05-06-2020, 09:20 AM | #45 | |
Rep 1,282
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
05-06-2020, 09:41 AM | #46 |
Rep 107
Your current tune wont be mapped for the higher boost in the upper RPM range. I would be careful and keep and eye on STFT's. Maybe do 1 log in 3'rd and post it for review before tooling around town and potentially leaning out/killing your engine.
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
oma3710194.50 |
05-06-2020, 10:00 AM | #47 | |
Rep 762
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
oma3710194.50 |
05-06-2020, 11:04 AM | #48 | |
Rep 107
At the end of the day I bet he'll run just fine and his fuel maps are probably already set aggressively rich in the areas in question, as this is responsible thing to do as a tuner. That being said you don't want to be driving around with 10:1 AFR unknowingly, or worse leaning out. Just recommending he be smart about it.
ronanz1819.50 |
05-06-2020, 01:32 PM | #49 | ||
Rep 1,282
05-06-2020, 01:41 PM | #50 |
Rep 7,602
You might be able to tell from the logs. The load based tunes usually have actual load closely following target load (just a little bit below it). The boost based tunes usually have a super high load target, actual load is nowhere close. And in the latter case the target boost is usually completely flat (like BM3)
05-06-2020, 01:55 PM | #51 | |
Rep 1,282
https://www.bootmod3.net/log?id=5e56...0b431dacbb7d7d https://www.bootmod3.net/log?id=5e56...0b431dacbb7d77
05-06-2020, 02:28 PM | #52 |
Rep 7,602
Links don't work, i think you copied them with the "..." truncation to the original link.
05-06-2020, 02:32 PM | #53 |
Rep 1,282
https://www.bootmod3.net/log?id=5e56...0b431dacbb7d80
05-06-2020, 02:39 PM | #54 | |
Rep 7,602
Here is a MHD log for comparison: https://datazap.me/u/thejeremyman9/4...&data=16-17-25 And a log on completely stock car/tune, which should be load based: https://datazap.me/u/thejeremyman9/s...&data=12-13-19 Do same comparison of actual vs. req. |
05-06-2020, 02:43 PM | #55 | ||
Rep 1,282
05-06-2020, 04:33 PM | #56 |
Rep 7,602
I don't feel comfortable telling you one way or the other, i am just trying to provide my insight. I would echo what ///M248 said above; proceed with caution and be smart about it. I would drive the car around carefully for a little bit, then do some logs. Maybe even a partial throttle log first, take a look, then work you way up to a full WOT log. Maybe even log a lower gear first, that puts less load on everything. If anything looks or feels off, stop. The DME is quite good at protecting the engine, but who knows what Cary changed in the custom tune that could impact that.
oma3710194.50 |
05-09-2020, 12:03 PM | #57 |
DisplacementReplacement
409
Rep 1,100
I know that each manufacturer uses their own tuning targets and i'm under the impression that BMW uses load and Subaru as an example uses boost targets. I used to use Cobb's Access Tuner Race to self tune my N54 and it was definitely load based tuning, the whole strategy was to achieve a load, not achieve a boost. From my experience with Subaru and BMW tuning, this tuning method is superior to boost based tuning for various reasons. IMO
My 2 cents worth. lol
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
oma3710194.50 |
05-09-2020, 01:19 PM | #58 | |
Rep 7,602
05-10-2020, 08:10 AM | #59 | |
409
Rep 1,100
05-15-2020, 06:42 PM | #60 |
Rep 1,282
I ended up getting the retune. I've only had one revision so far. Below are logs. The car feels stronger up top.
https://www.bootmod3.net/log?id=5ebe...0b43685823bc39 https://www.bootmod3.net/log?id=5ebe...90c6749ae74109 https://www.bootmod3.net/log?id=5ebe...90c6749ae74106 https://www.bootmod3.net/log?id=5ebe...729b718e92a69f
05-15-2020, 07:40 PM | #61 | |
Rep 7,602
What are your first impressions - change in responsiveness/lag? Worth the money? I only looked at the bottom log, but i find it a little surprising you are still trailing below boost target at 90% WGDC. Could just need some tune refinements though. Do you have a link to one of your "best" logs from the old custom tune before the turbo? I think putting these logs (or logs once this tune is dialed in) in virtual dyno will really show how much you are benefiting from the turbo upgrade. |
05-15-2020, 08:05 PM | #62 | ||
Rep 1,282
05-15-2020, 08:54 PM | #63 |
Rep 2,357
Did you get the Dinan?
(A Dane in China) |
05-15-2020, 08:58 PM | #64 |
Rep 1,282
06-02-2020, 07:55 AM | #65 |
Rep 1,282
New logs with dinan turbo. Cary still revising.
https://www.bootmod3.net/log?id=5ed6...90c61395a59714 https://www.bootmod3.net/log?id=5ed6...0b43443c80faae https://www.bootmod3.net/log?id=5ed6...90c61395a59712
06-02-2020, 11:19 AM | #66 | |
Rep 7,602
There's also a weird throttle closure and whatnot at 6800 in the last log (didnt look at the others). |
