BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
      05-08-2020, 05:11 PM   #529
cesaroctavio_80
cesaroctavio_80's Avatar
Mexico
Drives: 3 Series F30
HELP
Hi guys
I need your help. Im extremely sad / worried because upgrade to 8.8 screen didn’t work. I bought from ebay a 626 used screen and tried to install it.
1. I plugged new screen and never turned on with or without FDL Coding. No signal message is not present. First question is it working or is it damaged?
2. Im attaching print screens of esys changes. What it surprises me is that i cant write new values, once I code and read again old values appear again. one thing that is strange for me is that my car has entrynav2 but as you can see when i open CAF file to edit in the top says “CAF (HU_NBT_EVO)
3. As i couldn’t make FDL Code and i doubt if new 8.8 screen is working decided to instal old one (assuming no changes in ECU were done)
4. When i plug the old 6.5 screen i got error message “no signal” i checked and read values and old ones with 6.5 are in the ECU
5.
Honestly i dont know what to do. Did i make something wrong with FDL Coding? is new 8.8 screen damaged?
Thank you guys i was happy to finally be able to upgrade screen but right now im sad
My car is a F30 2018 LCI
      05-08-2020, 06:13 PM   #530
cesaroctavio_80
Mexico
Update: otiginal 6,5 screen is working i don't know what happened but i let the car 30 min 1 hr and screen is working again.
So for new screen. Do you think is working? Or what am i doing wrong with fdl coding?
Tks
Update: Excellent mod it is working! i was messing up with fdl coding. If anybody needs any help please let me know.
Last edited by cesaroctavio_80; 05-10-2020 at 07:01 PM.. Reason: Update status screen working
      05-20-2020, 04:15 AM   #531
sstyle
Drives: X3MC F97
Guys, is it possible to use 6.5" display with NBT EVO? I rotated CID port 180 deg, coded 6.5" with 800x480 res but still no image (
      05-20-2020, 07:42 AM   #532
nitsuj17
Drives: F30 328ix
You probably need to change display_variante back to whatever it is for 6.5
Also if the 6.5 is apix1 and the nbt Evo unit is apix2 (older id4 are typically apix1 but not all) you would need a voltage adapter
Why would you want to use the smaller screen though?
      05-20-2020, 01:11 PM   #533
sstyle
Drives: X3MC F97
As you may know, display from entrynav1 is not compatible with entrynav2. So entrynav2 also apix2.
(I am waiting for Android touch screen, so it is temporary solution)
      05-24-2020, 08:30 AM   #534
Matt111
Drives: BMW F31
8.8" display resolution
Hi everyone,
I've got a late 2016 F31 with 6.5" business nav and I'm trying to upgrade it to 8.8". Yesterday I fitted an LCI screen from ebay model 65509387453. Then using Bimmercode on an iPhone with an ENET cable I successfully (I think) coded
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
When my system restarted I got this on the screen.
With DISPLAY_VARIANTE set to breites_display I've tried changing the DISPLAY_SIZE_RESOLUTION using Bimmercode to all these settings
6.5_800x480
8.8_1280x480
10.25_1280x480
10.25_1600x600
Regardless of what I set it to the display stays exactly the same.
Back in November in this thread jdoc999 and Spanielgita were having the same issue I think. I can't see any solution to it though.
I've not used ESYS before. Would changing DISPLAY_SIZE_RESOLUTION with ESYS work any different to using Bimmercode?
Could anyone help me please?
      05-24-2020, 09:33 AM   #535
WUKONS
WUKONS's Avatar
Drives: 2018 340i 6MT RWD
2018 BMW 340i  [0.00]
Guys with HU_ENTRYNAV2 need to change 3005 CID_DISPLAY_RES as well.
      05-24-2020, 01:14 PM   #536
Matt111
Drives: BMW F31
Thanks for your reply Wukons. I looked in 3005 APIX_CID and I can’t see anything like CID_DISPLAY_RES.
      05-28-2020, 02:16 PM   #537
nitsuj17
Drives: F30 328ix
Originally Posted by pongkin View Post
same here, help please thanks
to my knowledge there has not been a solution to this.
wasn't business only available on 6.5? without reading through every post again i don't know if that was a common issue between the half screen issue
*if* (again i don't know for sure) business nav was only for 6.5 and not 8.8 screens then its possible the assets are not available in the head unit to change resolution since the head unit was only meant for a 6.5 in cid
      06-17-2020, 02:27 PM   #538
AzzaF30
Drives: BMW G20 330I
Evening all
Another one with the 8.8 screen upgrade question.
Ive got a 67plate 3series with entrynav2, ive bought a screen 6822626 for the upgrade, torn the whole dash down fitted and got nothing but a blank screen.
As far as im aware i should be getting "no signal" at least?
i coded the display_brities (i think) with bimmercode but that made no difference.
can anyone confirm i have the correct screen? and that its hopefully just a coding issue?
Cheers
      06-17-2020, 02:30 PM   #539
nitsuj17
Drives: F30 328ix
Originally Posted by AzzaF30 View Post
Evening all
Cheers
what model year is your car? last 7 digits of vin to look up?
      06-17-2020, 02:34 PM   #540
AzzaF30
late 2017 (dec) A342223
cheers
      06-17-2020, 05:54 PM   #541
nitsuj17
Drives: F30 328ix
cheers
realoem says your car comes with the touchscreen CID on navigation models either 65508709338 or 65508709339.....but I believe 626 should work if coded correctly. Double check that everything is plugged in and that you coded it properly
Make sure to change resolution to 8.8 as well as breites display......that doesn't matter on entrynav but I think it does on entrynav2
      06-18-2020, 02:28 AM   #542
AzzaF30
After a lot of digging seems being entrynav2 i need to code something different to every other guide ive seen
CID_DISPLAY_SIZE = 8.8
CID_DISPLAY_RES = 1280x480
So tonight ill give that a go and report back, appreciate the help
      06-18-2020, 09:58 AM   #543
AzzaF30
The above works on entrynav2 with the 626 screen.. all in and cooking on gas!
      06-18-2020, 01:13 PM   #544
maxipin
Drives: BMW F21 LCI
Hello,
Could someone tell me which entrynav I have and which part should I look for?
Year 2017, last 7 digits of VIN: 5H90061
Would 626 work? It's 1 series, but the head unit should be the same.
Thank you in advance.
      06-18-2020, 04:43 PM   #545
nitsuj17
Drives: F30 328ix
Originally Posted by maxipin View Post
Hello,
do you have nbt Evo id4 or id5
      06-18-2020, 04:45 PM   #546
maxipin
Drives: BMW F21 LCI
I think it's ID6.
      06-18-2020, 05:24 PM   #547
nitsuj17
Drives: F30 328ix
I think it's ID6.
626 *should* work but you would probably want confirmation from someone who has a similar install
      06-21-2020, 05:28 PM   #548
Hassan096
Drives: bmw f30 2012
Hi all, i have a 6.5 inch CIC from 2012. I know it’s been said that 8.8 screen won’t work with it. But this YouTuber did it and his screen was stretched out and I know that can’t be coded out as the car is older version. My question is can someone with a 6.5 CIC 2012 year straight swap the screen to 8.8 without coding as the YouTuber states or will it just straight up say “no signal” and not work? YouTuber in question is thic f30.
Many thanks
      06-21-2020, 05:32 PM   #549
nitsuj17
Drives: F30 328ix
Many thanks
what would be the point of a stretched 8.8 screen? Better to stay with 6.5
      06-21-2020, 05:35 PM   #550
Hassan096
I recently had CarPlay retrofitted its an Andream unit and I think even if idrive is stretched out CarPlay may work properly with it. That is obviously if the screen decides to work at all even if idrive is stretched.
