08-11-2018, 03:40 PM | #1 |
Rep 1,721
Remap Results
Hey Guys
I had my car remapped @ Mulgari a while ago, I've run it for about 2000 miles now, car feels wonderful, very smooth and torquey, surge of power is like a thunderbolt, can take on most cars on the road with ease (although a Golf R really impressed in a short duel, I believe these cars can run 400+bhp with just a remap ? amazing if true) A couple of observations - It takes a couple of ticks to get moving ? probably need a sprint booster ? - Suspension is still the limiting factor, the lack of sharpness, the wallowy feel at roundabouts is driving me a bit mad, a chat to Lorcan once I am back from Hols Re: Sports supension, should hopefully improve things.... - The XDrive really shines, I've had no tyre squeels nor brown pant moments at all, could feel the back end give away on my 335i, but car feels pretty solid with the xDrive, it's great news the m340i gets the xDrive, Appreciate it divides opinion, but I feel it's great Lastly, drove up to Surrey rolling road today to put it on the rollers, it made a very healthy 384 bhp but very high torque ? Should I be worried guys ? Mulgari offer Engine/Drive train warranty on their remaps for life, assume it's going to be ok ? They are a professional outfit, i could get them to dial down the map a bit ? Appreciate the advice Cheers Rudz
ICE
Fronts: Morel Hybrid Ovation II 4, Rears: DLS R4, Center: Focal 100CA, Subs: Earthquake SWS8, JL 10W7, Amps: Audison LRX 6.9, Audison LRX 2.9, JL Slash 500/1 V2, DSP: JBL MS8 |
08-11-2018, 04:38 PM | #2 |
Rep 2,152
759nm i wouldnt worry
nice results
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
08-12-2018, 12:14 AM | #3 |
King of the North (living in the east...)
1056
Rep 2,154
I'm no expert, but the torque curve looks non optimal. Appears to fall off quite a bit. Power curve looks great however, linear.
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
08-12-2018, 06:27 AM | #4 |
Rep 1,721
cheers guys
Anyone else think the same about the torque curve ? I am no expert either but the guys at Surrey Rolling road said the graphs were good and the car was happy as larry....
ICE
08-12-2018, 06:51 AM | #5 | |
Rep 3,967
Here's another 335d making similar power to yours, ...as you can see at various points on the rev range 2250rpm, 3250rpm, and most importantly still at 4750rpm your car makes roughly the same torque to this car. |
08-12-2018, 07:16 AM | #6 | ||
1056
Rep 2,154
08-12-2018, 07:25 AM | #7 |
Rep 3,967
The graph is misleading as the dimensions are slightly different, the OP's graph is taller and the other is wider making it look flatter, but apart from a little bump up at around 3500/3600rpm on the evolve tune torque curve the torque is similar throughout the rev range, and if you were to draw the OP's cars torque line on the evolve graph it would be very similar.
At the end of the day the OP's car makes roughly the same low down torque at 2250rpm and makes slightly more torque higher up at 4750rpm .. so what could be wrong with that? We haven't even discussed different dynos used! Cheers |
08-14-2018, 08:07 AM | #8 |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
mine running wagner and map at 409bhp...heres last RR i had, had no issues and drives smooth. the lower line is my previous map when i went to RR prior to IC and map update to suit.
08-14-2018, 12:51 PM | #9 | |
1056
Rep 2,154
Makes around 560 at 2250rpm, falling to 500 at only 3500rpm. A flat constant torque curve is felt as linear, acceleration. However, while many/most may prefer linear acceleration, many enthusiats revel in the powerband that is a result of having a peaky torque curve that only comes from petrol engines.
08-14-2018, 01:37 PM | #10 | |
Rep 3,967
Comparing both sets of torque at various points on the rev range .. 2250rpm - OP 560 Evolve 550 3250rpm - OP 515 Evolve 515 4000rpm - OP 480 Evolve 485 4750rpm - OP 420 Evolve 410 Nothing drastically different between them, the OP's is 10 higher at 2250 and 10 higher up at 4750 too, the evolve one is slightly stronger in the middle between 3500-4000rpm but overall the difference between them is very minimal, and we are comparing cars tested on 2 completely different dynos aswell. |
