07-26-2018, 09:52 PM | #1 |
Rep 123
F30 brake reset impossible
Hey guys i know there already a lot of threads about this, but i still cant find the answer. So i changed all the pads on my car (2012 328i F30) and left my front sensor because it was still good, the rear sensor was tripped so i replaced it, and now it says that "Brake reset impossible" and this is only for rear pads, front reset worked just fine, and i tried unplugging it and plugging back in and all that even tried looping it with a wire just to be able to reset it, no luck, any thoughts on this? Or maybe someone that had the same issue and found a solution for it.
Current: 2007 335i
Past: F30 M3 clone/ IS-F/ E46 M3/ Gen Coupe/ MS6 |
07-26-2018, 11:22 PM | #2 | |
Curmudgeon and Pedant
690
Rep 3,489
Because of the fact that the first wire is not intact, no reset is possible. Replace the front wear sensor. |
upsidedownfunnel1996.00 |
07-27-2018, 07:31 AM | #3 |
Rep 16,065
What are you using for a diagnostic tool? A good one, like the Foxwell NT510, can tell you if there are any active codes and clear any old codes, which may be necessary before you can do a reset. I had the rear warning trip and it wouldn't reset until I changed the sensor, but as I recall after changing the sensor I cleared all the codes before I did the reset.
08-07-2018, 03:24 PM | #4 | |
Rep 123
For diagnostic i used my friends i forgot what brand it was, but it can do a lot of things, so we went a checked my brake system and it had a code ---480A14 Brake pad wear sensor: Rear axle, plausibility--- So this was with an aftermarket sensor from ebay, then i went to the dealer and bought a new one OEM, replaced it, and still same thing and this code, everytime i erase it it comes back on like same second, so even erasing through diagnostic tool is not helping, any one have any ideas?
Current: 2007 335i
08-07-2018, 03:28 PM | #5 |
Rep 123
here is a photo of the code that i have now, with Brand NEW pads and Brand NEW OEM sensor
Current: 2007 335i
08-12-2018, 11:44 PM | #8 | |
Rep 123
Looking to buy a good OBD scanner and thinking of Foxwell, not sure which model yet |
08-13-2018, 06:56 AM | #9 |
Rep 16,065
Yes. It will also tell you why a reset isn't possible when that happens.
http://f30.bimmerpost.com/forums/sho...2#post23288222 |
08-15-2018, 03:52 PM | #10 | |
Rep 123
Current: 2007 335i
08-15-2018, 04:03 PM | #11 |
Rep 2,499
This might help you:
https://garagetalkmsge.wordpress.com...light-problem/ I'm assuming the Foxwell is able to reset the CBS? |
08-15-2018, 04:54 PM | #12 |
Rep 123
Yeah i can reset it, i saw the link that you gave me before, it looks like he does some sort of correction with that special tool, not just reset, so at this point im lost
08-15-2018, 04:55 PM | #13 |
Rep 123
08-15-2018, 08:41 PM | #15 |
Rep 16,065
The sensor plugs onto the pad on one end, the other plugs into a connector that's hanging from a clip that's attached to the chassis. I suggested that because when I changed my pads and left the original sensor in place I couldn't clear the codes. I had a new sensor, so I swapped it and then the codes cleared. I didn't bother to examine the old sensor to see what it was about it that the car could tell that it hadn't been replaced, but I figured that maybe disconnecting it from the chassis connector triggered something in the control module. It could even be that the old sensor would work if it's disconnect to trigger the module and then reconnected. If I didn't have a new sensor I'd have dug deeper and figured out how to reuse the old one, but I had the new sensor.
08-15-2018, 11:27 PM | #16 |
Rep 123
sensor is brand new from BMW dealer
Current: 2007 335i
08-15-2018, 11:30 PM | #17 | |
Rep 123
Current: 2007 335i
08-16-2018, 05:42 AM | #18 |
Rep 878
Is there a way to test the sensor, might be duff?
08-16-2018, 07:24 AM | #20 |
Rep 878
I thought the sensor was simply 2 switches, so 3 wires which when it starts to wear simply breaks the first followed by more wear and then the second.
If what I’ve said above isn’t ballony then there should be continuity between the contacts. |
08-16-2018, 07:53 AM | #21 |
Rep 16,065
Some searching turned up this:
https://www.moderntiredealer.com/art...warning-lights And this: And this: https://wiki.bentleypublishers.com/d...W+5+Series+E60 You should be able to test the sensor with a DMM, measuring the resistance between the two pins on the chassis connector plug end. It should be at most a few ohms. A high reading or an open circuit would indicate a bad sensor. |
ksc14140.00 |
08-16-2018, 08:18 AM | #22 |
Rep 123
Yeah i thought it could be a bad sensor so i went back to the dealer and exchanged it with another new one, still same thing
Current: 2007 335i
