08-29-2018, 07:12 AM | #23 | |
Rep 231
Look on eBay or Facebook for Murray from "Visual-Ice". Apparently he can custom make enclosures for whatever subwoofer you want, just give him the make/model and he'll spec it for the woofer. I'm currently waiting to receive my enclosure. Ordered about a week ago from Murray he has been great over email so far. Very communicative, prompt replies, professional service. Only thing is that I don't have the actual product yet so take this referral with a grain of salt. However if you search these forums for Visual Ice there are a few members who vouch for Murray and his work. I'll keep you posted once I receive mine. If it works out, it will be great though. Pics look like MusicarNW quality for 1/3 the price!!! AND custom for specific subwoofers! |
09-02-2018, 08:17 PM | #25 |
Rep 119
Hello people,
I'm new to the F30 (DEC 2017 330e) and can't wait to get proper sound in the car. My previous car (an Ancient Jaguar S-type had a Morel hybrid 602 set ran by a Sinfoni amp...). Two questions: 1. I have the lame HU_ENTRYNAV - how do I even connect an amp to it? I understand it has no RCA's in the back.. some wiring harness? If so which one? Also the output is speaker level while I want to get low level signal into the amp. I hate that I can't just install a proper double-din unit... I'd rather not retofit the bigger screen for warranty reasons. 2. The car is a Sedan (duh), if I put a sub in the boot (say a 10" morel ultimo SC in a sealed enclosure) would it be heard in the front? What are the under-seat subs? Do I have it with the base (not HK) sound system? What drivers can I use to replace them? Any advice is appreciated, thank you! Last edited by RoundRound; 09-03-2018 at 05:37 AM.. |
09-03-2018, 06:09 AM | #26 | |
Rep 195
RoundRound30.50 |
09-05-2018, 09:12 PM | #27 |
Rep 262
Drives: 2013 BMW 335i M-Sport
Here's my build from two years ago.
09-06-2018, 01:13 AM | #28 | |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
https://f30.bimmerpost.com/forums/sh...0&postcount=21 I then added a 5m ISO extension to run the high level feeds to an amp in the boot, but you could add a pair of Hi to Low converters in/behind the glovebox and run RCA's to the amp from there. https://www.ebay.co.uk/itm/In-Phase-...8AAOSwlxRaZwXl
10-14-2020, 11:21 PM | #29 |
Rep 187
Drives: 2013 x5 m57
Old thread bump
How is everyone getting power and ground into the underfloor storage? I've found rubber plugs in the battery area and the storage bin area, ran a wire in the battery side and it didn't come out the hole in the storage bin side 🤷🏽*♂️ I saw in a this thread "I drilled a large hole", a large hole in what? Through the bin side into where the battery is?!?! |
10-22-2020, 11:50 AM | #30 |
Regular user
224
Rep 965
Behind the trim panel above the battery is a connector block that runs off the positive side of the battery. I used a large eyelet crimp on a lead to feed down the inside of the trim panel and along to where my amp was. You should be able to just run it under the trim.
