BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Engine coolant Temp?
European Auto Source (EAS)
      04-16-2015, 06:11 PM   #1
Trcb777
Trcb777's Avatar
Drives: 2013 335i M Sport
Anyone know what the engine coolant temp normal operating range is? My 335i runs about 225 F.
      04-16-2015, 06:25 PM   #2
COKen
COKen's Avatar
Drives: 2014 435i / 2002 M Roadster
Are you sure that isn't your oil temp? If it is, then that temp is OK. ( I don't think BMW has put coolant temp displays on our cars for some time now.)
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C.
      04-16-2015, 06:27 PM   #3
Trcb777
Trcb777's Avatar
I have a obd link scan and its showing coolant temp.
      04-16-2015, 06:36 PM   #4
E90Fleet
South Africa
1123
The engines have variable MAP controlled thermostats, so coolant temperature varies depending on the mode the ECU is in.
Its one of the reasons BMW dont show coolant temp anymore to regualr drivers
Range is from 80C - 111C (176F - 231F )
"Normal" is around 105C (221F), so your 225F is perfect
ECO mode will take it to 111C (231F)
BMW if you are reading, I need a job, Please.
      04-16-2015, 06:37 PM   #5
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
I believe the thermostat opens at 105C, so coolant temp should be in the 221F area.
      04-16-2015, 06:38 PM   #6
E90Fleet
South Africa
1123
Nope. MAP controlled
      04-16-2015, 07:18 PM   #7
Trcb777
Trcb777's Avatar
Thanks for the info
      04-16-2015, 09:10 PM   #8
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The coolant temp is going to be about the same as the oil temp. 225 seems high, as water boils at 212, but the coolant isn't pure water, and it's under pressure, which also lowers the boiling point.
      04-16-2015, 09:20 PM   #9
Mike_L
Pressure and coolant raise the boiling point.
      04-16-2015, 09:37 PM   #10
Billfitz
Billfitz's Avatar
I meant raise, of course. That's what I get for going on line when I should be going to bed.
      04-17-2015, 05:56 AM   #11
JJS
New Zealand
113
Drives: BMW F31 335i 6MT M-Sport
There is an echo in this thread.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional |
      04-17-2015, 11:53 PM   #12
Kev314
Drives: 2014 328 xdrive
Makes you wonder about toggling between modes since it might never operate at the optimal temperature with frequent toggling. I suppose the variations are nowhere near as severe as during warm up from dead cold.
      04-18-2015, 04:40 AM   #13
E90Fleet
South Africa
1123
The ECU modes are not linked to the modes you can select for the gearbox and suspension.
The ECU modes are ECO,Normal,High and High+.
The ECU automatically determines which mode to go into depending on driving conditions.
The driver cannot select the modes.
      04-18-2015, 08:05 AM   #14
Kev314
OK - Thanks for the explanation.
      05-13-2015, 01:26 PM   #15
Fast400
Fast400's Avatar
Drives: X4 M40i G02
2014 BMW  [0.00]
I hit 234F today...according to obd. Should I be worried?
      05-13-2015, 02:29 PM   #16
HighlandPete
Drives: BMW F11 535i Touring
BMW Data for typical N55 Engine Cooling
The engine control unit regulates the following temperature ranges:
108C/226F = Economy mode
104C/219F = Normal mode
95C/203F = High mode
90C/194F = High mode and control with characteristic map thermostat
System Protection
If the coolant or the engine oil overheat during operation, certain vehicle functions are influenced to the effect that more energy is available to the engine cooling system.
These measures are divided over two operating modes:
Component protection
- Coolant temperature between 117C/242F and 124C/255F
- Engine oil temperature between 150C/300F and 157C/314F
- Result: The output of the air conditioning system
(up to 100%) and of the engine is reduced
Emergency
- Coolant temperature between 125C/257F and 129C/264F
- Engine oil temperature between 158C/316F and 163C/325F
- Result: The power output of the engine is reduced
(up to 90%)
As you can see, 234F for engine coolant is still below any protection thresholds.
HighlandPete
      05-13-2015, 07:47 PM   #17
BavarianFanatic
Too much is never enough
Drives: Too Many
This is not correct. The opposite is true.
      05-14-2015, 12:59 AM   #18
tekzhicuh
Drives: bmw
m3 is cool
      05-14-2015, 02:55 AM   #19
Fast400
Fast400's Avatar
Drives: X4 M40i G02
2014 BMW  [0.00]
System Protection
Emergency
(up to 90%)
HighlandPete
Great info! Thanks Pete
It's still a weird feeling coming from vehicles that ran 200F tops. All in the name of fuel economy I guess.
      05-31-2015, 02:45 PM   #20
RootCanal05
Clutch Rider
RootCanal05's Avatar
Drives: 335i xDrive M-Sport
I have a 2015 335 6 MT w/ M PPK and I noticed it was running just under 250*F. I was highway cruising at ~70mph, in sport mode, it was 72* outside, low humidity, cruise control was on, AC set at 68*. I didn't notice any reduction in power or quality of the AC. It ran at that temp for 3/4 of the trip then it went down to the usual ~220. It did concern me since I never saw the temp gauge go over the 220 mark even on 90* humid days. The SA stuttered through an answer when I questioned him about it. Then he ends with "it's normal." I hope he's right.
RootCanal-
      05-31-2015, 02:58 PM   #21
HighlandPete
Are you referring to the temperature gauge... reading oil temperature, not the hidden menu and reading ECT? If so, then you are in the normal range at 250F. Gauge is only at mid position, isn't it?
HighlandPete
      05-31-2015, 03:05 PM   #22
Trcb777
Trcb777's Avatar
Are you talking coolant temp or oil temp. Either way, they both run high and its normal.
