08-13-2018, 03:25 AM | #1 |
Rep 506
Front tyre scrubbed off
Morning
Noticed the front tyre has scrubbed of the first 1/2" on drivers side, the rest of the tyre is all good, what do people reckon I should do? Cheers Virge
Incoming BG X3 M40i
08-13-2018, 03:49 AM | #3 |
Jeff
318
Rep 1,451
A full laser alignment is quite a good investment and is relatively cheap. I would go down this route - maybe you can correct things and still get full life out of the tyre.
08-13-2018, 04:11 AM | #4 |
Rep 4,935
Drives: 340i MPPSK
Had this on both my F30's and have twice had an alignment done. Unfortunately the numerous potholes on UK roads don't help.
Life is a state of mind |
08-13-2018, 04:13 AM | #5 |
yes....spelt with J's
55
Rep 963
It has to be a PROPER alignment too..............not necessarily BMW, but someone who knows how to use the Hunter/KDS machine and knows what to do with a BMW
i.e. weighing it down or measuring etc J |
08-13-2018, 04:24 AM | #6 |
Rep 506
Ok cheers, do people think that it is ok to get the alignment done and there should be no need for new tyres?
Incoming BG X3 M40i
08-13-2018, 04:43 AM | #7 |
Jeff
318
Rep 1,451
Ask the guys at the aligning place. Depends how bad it is and if it’s not legal.
on_the_virge285.50 |
08-13-2018, 05:03 AM | #8 |
Rep 8,495
Things to check/adjust/fix :
Tyre pressures. Even ride height : springs aren't broken ? Full 4-wheel laser alignment. Picture of the tyre wear would be useful.
08-13-2018, 05:22 AM | #9 |
Rep 784
Drives: 2018 F80 M3 CP YMB
That is very common if you are on runflats? Certainly get geometry checked but the cause may well be a combination of that and under inflation - runflats have very stiff walls so any under inflation will result in excessive wear on the edges as they are taking all the load - especially outside edges on the fronts. I usually found I needed to run at the full load recommended pressure to get even wear across the tyre. Having said that I lived in Milton Keynes (the land of high speed roundabouts) for a while and my tyres often suffered from that no matter what I did and often looked like I'd been on a few track days... As long as the tread on the 2/3rds remaining is legal and you are not getting near to the canvas then you are fine legally but depending on the tread depth on the remainder you are probably as well to consider changing it as your braking efficiency will be compromised in the wet.
08-13-2018, 05:45 AM | #10 | |
Rep 15,858
Many a BMW with tyre wear has alignment in spec', so ensure tyre pressures are high enough first, before jumping on the "alignment is necessary" advice from many a garage. |
08-13-2018, 07:18 AM | #11 | |
Rep 32,881
Especially on Bridgestone run flats as their sidewalls are very stiff! Set the tyres to close to the maximum load pressures on the door label. |
08-13-2018, 11:58 AM | #12 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
I got 30k + miles out of the Bridgestone RFT tyres that came with my f31. Even when I replaced them they were legal and tread wear was very even. I suspect you have alignment issues of the wear is very uneven.
08-13-2018, 12:08 PM | #13 |
Rep 1,696
My front off side tyre is like this on approx 1" of the outside edge. However still has at least 5mm on rest of tyre so it's legal.
I changed my other 3 earlier this year, when I put my summers back on. The rears were worn and the near side front had an egg in the sidewall. The off side front was the only one I could save, hence the reason it's like this. |
08-13-2018, 12:23 PM | #14 |
Rep 2,376
this used to be very common on the e8x cars, but not so much in my experience with the f30's.
Current - X3m Comp
Gone but not forgotten - F80 m3 Comp, F30 340i, F30 - 320i |
08-13-2018, 01:22 PM | #15 |
Rep 1,034
Was a lot worse on my E90, struggled to get 15k out of the fronts. It was so bad I used to rotate them to the back after 12k. The F30 is better but still wears the outside edge on corners. I go around corners like an old granny to stop it scrubbing the edges off. Anyone who isn't suffering this probably does a lot of motorway miles, it is town driving and roundabouts that kills them
08-13-2018, 03:29 PM | #16 |
Rep 506
There is loads of tyre left on it, just the outside 2cm.....pretty gutted to be honest as there is nothing really wrong with the rest of the front tyres....
Incoming BG X3 M40i
08-13-2018, 04:08 PM | #17 |
Rep 32,881
08-13-2018, 04:20 PM | #18 | |
Rep 506
Incoming BG X3 M40i
08-13-2018, 04:26 PM | #19 |
Rep 32,881
Definitely safe if there’s no bulges and it’s not down to the cords. As others have said it’s just the central 3/4 that have to be above 1.6mm depth:
08-14-2018, 07:25 AM | #20 |
Rep 1
Had exactly the same issue recently. After 15k both fronts have approx 4mm across most of tyre but outside edge on both down to about 1mm. As others have said, get alignment sorted, inflate to upper end of manufactures recommended pressure and then keep an eye for cord over coming months.
08-14-2018, 08:06 AM | #21 |
Rep 944
Is there visible tread on this ' first 1/2" '? If so, all good. If no tread visible then I believe the tyre would not be legal.
08-14-2018, 08:21 AM | #22 |
Rep 506
The tyre is like a slick on the edge so the tracking is massively out, got it booked in tomorrow for the tracking and then going to put new tyres on....going to Devon on holiday so got about 1000 miles to do with the family in so not taking any risks....
Incoming BG X3 M40i
