12-10-2018, 04:50 PM | #1 |
Rep 285
Drives: 2014 428i XDrive
Catless DP Question - O2 Sim or Valve
Hey guys,
Does installing an O2 sim and/or one of those defouler valves cause misreads to the ECU causing lean / rich conditions in the engine by any chance? I always wanted to go Catless but swapping it for emissions check is a huge turn off every year Current high-flow catted dp does not cause CEL - Does the VSRF DP Fix work for N20 / N26 EWG? - Does the AK74 (-K) work for N20 / N26 EWG? Last edited by lonecitizenfour; 12-10-2018 at 04:58 PM.. |
12-10-2018, 05:13 PM | #2 | |
Rep 3,680
But, it won't help with passing emissions. At least not if they put a thing in the exhaust tip to actually test the emissions like they do in NJ. What are you worried about this for if you already have a catted DP that isn't causing a CEL though?
12-10-2018, 05:13 PM | #3 | |
Rep 285
12-10-2018, 05:15 PM | #4 |
Rep 3,680
Gotcha. So why are you worried about an O2 spacer if you already have a catted DP with no CEL?
EDIT: cause you want to go to a catless DP. Missed that part of your post. My b!
12-11-2018, 08:47 AM | #5 |
Rep 420
I have a catless downpipe, o2 spacer (spark plug defouler) and I am not tuned yet.
I do not have a steady CEL, but I have gotten a CEL twice so far in the last month that cleared itself on the next start. |
12-11-2018, 09:56 AM | #6 |
Rep 285
Is this absolutely safe that it won't cause a lean condition?
12-11-2018, 01:57 PM | #7 |
Rep 3,680
Read my first post. As long as you put it on the right O2 sensor it will be fine.
12-11-2018, 02:34 PM | #8 |
Rep 285
12-11-2018, 07:12 PM | #9 |
Rep 3,680
As long as you put it on the right O2 sensor, yes.
12-12-2018, 06:23 PM | #11 |
Rep 285
Okay thanks. I'll ask if the shop can get this part from autozone or something and add it in... if not... there's always next time.
12-12-2018, 08:22 PM | #12 | |
Rep 285
Thanks |
12-12-2018, 09:26 PM | #13 |
Rep 937
Bro
Hi
12-12-2018, 10:10 PM | #14 |
Rep 285
