01-14-2015, 02:19 PM | #23 |
Rep 36
05-13-2015, 09:42 PM | #24 | ||
Rep 397
Appreciate it in advance.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
07-09-2015, 01:22 PM | #26 |
Rep 258
For anyone trying to do this:
I just got an airbag from my dealership at around 740$ and on ebay they have plenty of steering wheels ranging from 200(without paddles) - 500 (brand new and such with paddles) i got mine for 300 from romania. everything seems the same except instead of the "set" button it says "lim" i will be installing myself in a few days when airbag comes in, ill let you guys know. my project total is around $1040 |
07-11-2015, 07:35 PM | #27 | |
Rep 397
07-11-2015, 07:48 PM | #28 | |
Rep 312
http://www.autonationrosevilleparts....mw/32307845798 The link above will not ship airbags at all since they're classified as a hazardous material. According to my dealer, there are only 8 left in the entire country as spare parts. More will come in eventually, but I'd pick one up ASAP. I'm retrofitting this myself Monday night. |
07-11-2015, 08:03 PM | #29 | ||
Rep 397
I will see if I can get my dealer to match price, hopefully they will.
04-07-2016, 03:46 AM | #30 |
Rep 6
Hey man I noticed your in toronto are you part of BMWTN? Also Im close to buying a 2013 f30 335i and I want the lci steering wheel but I was wondering is 32307848338 the part number for the steering wheel? I found a good one on ebay and im thinking of buying the air bag from Pffaf BMW in mississauga just to be on the safe side Thanks!!!
04-08-2016, 08:22 AM | #31 | |
Rep 41
Definitely would like the link. Thank you! |
09-12-2016, 10:10 AM | #32 |
Rep 173
Drives: 2021 M340i
So I replaced my sportline wheel (no paddles) with an M-sport wheel that had paddles. I had previously coded 2TB to my car and VO coded FEM, EGS, ICM and KOMBI so I've had those functionalities for a while. I read on this post and on other posts that if I had FEM BODY 3190 PADDLES_VERBAUT then that means my car was pre-wired for shift paddles.
However, after starting the car, the paddles did not work - I coded the PADDLES_VERBAUT back to nichtaktiv, restarted the car, and re-coded it to aktiv and it still didn't work. Does that mean my car isn't pre-wired and the only reason that folder in FEM BODY exists is because I VO coded 2TB? |
09-13-2016, 12:34 AM | #33 | |
Rep 397
My car was not rewired as confirmed from my retrofit. I thing whoever made that claim just happened to have a prewired car. I think you need to do the wiring to get it working. Its a pretty fun option. I left 205 in there but activated sports transmission (no sports+) I don't want to accidentally turn off traction control in traffic.
05-10-2017, 08:59 AM | #34 |
Rep 13
Does anyone know where I can order a pre made connecting wire from? That seems to me like the most confusing part of this DIY. Much appreciated.
2014 320d, AW
01-19-2019, 05:51 AM | #35 |
Rep 270
Drives: 2015 X5d M Sport Metallic Whit
M3 wheel with paddles installed
I know this is an older thread but google is wonderful at finding these gems - I found it helpful so thought I’d add my experience. I have a ‘17 non M-Sport F31 that came with the standard ‘Sport’ wheel. I love the look and feel of the heavier M-Sport / M3/4 wheels so purchased a used one from BimmerPost. I also found a US spec M3/4 airbag (legit, dual stage, vent, leather cover) slightly used. Getting the Sport wheel’s airbag off was the most difficult part of the process (I even tried the ‘remove the cowling’ approach but it just didn’t seem to release the bag). The whole thing was plug and play with the M3 wheel except for the paddle shifters...I need to run the signal wire from the passenger well to the wheel’s electrical connector - not a huge deal. The parts are silly expensive from the BMW dealer but cheap from various legit OEM retailers. Check out Kies Motorsports excellent DIY for the M3 paddle shifters install (including part numbers)
Mine was plug and play otherwise for the wheel - no coding required and no Airbag malfunctions or warnings. It’s a great upgrade and well worth the time. |
10-09-2020, 03:19 AM | #36 |
Rep 5
I know this is old but hoping someone sees this and can tell me a legitamate site to purchase an oem m sport steering wheel for my f30 320xi bmw. Can't find one anywhere that doesn't look like a scam and kind of confused as to why such a big company like bmw doesn't have these steering wheels for sale for all vehicles. My only hope right now is eBay but i'll wait to see if y'all got a good place to get them. I'd even go into the bmw dealer near me to get a new wheel, tired of this boring old base wheel.
08-22-2021, 07:01 PM | #37 | |
alpinweiß
Rep 64
its confusing trying to find something like this, the stuff on ebay can't be legit for $900. |
07-26-2022, 12:36 AM | #38 |
Rep 15
I have couple question:
1. My US spec 2016 F30 has the regular sport steering wheel with the paddle shifters. If I get the m-sport steering wheel without the paddle shifters, can I remove the paddle shifters from the regular steering wheel and install on m-sport? If yes, do I need coding? 2. If I buy a 2-stage airbag for the m-sport steering wheel, then do I need to coding? |
07-26-2022, 07:13 PM | #39 |
Ozzy Dude
222
Rep 187
Drives: BMW F30 330i LCI
07-26-2022, 11:15 PM | #40 |
Rep 1,117
1) Technically, the same paddles in the F3x series work across all steering wheels. However, the MSport Steering wheel without paddles will not have the screw holes for mounting. You must create them. You might not have the proper wiring connection either.
You should also be aware that BMW calls for a steering wheel to be replaced when an airbag deploys. That’s why people find them easily on eBay. That might not worry you, but BMW does call for their replacement. What do they know that you don’t 🤷🏼 2) As you are in USA you should already have 2 stage Airbag. Swapping a 2 Stage to 2 Stage Airbag is plug and play. Many airbags, including most Single Stage Airbags on eBay from EU are either counterfeit or rebuilt. I wouldn’t bet my life on one of those. |
07-26-2022, 11:19 PM | #41 | |
Rep 706
ReMiii4021.50 |
11-10-2023, 02:37 PM | #42 | |
Rep 29
Drives: '14 F31 M-Sport, '11 E90 335i
My VIN is WBA8K3C57JA485848 Options to note: 544: Cruise Control With Braking Function 5AG: Lane Change Warning Servotronic Looking at my stock wheel, it says SET, not LIM like a lot of the ones for sale on eBay. I found this M-Sport wheel that has the right buttons and its a vibration wheel. Since you also have an LCI F31, would this wheel be the right fit for me? It would simply be plug and play? No wiring needed? I also talked to a dealer that said it's not possible to retrofit LCI cars with servotronic steering, but I think they're wrong. Thanks https://www.ebay.com/itm/15573605468...3ABFBMuPuK1vZi |
11-10-2023, 05:58 PM | #43 | |
Rep 1,117
LIM is for cars with Adaptive Cruise Control with the radar unit on the front grill |
11-10-2023, 08:45 PM | #44 | |
Rep 270
If you have an adaptive cruise control equipped car, then you have 2 extra buttons beside the normal cruise buttons. These allow you to increase or decrease the following distance between you and the car ahead. If you have a car with TJA (Traffic Jam Assist) as well, then you have an extra top button which changes the followong distance and an extra bottom button that engages the TJA (it'll have a small steering wheel symbol and lines). Love mine (X5 35d). Cheers |
Saito1.50 |
