12-01-2021, 05:10 AM | #1 |
Rep 35
2 sets of wheels and 2 sets of TPMS
After a bit of Googling I cant seem to find a definite answer on this.
I am putting winter rims on this week, which came with TPMS sensors. The garage I use checked they can be communicated with before putting tires on to rims. Fingers crossed they work on the car. I now have 2 sets of TPMS for winter and summer rims. A couple of questions, when I swap the wheels do we need to "tell" the car? Or once the sensors are set up does the car remember? Can the car remember more than 1 set of sensors? Do I need to do anything to the wheels that are off the car? Do they have some kind of memory or battery back up? Car is a 2015 LCI F30 if this makes a difference. Any info greatly received Cheers |
12-01-2021, 05:35 AM | #2 |
Rep 1,992
Drives: F30 335d
There's no need for the car to 'remember' a set of TPMS sensors. Just re-initialise the TPMS in the iDrive when you swap the wheels over. It'll then use the sensors that are in the wheels on the car.
if I've helped - an Appreciate would be, er, very appreciated!
jaf6526.00 |
12-02-2021, 03:07 AM | #5 |
Rep 35
A nice simple reset and all went well up until 49% of the reset was reached. Then it stops and throws up a fault. Tried a few times and each gets the same results.
So I guess one is faulty even though tested that they communicated before fitting. Any ideas where to go next? Thanks |
12-02-2021, 05:40 AM | #6 | |
Rep 198
12-02-2021, 07:06 PM | #8 |
Rep 117
I know it's a ball ache but could you not put 3 of your wheels back on and keep swapping the other one over till you get the error. You know your wheels are good so by keeping 3 of them on and keep swapping the 4 with your new set you should get a error sooner or later.
