BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Depo headlights high beam bulb access
      08-07-2018, 12:19 PM   #1
Jackfrost822
Jackfrost822
Scotland
Drives: BMW F30
F30 Depo lights arrived, look great. Bulb change access for low beam and turn is through panel in wheel arch as expected. However no high beam bulb access on top as OEM. The H7 high beam access is on the inner side of each unit. To me it looks like there would be no room for a bulb change without unit removal. UK distributor says access via wheelarch, but I'm not so sure. Anyone any experience? Thanks
      08-10-2018, 01:48 AM   #2
Craven_01
Drives: 2013 F30
Only way is to uninstall the lights. The access panel is on the side of the headlights closest to the radiator.
      08-10-2018, 04:08 AM   #3
Jackfrost822
Jackfrost822
Scotland
Drives: BMW F30
Thank you. Newbie first post. Thought no one would reply!
      08-10-2018, 02:25 PM   #4
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Definitely install new bulbs or HID kit before installing the headlights on the car to make your life easier
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
      10-14-2018, 12:36 PM   #5
deleted_user
Drives: F30
That moment idrive trows a high beam failure... went on google but no luck. Yes the cover is indeed on the side of the unit and I have no clue in getting there without removing the headlight... I am sure there must be a way.....!
      02-13-2021, 12:55 PM   #6
bamafrog
Drives: 2013 BMW f30 328i
Has anyone actually replaced the high beam bulbs? I tried today and even with the headlight removed, I couldn't remove the bulb.
      03-08-2021, 04:16 AM   #7
Spencer786
Spencer786's Avatar
Drives: BMW 320D ED
I'm pretty sure it's a bumper off job to replace the high beam bulbs with F30 Depos -as is the same for OEM Xenon high beam bulb change (but don't quote me on the latter).
I chose long life halogen beams but will probably scour the latest (and possibly MOT legal??) longer life LED setup if/when they blow.
      05-06-2021, 03:33 AM   #8
DarkF30
DarkF30's Avatar
54
Drives: F30 328i
Not sure if this is a dumb question, but would I not have to worry changing the high beam bulb if I rarely ever use the high beam? So it won't the bulb won't die?
