BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMW Shops in the Hudson Valley NY?
      01-21-2019, 11:50 AM   #1
Drlu23
Drlu23's Avatar
Drives: X1 x28i; 328iX; X5 35i
Does anyone know of reputable BMW shops in the Hudson Valley NY area (Poughkeepsie, Fishkill, Kingston).
Thanks,
Lu
      01-21-2019, 03:42 PM   #2
smallba
smallba's Avatar
Drives: 2013 328i xDrive
What are you looking to be done?
      01-21-2019, 06:21 PM   #3
Drlu23
Drlu23's Avatar
The car is skipping a lot under medium and hard acceleration and I believe it has to do with fuel delivery. I changed spark plugs and gapped them correctly, changed intercooler and piping is tight. I need to clean the MAF as a third option but so far no ECL lights are on. I checked bimmer code and saw the MAF sensor notification on there. I just want a second opinion if I am still having an issue after I clean the MAF.
      02-09-2019, 05:51 AM   #4
Drlu23
Drlu23's Avatar
Bump
      02-12-2019, 05:37 PM   #5
sq86
sq86's Avatar
Drives: 2013 328i E92 LMB
Bavarian Rocket Science is supposed to be good but they're further north in Albany.
Based on your description it could be coils or maybe carbon buildup too, depending on your mileage. I hope it works out!
BMW CCA Member# 481791
Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown
Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black
      02-19-2019, 06:08 AM   #6
smallba
smallba's Avatar
Sorry Didn't get back to you, you could reach out to Lomotion in poughkeepsie, JJ has alot of experience with European cars, any thing else with be Jersey (AUTOcouture Motoring)
      02-20-2019, 07:00 AM   #7
Drlu23
Drlu23's Avatar
Thanks. I'll reach out to Lomotion.
      02-20-2019, 07:05 AM   #8
pjkbrit
pjkbrit's Avatar
128
Drives: 2018 340i 6MT ZHP
How many miles? The coils die after so many heat cycles.
      02-20-2019, 07:09 AM   #9
Drlu23
Drlu23's Avatar
75K. I've gone through the coils and overall the system is working well. I took off the tune and have noticed no hesitations now during full throttle acceleration. I do believe either I have a fuel issue or boost leak, or maybe something with the tune (Jb Stage 1)
      02-20-2019, 07:33 AM   #10
Drlu23
Drlu23's Avatar
I'm also looking to clean out the intake valves; possible carbon buildup causing the hesitations. If this doesn't work, at least I'll have cleaner intake valves!
      02-21-2019, 03:12 PM   #11
pjkbrit
pjkbrit's Avatar
128
Ah.... could be the JB tune then
      02-21-2019, 07:39 PM   #12
Drlu23
Drlu23's Avatar
Have you guys heard of the tune acting this way? I would have thought the tune would only apply a single code set to the parameters of the car.... wasn't sure if you guys are aware of a tune not functioning as it should later during it's life. Any feedback would be great on this topic.
      02-23-2019, 06:38 PM   #13
smallba
smallba's Avatar
Sounds like your issues are pointing towards JB stage 1 (I'm assuming) or is it a JB4
      02-24-2019, 10:33 AM   #14
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Absolutely, it's likely that it is the tune if the issue stops when the tune is removed. If it never did this before however, even with the tune, then that points to a mechanical problem, it's either not getting spark or fuel and that's being exacerbated with the tune. The tune the will degrade over time though, if that's what you're asking.
      02-24-2019, 11:06 AM   #15
Drlu23
Drlu23's Avatar
I am going to clean out the intake runners to see if there is extensive carbon build up. Again, I am at 75K so why not anyway. But I am thinking it is a fuel issue, I just don't want to do the fuel injectors; 1 haven't done that before and 2 I can do it but it's time and also a lot of things to do too like also changing the seals on the filter which makes this job not so much fun to do right now I'm the winter.
