10-13-2020, 12:22 PM | #1 |
Rep 245
Connecting Dorch 1 to Spool ethanol sensor
I had the Spool ethanol sensor connected and working with my stock HPFP. I just installed the Dorch stage 1 HPFP that has a QD connector on the LP side. The Dorch supplied hose has QD on both ends, but the end that connects to the LP fuel line from the tank is smaller and will not fit on the ethanol sensor QD (which is the same size as the one on the Dorch LP side). Where can I find a short (12"?) fuel line that has large QD on both sides? Has anyone run into this?
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
10-13-2020, 01:45 PM | #2 |
Rep 57
You need to contact Dorch and tell them what you're trying. They are going to send you a new line that will work with the EA.
2020 M340i xDrive Mineral White Metallic
RIP: 9 second 1/4 BMW 340i xDrive Melbourne Red | Instagram: daddy.340 |
10-13-2020, 02:30 PM | #3 |
Rep 154
When I ordered my Spool ethanol sensor. I told them I was running the Dorch pump and they gave me the necessary fuel lines.
