10-10-2018, 11:40 PM | #1 |
Rep 808
Need help coding led foglights
I've got an f30 that I installed oem led foglights in that seem to need to be coded. I coded off bulb check so they don't flicker on start up. However after a minute or so they start flickering. I've got all the software (e-sys and more) and cables. I'd really appreciate the help
10-11-2018, 07:37 AM | #3 |
Rep 16,060
Flicker on start up is from the cold check. Flicker after that is from the warm check. You have to code both to not active. Strobing when they're on is from 'is LED' not being active.
10-13-2018, 12:58 PM | #4 |
Reads books at a 4th grade level; I'm an enabler
78
Rep 116
Drives: X5 35d, 335i Msport, X3, 325iX
Garage List 1993 BMW 525iT [0.00]
1989 BMW 325iX [0.00] 2015 BMW 335i M-Sport [0.00] 2007 BMW X3 M-Sport [0.00] 2015 BMW X5 [0.00] |
This is the correct solution, as I just did this upgrade myself last week. You may have to also update the date code (Zeitkriterium). 0715 should work.
