11-30-2021, 04:39 PM | #1 |
Rep 383
Anyone installed the MAD 5" Stepped Intercooler
The title says all, just ordered it and was wondering if anyone has anything to say about it and if its better over stock, currently have a bm3 stage 2 ACN tune and want something that can keep the car colder
11-30-2021, 04:52 PM | #2 |
Rep 706
better than stock? of course, 100% better, but the consensus here said you should get the largest possible as there won't be any lag. if you have not install it, get the 6.5" competition, or better yet, get the race version
11-30-2021, 04:56 PM | #3 |
Rep 383
already ordered but I'm going to do some logs on it anyways and see how it performs over stock but it does have a nice density core so I think it should at least be enough.
11-30-2021, 05:50 PM | #4 | |
Rep 706
However if you are comparing with other brand fmic in similar size capacity or bigger, then log is required to properly compare them. If you already have stage 2 tune on the car, then you should stop driving the car until you get the fmic installed. To prevent overheating and blowing your engine. Flash back to stock if you are driving it daily, btw with stage 2, you need to change the downpipe and charge pipe at the minimum. Have you done that? |
11-30-2021, 06:30 PM | #5 | |
Rep 5,393
11-30-2021, 06:31 PM | #6 | ||
Rep 383
11-30-2021, 06:47 PM | #7 | |
Rep 5,393
We are a small group of opinionated guys arguing/discussing a subject, turbo lag, that can't easily be quantitatively evaluated. I still stand by my two points: 1) Physics says that more volume in an Intercooler means more turbo lag is more likely. 2) I've actually observed friends with same car and tune, but with large Intercoolers, drive my car and say it's more responsive (less lag) than theirs. I think we should all have some beers! 😀 |
alohasurftoad3076.50 anielsen71558.50 |
11-30-2021, 07:17 PM | #8 |
Rep 1,058
I still say the 5" intercooler is best for stock turbo and OTS tunes. With the 6.5 there was a small amount of lag to pressurize the intercooler (ATM/CSF) but going custom tune fixed the lag completely
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block |
11-30-2021, 09:01 PM | #9 |
Rep 5,393
11-30-2021, 09:42 PM | #10 | |
Rep 383
11-30-2021, 10:20 PM | #11 |
Rep 706
12-01-2021, 07:14 AM | #12 | |
Rep 5,393
It actually made for a pretty good scientific experiment because at the time our engine mods, tune, etc were all identical except for our intercooler upgrades. Theirs were much larger. We weren't trying to do an experiment. It was an observation that we all had about mine seeming more responsive, so we tried to figure out what may have caused it. Now with my fueling mods my engine power is higher so my upgraded intercooler no longer has the capacity to cool fast enough. I'm concerned about just automatically choosing a giant intercooler and potentially adding turbo lag. So I'm trying to see if a mid-size intercooler will cool enough for my current engine power. It just makes sense to me that if I'm trying to cool an engine in the 450-500whp range, that a giant intercooler that can handle 600-700whp may be overkill, and could potentially cause increased turbo lag. Hey, my logic makes sense to me. I could be wrong but there isn't an easy way to design a quantitative experiment. I figure that if I install a midsize intercooler and it handles IATs to my satisfaction, that I'm probably minimizing turbo lag too. If it doesn't handle IATs to my liking then I won't have much choice but to install a large intercooler. We'll see. This is what makes modding fun! 😀 |
12-01-2021, 07:39 AM | #13 | |
Rep 1,058
12-01-2021, 07:53 AM | #14 | |
Rep 706
what fueling mods do you have now? thanks.
12-01-2021, 08:00 AM | #15 | ||
Rep 5,393
The charge intake system has three main components that are subject to modding: 1) The Turbo to Intercooler (TIC) Pipe, also called the Boost Pipe. 2) The Front Mounted Air to Air Intercooler (FMIC) 3) Charge Pipe from the intercooler to the throttle body on the engine. Aftermarket TIC and CP's are roughly the same size and shape as their stock parts. In fact if they are different at all they tend to be slightly larger. More volume would contribute negatively to turbo lag. My Evolution Racewerks charge pipe is noticeably larger. The smooth straight walls are seen as an advantage to reduce air turbulence so that might help flow while the extra volume to fill could be seen as contributing to lag when trying to build boost. The TIC pipe is much shorter than the CP so an aftermarket TIC would have less impact on lag. So the aftermarket Intercooler has by far the biggest potential impact on lag. There are several factors but if you just look at volume for example. The stock intercooler has a core volume of about 450 cubic inches. A big race intercooler could be 1,450 cubic inches, over 200% larger. So of the three components upgrading one or both of the two pipes isn't likely to effect lag. It's the intercooler that does the cooling and would have the most effect on turbo lag. |
12-01-2021, 08:15 AM | #16 | ||
Rep 5,393
The pedal programming can get sophisticated. So driving slowly through a parking lot provides a less responsive pedal while driving at 50mph has a more responsive pedal. Sport Mode would have a more responsive pedal than Comfort Mode. Engine tuners whether they are custom or OTS like Bootmod3 or MHD usually tune the gas pedal for specific response parameters. So what you are interpreting as less engine turbo lag is probably the engine tune also having a different gas pedal response profile. |
12-01-2021, 08:23 AM | #17 | ||
Rep 5,393
Dorch Stage2 HPFP Precision Raceworks Stage 2.5 v2 LPFP Precision Raceworks Fuel Line Kit Zeitronix CANBus ethanol sensor with dashboard gauge Bootmod3 FlexFuel MultiMap tune |
12-01-2021, 08:24 AM | #18 | |||
Rep 1,058
12-01-2021, 08:31 AM | #19 | ||||
Rep 5,393
12-01-2021, 10:29 AM | #20 | |
Rep 383
12-02-2021, 08:36 AM | #21 |
Rep 190,750
Let us know how it goes
12-02-2021, 11:39 AM | #22 | |
Noob
Rep 3
