BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Good alignment specs?
      05-18-2019, 11:19 AM   #1
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
How are my settings? This is with the powerflex adjustable camber bushings up front.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      05-18-2019, 04:08 PM   #2
jbiswurm
Drives: F30 335i msport 6mt
confused. looks like everything is in the stock ranges. I would have expected to see more camber up front. the F30 begggggs for more camber up front. I would get to 1.5 at least if you can. everything else seems fine.
      05-18-2019, 05:50 PM   #3
52172
52172's Avatar
The bushings only neted .5 deg camber
      05-18-2019, 06:37 PM   #4
jbiswurm
ah. well every little bit helps. I'll recommend the F80 arms. they really helped me.
      05-20-2019, 02:19 PM   #5
reyoasian
Drives: 340xi MPPSK
Hijacking thread.
Should I get an alignment before track season starts?
Stock suspension so no lowering, but not sure how off it is off from all the potholes over the winter.
      05-22-2019, 09:50 PM   #6
colobrio
Drives: 2016 3281i
Originally Posted by reyoasian View Post
Hijacking thread.
Stock suspension so no lowering, but not sure how off it is from all the potholes over the winter.
I can't speak to potholes. I got an alignment last season while still stock, to get some camber in back and some of the toe out in front. I think it helped a little. The rear tires certainly wore a bit more evenly.
      05-24-2019, 08:10 AM   #7
reyoasian
Drives: 340xi MPPSK
Thanks, definitely looking at a more aggressive toe in the front.
Too bad camber is not adjustable up there though, would prefer more camber up front as well.
My tire wear isn't bad but it's definitely not even.
      05-24-2019, 10:23 AM   #8
52172
52172's Avatar
Loving my adjustable camber bushings just the added half a degree neg camber makes a difference.
      06-27-2019, 06:53 AM   #9
SoCalCarGuy
Drives: 2019 440ix cpe + 2018 x4 m40i
The alignment shop didn't change your front camber. It's still the same. They didn't dial in an extra half degree negative. Show your shop this thread.
      10-14-2020, 11:32 AM   #10
itsrichierich
Moto Lover
itsrichierich's Avatar
187
Drives: '19 BMW S1000XR
No one really responded to the specs. Besides needing camber at -1.5 (or more), how is everything else for OP?
      10-14-2020, 11:37 AM   #11
52172
52172's Avatar
Running fortune auto coilovers with camber plates now and neg 1.5 camber up front and had to dial in neg 2.3 camber in the rear to fit my 275/30/19 on 19x9.5 et35 wheels. We're actually going to take out a little more camber in the rear to like neg 2.0 or 1.8 cause i originally was on 275/35/19 tires when alignment was set.
      10-14-2020, 11:41 AM   #12
52172
52172's Avatar
that's because initial was taken with camber bushings already installed.
      10-16-2020, 02:59 AM   #13
jmg
jmg's Avatar
18694
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Both the F30 and F80 tend to beg for negative front camber. I run -2.7 in front and -2.3 in the rear. What are your goals with this setup? Seems like your setup is leaning towards understeer.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      05-28-2021, 12:19 PM   #14
52172
52172's Avatar
yes would rather encounter some under steer rather than oversteer. I could always create oversteer with more throttle!
      05-28-2021, 12:57 PM   #15
jmg
jmg's Avatar
18694
2019 i3 BEV  [0.00]
Oversteer changes what direction your car is facing(rotation) but it won't always necessarily change the direction your car is traveling(vector). So you can create the rotation with throttle and weight transfer, but the camber will actually help you get the grip needed to make the turn and hit the apex.
IG: Raging_G82
      05-28-2021, 05:05 PM   #16
52172
52172's Avatar
so your saying a little oversteer is better? That would mean less traction in the rear rt?
      05-28-2021, 05:56 PM   #17
jmg
jmg's Avatar
18694
2019 i3 BEV  [0.00]
Relative to the front yes. That can do with tire compound or weight distribution due to the dynamic state of the car.
In general a little oversteer is better than understeer, but predictability is actually what you are looking for. Gradual traction loss that translates to the driver so you know when you are at grip limits. That is accomplished through the tires and suspension. Playing with camber, castor, rebound and spring rates so that upsetting the car is minimized during weight transfer and by road/track conditions.
IG: Raging_G82
      06-04-2021, 10:28 AM   #18
romemedrano
Drives: BMW F30
Here is mine.
I'll be maxing out my camber plates later today. Trying to get to around -3.1 front
This is official BMW KDS so it reads in degrees then minutes. 60 minutes = 1 degree.
