08-22-2018, 12:23 AM | #177 |
Rep 10,473
08-26-2018, 02:01 PM | #179 |
Rep 771
Is the green light flashing as well on PI. Green light is Wifi I believe. Also which Raspberry Pi did u buy? Hope u did not buy the B+
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White |
08-27-2018, 10:15 AM | #180 |
Rep 285
08-28-2018, 01:56 AM | #181 |
Rep 55
Ive got a question.
Will bootmod3 work on a raspberry pi 3 with a screen in a small case? I typically prefer not to do stuff on my phone and would like a dedicated box for it. So my questions would be. Since I havent looked up or even tried a test boot on this software at all. Does bootmod3 have a GUI? Not on the phone but the pie. How intuitive is the gui on the pie? The phone looks fairly simply. Im wondering if there are set blocks on the gui where I can swap tunes on the fly? Im assuming this is like the jb4 where you can pull the tunes and lock it if you need to take it to the dealer for anything correct? I had something similar to this on my mustang before and really loved being able to see all the stuff going on with the car. https://www.americanmuscle.com/gtx-t...product_pics-0 Im assuming once again that the bootmod3 if it has a gui shows boost levels and other such things going on within the car? |
08-28-2018, 09:08 AM | #182 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
08-28-2018, 03:21 PM | #183 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Anyone tried powering the Pi with a 12V outlet? My radar detector's 12v power adapter has a second outlet. Its an ethernet connection. Would rather use this since its empty and i can leave my usb port open.
Quiet M235i
08-28-2018, 05:06 PM | #184 |
Rep 2,382
Yes. I use the one under the dash.
EVEda235i90.50 |
08-29-2018, 08:13 PM | #186 | |
Rep 10,473
However it’s not going to be happy with 12V from a cigarette lighter plug or the ODB. You need to step the Voltage down for the raspberry (or up for the NUC). Last edited by IK6SPEED; 08-29-2018 at 10:49 PM.. |
EVEda235i90.50 |
08-30-2018, 09:01 AM | #187 |
Rep 2,382
Why wouldn't it be happy? I've been utilizing mine for a year now with zero issues.
08-30-2018, 09:37 AM | #188 | |
Rep 10,473
Feed most electronic pieces 150% more voltage than they want and they become a door stop, especially those without a good power regulation system which the Pi lacks in its compact size. I do not intend to risk fate. Not of the $50 Pi, but a resulting fire that could take the car out. |
08-30-2018, 10:16 AM | #189 | |
Rep 2,382
You could also get a power supply shield for the Pi if you're looking to tap the 12v wire.
08-30-2018, 10:30 AM | #190 |
Rep 10,473
Yeah, sure.
There is a reason they are called 12V power sockets and 12V adapters. Last edited by IK6SPEED; 08-30-2018 at 10:48 AM.. |
08-30-2018, 12:34 PM | #191 |
Rep 2,382
Yes. No one is discounting that. I'm well aware of the socket's varying voltage as well. I simply was saying that you can, in fact, run it from the cigarette socket if you'd like. I've stated in a previous post of my setup utilizing the adapter and running it underneath the radio controls.
08-30-2018, 02:23 PM | #192 | ||
Rep 325
Drives: 2016 F36
In the end we should be safe to assume a 12v rated device, plugged into a 12v rated supply are made to work together, therefore should not be able to overload or overdraw and cause damage. Does it happen yes, by why worry so much especially since these Pi boards are under $30. We're not talking about a $3,000 electronics board. Our car also circuit fuses designed to fail if an improper current is flowing through the line. So IMO it's safest to a cheap 12v device into a protected 12v source. That way if the cheaply made device is out of spec or standard and over or under draws it will simply blow a fuse or fry itself. At least that's my take on the Pi and plugging it in. When I get around to it, I'm tapping a 12v socket into the 12v socket line under the dash center. I'll report back if sparks fly
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
08-30-2018, 03:14 PM | #193 | |
Rep 2,382
My current setup is a 12v cigarette socket adapter (the one under the dashboard) that outputs 5v to two (2) USB Micro B cables that run immediately under the radio/A/C controls. One comes out on the opposite side of the trim to charge the tablet while the other stays within the trim and goes to panel below the steering wheel. There I have my Pi plugged into power and also the OBD2 port. There are boards to convert 12v to 5v that you could slap on top of the Pi as well.
Noelified228.00 |
08-30-2018, 03:43 PM | #194 |
Rep 109
my first BM3 OBD wifi agent I picked up from ebay doesnt work. I picked one up from kiesmotorsport and it works fawlessly. Anyone have trouble with their dashboard not spinning at all? all the datalogs I recorded while driving all remain empty, though I do have the time stamps posted on BM3 online.
08-31-2018, 01:28 AM | #195 | ||
Rep 10,473
I stated I ran mine off the ODB which is 12V. But you cannot power it off 12V with a transformer. And then BunkerJ stated you could run it off 12V Cigarette lighter, which is false. No mention of step down transformer. As step down transformer was stated in OP, and he objected to that, only one way to take it, until he was proven wrong. And quite simply, to state it was fine from cigarette adapter is plan reckless as someone would try and wire it direct and blow out their PI. So much for assuming. |
08-31-2018, 09:14 AM | #196 | |
Rep 1,499
Reset adaptations and that should fix your dashboard and logging
08-31-2018, 09:19 AM | #197 | ||
Rep 2,382
Let's quit the banter and move on. No need to clog up a perfectly good thread with this nonsense.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit Last edited by BunkerJ; 08-31-2018 at 10:00 AM.. Reason: words |
09-01-2018, 03:25 AM | #198 | ||
Rep 10,473
And then there is the 2nd line that one COULD use a device between the 12V and Pi. Quote:
