08-23-2021, 04:37 PM | #1 |
Rep 6
N20 Turbo issues
I recently purchased a '15 428iX with 59k miles. After driving it only four times it popped a message of Drivetrain Malfunction drive moderately. Looks like low boost and it might need a Turbo. Any idea if it would be covered under emissions warranty? And if not.....what is a better replacement setup? might as well make it better if I'm paying for it!
08-23-2021, 08:15 PM | #2 | |
Rep 384
second, you better scan the error code to identify the error
Instagram: nightfall.f30
08-23-2021, 09:05 PM | #3 |
Rep 6
Code was scanned by BMW certified technician, all sensors were replaced to eliminate potential false readings. Low boost issue, he determined bad turbo, suggested taking to dealership hoping for emissions warranty replacement.
I was under the impression that a '15 428i had the B46, but see now I'm wrong. This is my first experience in the European car world, so far not good. I'm not new to cars by any means, have always had (and still do) GM Muscle. Last edited by Elkwagn; 08-23-2021 at 09:22 PM.. Reason: Better explanation |
09-12-2021, 01:16 PM | #4 |
G
129
Rep 162
Drives: 2013 BMW 328i F30 Luxury Line
They can be a pain in the a** because of the modern tech but they're an overall good experience. Find an independant shop in your area for BMW and Euro cars, that'll save money, they can help you with upgrades and they're enthusiast centered. The N20 is a good engine, in your year and model there is no more timing chain guide issue and they can be finicky when it comes to mods / upgrades. If you go with a bigger turbo you will have to upgrade the charge, boost, turbo inlet and down pipes as they are plastic and will fail and upgrade the intercooler as well.
09-14-2021, 01:29 PM | #5 |
Rep 129
It could be many things, but on my 2013 N26 when that happened it was the wastegate that failed...of course my original wastegate was pneumatic.
09-14-2021, 03:01 PM | #6 |
Rep 16,073
09-16-2021, 04:56 PM | #7 |
Lancaster Dave
Rep 1
N20 Turbo Oil Feed Line Issue
I have a 2013 328 IX with the N20 turbo engine. Noted blue smoke out exhaust on cold start up. Found the issue is the oil feed line leaks into the turbo causing burn off on start up. Car drives fine and no codes but this car guy can’t stand a blue puff on startup. Found a BMW Tech Service bulletin extends warranty coverage for 10 years Or 120k miles for 2012-13 N20 engine with oil feed line issue Repair involves installing a new oil line that has a check valve, preventing oil drip back. Dealer and the friendly BMW “customer care” rep sadly report my vin. is excluded from the warranty coverage even though our car has 48k miles . Dealer quoted $2,134 to replace the line (bmw part cost $41.00 labor $2 grand.
Anyone have any experience with this. Xtremely dissatisfied bimmer guy Dave |
09-16-2021, 09:26 PM | #8 |
Rep 16,073
The leaking turbo oil feed line is very well known. There are youtube videos how to replace it. It's not something only seen in BMW. Google 'turbo oil feed line leak' and you'll see at least ten pages of results.
11-01-2021, 10:14 AM | #9 |
Rep 6
Update:
Replaced the turbo, bought the "kit" from Bimmerworld with the "big" turbo upgrade. Other than the fact there is 100lbs of shit in a 5lb box under the hood of these, it was fairly easy to swap out. Quoted $5k to have it done at dealer, $4k at an independent shop, have $1850 into it and probably could've done it in a day if I hadn't gotten busy and done other things in the middle of the job. Currently on stock tune with everything stock besides the bigger MHI N20 Turbo. May pursue further upgrades, may just sell. Last edited by Elkwagn; 11-01-2021 at 10:19 AM.. Reason: correction |
11-01-2021, 10:21 AM | #10 | |
Rep 5,457
Drives: F30
https://www.facebook.com/groups/244324833434651/ |
11-01-2021, 11:09 AM | #11 | |
Rep 706
sspade2464.50 |
