03-01-2016, 07:15 AM | #10055 |
Rep 105
My INPA doesn't seem to have F-Series in it. Am I using a old version maybe?
Also does someone have a Linkt for all the needed Software with current versions? I want to upgrade my current setup. |
03-01-2016, 10:49 AM | #10056 |
Rep 40,861
PM sent.
03-02-2016, 12:51 AM | #10057 |
Rep 4
Me too
Hey Shawn, just got my pre-owned 2012 328i and would like to enable some options. Would you send me the links for the software so i can get started coding? Thanks
03-02-2016, 05:48 AM | #10058 |
Rep 40,861
PM sent.
03-02-2016, 08:13 AM | #10060 |
Rep 40,861
Sorry, but there I have no Guide for NBT retrofit, although there are a few threads here and on Bimmerfest discussing it in great detail.
03-02-2016, 03:30 PM | #10061 |
Master Driver
422
Rep 752
I am doing ED soon, for an M3. Is it possible to remove the speed limiter if under 10 hours of operation? That's what I have been reading, but anted to confirm if this is possible.
If so, Which guide should I look at ? Thanks Furball |
03-02-2016, 06:01 PM | #10062 | |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
03-03-2016, 12:23 AM | #10063 |
Rep 380
What are the different startup type under HU_NBT 3001?
STARTUP_TYPE: animation, black, splash, pwf_welcome I coded MY2016 435 F36 with "animation" and emblem "variant_01" but of course I only saw it once during coding restart. Should I switch to splash or pwf_welcome instead to show the ///M more often? I confirm that coding for the CLOSE trunk HKFM 3010 with button and key fob works on the F36 with power trunk. |
03-03-2016, 09:28 AM | #10064 |
Rep 1,502
Drives: M4 CP SSII/SS
Hi Shawn,
A laptop HDD failure has meant I've lost my Esys. Can you re-send me the link suitable for June 2013 build F30. Many thanks, Jon
Current: F82 CP SS/SS
03-03-2016, 09:48 AM | #10065 |
Rep 40,861
PM sent.
03-03-2016, 12:11 PM | #10066 |
Rep 902
Looking for latest DB links, thanks!
03-03-2016, 12:12 PM | #10067 |
Rep 40,861
03-04-2016, 01:53 AM | #10068 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
Auto PDC on Pre-LCI - Anyone get it to work?
Anyone manage to get Auto PDC to work on Pre-LCI F30s equipped with PMA - Parking Maneuver Assistant?
I've changed the coding on my Pre-LCI MY15 w/ PMA to enable the checkbox for Auto PDC under NBT, however I'm dumbfounded trying to figure out what else I need to enable - potentially under PMA2. I know the MY16 F22 with PMA (2 sensors) has Auto PDC, but what is the limitation on a Pre-LCI with PMA? |
03-05-2016, 09:23 AM | #10069 |
Rep 86
Hello Shawn,
Due to my throttle slow response when 20km/h: takes 3-4secs, so send to BMW update the software and firmware. But now i couldn't use my E sys & Pzd data, showed: cafd_000000794-015_041_203, and other modules also. I could read and edit FDL. I would like to request the latest e sys & Pzd data please. Thank you so much |
03-05-2016, 10:17 AM | #10070 |
Rep 93
Hi all.
Already I retrofitted NBT TO my f30. Also I get some help from forum users to work properly. But now I have problem with coding my car. I get esys 3.27.1 and PsdZData v.58.0 from shawnsheridan. Esys working Ok. But codes are not saved at all in my car. l read FA , then read svt - reading coding data - then changing chosen parameters. Then saving And coding. Alll without errors. But none of codes are applied in my car. Any advice guys? |
03-05-2016, 01:28 PM | #10071 | |
Rep 40,861
03-05-2016, 01:30 PM | #10072 | |
Rep 40,861
03-05-2016, 04:55 PM | #10074 |
Rep 40,861
03-06-2016, 04:53 AM | #10075 | ||
Rep 93
I still can't activate "DRL on/off " on display. code is changed but not appear on the screen ? |
03-07-2016, 07:51 AM | #10076 |
Rep 26
Hi Shaun,
Sorry im now to this i have order a cable but software that come with it seems to be corrupt on some of the part files. could i please get a link to download please thanks sunny |
