BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bulb Replacement DIY
      08-02-2012, 03:10 PM   #1
G3raldT
Drives: 2012 328i Jet Black / Black
can anyone show me how to change the bulbs (preferably with pictures) im planning to replace my high/low beams with HIDs. Ive read the manual but it still looks like rocket science to me (noob). Thank you guys soo much!! This forum has helped me tremendously with my bimmer love!!
      08-09-2012, 03:45 PM   #2
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
Drives: 13' 328 MSPORT
Not 100% yet, but for the fogs im thinking you can go thru the front fender just like you would do if you were replacing your reflector....
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      08-18-2012, 02:34 PM   #3
SmoothSteeringHopeful
SmoothSteeringHopeful's Avatar
Drives: 2012 BMW 328i
I second this question. I have some new low beam bulbs I want to use! I've looked at the manual and pulled the covers off but cant get the damn bulb out!
Taking one more shot at it in a bit
      08-19-2012, 10:39 AM   #4
I tried to push the clamp on the bottom right... it just bent
      09-08-2012, 05:22 PM   #5
Ecmiyake
Drives: 2012 320i
I've found the easiest way is to put the connector back in the bulb, will be much easier to hold onto the connector than the two sharp legs of the bulb. Try to move and tilt the bulb out at the bottom.
      04-10-2013, 07:55 AM   #6
SanG
SanG's Avatar
Drives: 2013 F30 316d Alpine White
Hi,
would you please explain how you pulled the covers off?
Thanks.
      02-25-2014, 01:46 PM   #7
Hypnotic
Drives: 328i M Sport Saloon Auto
They twist off, and you can go through the inspection panel in the wheel arch liner for the low beam bulb.
Good luck with it ;-)
Cheers.
      02-25-2014, 11:52 PM   #8
JBH320
Australia
Drives: 320D
Did you ever get the HID's fitted.
I have asked about fitting them to my F30 and I was told they would not work with the existing light components.
O do night driving in the country and the halogen bulbs are practically useless.
