02-27-2021, 03:42 PM | #45 | |
Rep 1,453
03-08-2021, 04:28 PM | #46 |
Rep 2,048
Just ordered one of these for my Impreza. The original 4 spoke ideally needs restored but it has a groove worn in it from climbing callouses back when it was my daily. I replaced it with a decent later 3 spoke wheel but the leather quality definitely went downhill in the intervening years so it's not as pleasant to use. Hopefully this will resolve the difference until I can get the original wheel properly restored. That it makes the wheel a bit thicker is no bad thing. For $25 you can't go wrong!
03-13-2021, 05:57 AM | #47 |
Rep 52
Landed. First thoughts. Bit thick. Not sure how it will mould without creases. Not in any way a suede finish. But hey ho less than £40. I can at least practice fitting.
Update once fitted. |
03-13-2021, 07:22 AM | #48 |
Rep 2,048
03-13-2021, 07:43 AM | #49 |
Rep 52
12 days. Not bad.
03-13-2021, 12:33 PM | #50 |
Rep 52
Took a little time but I got there.
No creases which is good. Wasn't able to tuck the cover in beneath the spoke at 6 o clock but it looks fine as they have finished the edge nicely. I think that if the join was cut out then you could tuck it in. As it is it is too bulky. |
03-13-2021, 06:23 PM | #52 |
Rep 52
Cheers. I'll oblige in the daylight. If it hadn't taken me all day to get the job done I might have been brave enough to cut the section out. Perhaps another look tomorrow.
03-14-2021, 04:41 AM | #53 |
Rep 52
Better daylight pics. You can see how the bottom section sits. I'd like to be satisfied with it but I'm going to have to tackle it at some point I think.
I removed all the wheel trim front and back but kept the buttons loosely attached. Be careful when replacing the buttons over the new thicker cover, as the fit is tight. Squeeze the trim pats together as much as you can. The screw only goes into plastic so you don't want to put too much tension on it as you tighten. One of mine has pulled together fine but the screw now just turns. If it pulls out, I'm going to have to fill the hole with Araldite type resin. I used the tape supplied as it seemed fine. I didn't place it in rings around the wheel as in some videos. I placed it in short lengths with gaps around the rear edge of the new cover. I also had a few 1cm pieces cut to strategically place as I went around. |
03-14-2021, 11:39 AM | #54 |
Rep 2,048
Is it not possible to remove the centre trim and then refit back over the cover? I've been contemplating fitting an M-car's leather coated central trim as the plastic M-Sport item is really hard and cheap feeling. Just a thought that it might help finish the edge off better. It looks good though, pretty impressive for £40. The one for the Impreza was even cheaper so we'll see what it looks like.
03-14-2021, 11:52 AM | #55 | |
Rep 52
Open to suggestions if anyone has made this work. One YouTube video refers to cutting the join out of the new cover. |
03-14-2021, 12:45 PM | #56 | |
Rep 2,048
03-14-2021, 01:34 PM | #57 | ||
Rep 52
Although I'll probably now end up faffing with it again tomorrow. This is the video with the reference to cutting the section out. Skip to 23:24 |
03-15-2021, 06:35 AM | #59 |
Rep 2,048
That looks absolutely spot on, good effort!
Squirtydog16.50 |
03-15-2021, 11:13 AM | #60 |
Rep 52
05-06-2021, 03:12 AM | #61 |
Rep 128
I would just use royals, they did mine and the quality and the service was really good.
I went for full black alcantara with light grey stitching to match the mineral mineral grey. Black 12 o'clock stripe (I've also retro fitted M4 paddles)
440i GC - Previous cars, I30n Performance, MKV GTi, E46 325i Touring, E46 320d Touring, E91 M Sport Plus Edition,
06-21-2021, 07:02 AM | #62 | |
Rep 594
I'm thinking about having my wheel done, but I'm quite the novice and wondered how easy it was to remove all of the old buttons etc from the old wheel and move them to the new one? Cheers |
06-21-2021, 07:12 AM | #63 |
Rep 1,303
Squirtydog16.50 |
11-29-2021, 12:53 PM | #64 |
Rep 52
Switched to proper Alcantara. Again from MEWANT.
Perfect fit. Much easier second time round. Thinner material so it fits beneath the bottom spoke without trimming (perhaps in part cos the thicker one has been pressed in there too). The 'suede' one didn't feel nice on cold mornings with cold hands. It has been through the wash though and is available for the price of postage if anyone is interested. Seems to have washed up well. I have spare grey stitching and some tape. |
winther11819.50 |
