11-29-2018, 07:56 AM | #265 | |
Rep 1,499
NICE!! Thanks for adding!
11-29-2018, 09:55 AM | #266 | |
Rep 170
11-29-2018, 10:01 AM | #267 |
Rep 170
Also confirmed it will still pair with the car and will stream music while displaying data from the car so you don't lose anything. I ran into a snag driving into work though. It was like the agent crashed and didn't want to reconnect on either wifi or bouetooth for a while. When it did it started wildly displaying engine temps for example fluctuating between 80-100c. It's like it broke and got confused.
Really I'm thinking my pi is just broken but either way I'll try to get instructions for BT up today. More people testing will help us answer that. |
11-29-2018, 08:23 PM | #268 | |
///M SubDriver
1833
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
12-01-2018, 08:11 PM | #269 |
Rep 170
Android. I have noticed for some reason while bluetooth tethering I also cause the agent software to crash and then fail to ever start again on the pi. I'm not sure if this is exclusive to me. Apologies for not posting up the guide. Been sick and busy. Will work on it today.
12-02-2018, 07:55 AM | #270 |
///M SubDriver
1833
Rep 2,782
Ok, I am looking forward to see what you did. I did a very quick search on using BT with a headless Pi system like the OBD Agent and it initially looked more "involved" than tweaking with the WiFi settings as described earlier in this thread. I am surprised you are having trouble with Android and BT though. Usually Android is pretty good with stuff like that, and much better than iOS.
12-02-2018, 08:23 PM | #271 |
Rep 170
Okay here it is. Sorry it took so long but I decided to just make a new image and make you guys do as few steps as possible. I also spent some time troubleshooting and I am pretty sure my pi 3b is defective. Will be messing with it a little more just to make sure its not some detail I am missing but this worked perfectly today on my 3b+. I also found the app way more responsive with my 3b+ in the car and update rates seemed much quicker.
First off what you will need. My image (should work on pi 3b and 3b+) -UPDATED 4/18/2019-: https://mega.nz/#!W5YSiYSK!_fJ50g2CC...uRcp8HJyzOCjWU balenaEtcher to flash the zip: https://www.balena.io/etcher/ Putty to setup the BT pairing: https://www.chiark.greenend.org.uk/~...ty/latest.html Now for the steps. 1. Download and install balena etcher and use it to flash the image to the sd card. For those of you interested it is raspbian stretch lite. I left the standard pi user on there with password raspbian and created a bm3 user with password bootmod3. 2. Insert your SD card into the raspberry pi and power it up. Plug it into your computer's ethernet port where you would normally plug in your internet cable. 3. Open putty and connect to 169.254.0.2 When prompted enter 'bm3' for the username and 'bootmod3' for the password. 4. Find your android device's bluetooth address. This would be on your phone in setting somewhere. For me it was under settings->About phone->Status->Bluetooth Address It should be of the format Code:
AA:BB:CC:DD:EE:FF 5. Go back to your putty window and type Code:
nano /home/BTether/can.sh Code:
BT_MAC_ADDR=AA:BB:CC:DD:EE:FF Code:
AA:BB:CC:DD:EE:FF 6. Press 'ctrl + o' to save and hit enter when prompted for a filename. Then hit 'ctrl + x' to exit the text editor. 7. Now type: Code:
sudo bluetoothctl Code:
[NEW] Controller 11:AA:22:BB:33:CC bootmod3 [default] [bluetooth]# Code:
power on agent on discoverable on Code:
[NEW] Device AA:BB:CC:DD:EE:FF DEVICENAME Code:
trust AA:BB:CC:DD:EE:FF exit Code:
sudo reboot GUIDE FOR EXISTING INSTALLATION Okay here we go Just like above you will need putty. 1. Connect to 169.254.0.2 and when prompted enter bm3 for the username and bootmod3 for the password. It should log in. If it does not you will need to use whatever user is set up on your device and the associated password. This is the default so I assume it will be the same for you. Note that the agent will have to be connected to a hotspot or router with internet connectivity for this guide to work. 2. You will want to type Code:
sudo apt-get update sudo apt-get install python-dbus 3. Now type Code:
cd /home sudo mkdir BTether sudo chown bm3 BTether cd BTether Code:
curl -s -H "Accept:application/vnd.github.v3.raw" https://api.github.com/repos/WayneKeenan/RaspberryPi_BTPAN_AutoConnect/contents/bt-pan >> bt-pan curl -s -H "Accept:application/vnd.github.v3.raw" https://api.github.com/repos/WayneKeenan/RaspberryPi_BTPAN_AutoConnect/contents/check-and-connect-bt-pan.sh >> can.sh Code:
sudo chmod +x can.sh bt-pan Code:
sudo crontab -e Code:
@reboot /home/BTether/can.sh * * * * * /home/BTether/can.sh 5. You will now need to set up bnep0 (the bluetooth interface) to take an ip address from your phone via dhcp. Type Code:
sudo nano /etc/network/interfaces Code:
allow-hotplug bnep0 iface bnep0 inet dhcp Please post if you have any problems as I didn't really test this bottom guide. Thanks! Last edited by meltbox; 04-18-2019 at 07:11 PM.. |
12-02-2018, 08:24 PM | #272 |
Rep 170
Reserved for troubleshooting guide for BT.
Things to try if you have BT drops (try one at at time and then combinations): 1. Turn on BLE Code:
sudo hciconfig hci0 leadv 0 BUT FIRST CHECK ORIGINAL POLICY AND NOTE DOWN THE OUTPUT OF THIS COMMAND Code:
sudo hciconfig hci0 lp Code:
sudo hciconfig hci0 lp HOLD,SNIFF Code:
sudo hciconfig hci0 lp RSWITCH,SNIFF Note all these reset on reboot. I'm still working on that... More to come... Last edited by meltbox; 12-06-2018 at 10:17 PM.. |
12-02-2018, 10:11 PM | #273 |
///M SubDriver
1833
Rep 2,782
Great work! I would be interested in this as I would rather update my existing image than start with a new one, at least for my first try at this.... Any reason why the same process would not work with iOS? I know trying to get BT to work with iOS can be "challenging" at times when compared to Android.
12-02-2018, 10:16 PM | #274 | |
Rep 170
12-04-2018, 06:13 AM | #275 |
Rep 191
Lots of awesome info here. Great work on the bluetooth, may try that out soon. I just put together mine last night and flashed. Everything went smoothly and stg1 is an impressive bump for no mods.
With that being said, I seem to be having connection timeout of some sort. I had my dashboard up and was monitoring things on my first drive, when I noticed all parameters were frozen. The device was no longer connected to my hotspot. After checking/trying a few things, it was only resolved by unplugging the power to the rp and plugging back in. This continues about 3 more times in an hour. Then, I start receiving a message that OBD Detected - VIN unavailable. After looking into that, I followed PTF's instruction to disconnect the battery for 3 min and try again. This did indeed fix "VIN unavailable" but the connectivity timeout has continued. I've read through all 13 pages here, and can't seem to recall anything similar. This is on Android. (I may also just be an absolute dunce and if so, just point me in the right direction for the relevant info, lol) Last edited by BettyFkinCrocker; 12-04-2018 at 07:11 AM.. |
12-04-2018, 07:58 AM | #276 |
Rep 2,653
What's the benefit of BT tethering?
On a side note, I recently rebuilt my agent using the .41 ISO because I was getting an error with in app updating. When attempting an in app update I get prompted that my current version doesn't support it. Anyone else run into this? It's happening again with version .41.
12-04-2018, 09:58 AM | #277 | |
Rep 170
It may be a defective pi or something about the 3b. Not sure yet but I'm planning on trying to diagnose that too if I can. |
BettyFkinCrocker180.00 |
12-04-2018, 09:59 AM | #278 | |
Rep 170
12-04-2018, 01:07 PM | #279 | |
Rep 191
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
12-04-2018, 06:40 PM | #280 |
Rep 170
12-04-2018, 07:14 PM | #281 | |
///M SubDriver
1833
Rep 2,782
Regarding the update error you mentioned, I recently got it when trying to update my agent to ver 41. However, I figured it was due to low signal strength on my phone (only 1 bar at the time). I tried again (with better signal strength) and my agent updated remotely without issue.
12-05-2018, 05:48 AM | #282 |
Rep 191
Well, looks like the problem resolved itself. I've since had my dashboard up for two hour long drives with no interruptions at all. Must have just been a fluke. All is working great.
IG: @derringerF10
12-05-2018, 01:17 PM | #283 |
Rep 2,653
Stupid question... Is there a way to tether the agent to the iPhone by JUST using USB? Right now when I turn on personal hotspot, the agent automatically connects to SSID "bootmod3" via WiFi.
12-05-2018, 01:26 PM | #284 |
///M SubDriver
1833
Rep 2,782
So I tried the BT procedure above using my existing image vice burning a new one... Good news is that it appears to have worked. I was able to update my Pi and turn on BT. Bad news is that my iPhone did not detect the Pi. To ensure the Pi was working properly, I used an old Android phone I had lying around and that phone was able to see the Pi and connect to it via BT. Unfortunately, I am not surprised that the iPhone did not see the Pi as Apple is very strict about which types of devices can connect via BT. The only way my iPhone will be able to detect/connect the Pi via BT is if I jailbreak it, which I don't feel like doing right now...
What is worse is that I can't even use my old Android phone if I wanted to since the BM3 app requires Android 4.4, but my old phone can only go as high as 4.1 . Oh well, at least my Pi is now configured to use BT...
meltbox43.00 |
12-05-2018, 01:57 PM | #285 | |
Rep 2,653
12-05-2018, 04:23 PM | #286 |
///M SubDriver
1833
Rep 2,782
Yes, there is. See my post earlier in this thread where I disabled WiFi on my agent for that very reason. That way when you turn on your hotspot, it will only accept the USB cable. Or you could just change the wifi hotspot name on your phone which in theory should work too since the agent won't be able to connect to your iPhone without the correct SSID and password.
