BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Odd ABS light appearance
      12-14-2018, 04:17 AM   #1
454697819
Drives: F31 335D XD
Morning All
Over the last week I have experienced an odd flash of the ABS light (above the temp gauge)
It flashes for half a second or so and disappears, not long enough for the ID system to log a fault or for it to flag on the ID screen.
There appears to be no real consistency with this, occurring at high speed, lower speed, on the throttle or coasting. this is combined with my gear box doing strange things, like feeling a little lumpy occasionally when going on or off the throttle even when warm, and holding 7th gear not dropping into 8th on the motorway.
I initially blamed the fact the car was disgustingly filthy, but a bloody good clean around the brakes and sensors has made no difference.
Of course the obvious thing will be to send it back to BMW, which I intend on doing but naturally I wanted to ask you lot if you had seen or heard of anything similar whilst I wait for a date from BMW.
Its a 67 plate 335D XD.
the only other possibility I thought off was the Tyres on the back are approaching 3 mm but the fronts are still a bit over 5mm, is this enough to confuse the XD system?
Car has 31k on the clock.
Any guidance or previous experience appreciated.
335d XD Shadow Edition - Mission intergalactic mileage underway
      12-14-2018, 05:40 AM   #2
Sasquartch
Drives: 520i G30
Sounds like a wheel sensor is possibly duff
You'd really need to connect it up to ISTA and see if any faults logged
