needs to be done. Default is 1 yr 10k miles I believe.
09-27-2022, 02:00 PM | #4 | |
Rep 5,392
09-27-2022, 02:16 PM | #5 | |
Rep 436
09-27-2022, 07:20 PM | #6 |
Rep 1,791
My car says 9k miles after an oil change when the dealer resets it even though it's coded to 10k miles but I get it changed every 5k miles. I just get it changed when there's 4k miles left.
If you want to change the interval you will have to code it with Esys. There are threads that list what the VO codes are. |
09-28-2022, 12:31 PM | #7 |
Rep 975
Right? If I was missing that much oil, I'd be scouring the engine bay to see where it's going.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
09-28-2022, 01:06 PM | #8 | |
M340i
394
Rep 969
Drives: BMW M340i
Should be able to reset the maintenance minder from the dash. I know I do. |
M Smurf156.50 Fliplegend1471.00 |
f30, oil, oil change interval |
