06-03-2020, 01:37 PM | #1 |
Rep 301
xHP Flash recent reviews anyone?
I was initially very excited about this trans flash but once released there were some very mixed reviews.
Seems like it makes more for an improvement with the 6spd than the 8spd transmission. Can some 8spd folks give me their impressions? I am thinking about it for the torque limiter problem alone but I occasionally track the car and hope that I would find it to be an improvement for the track. Thanks! |
06-03-2020, 01:44 PM | #2 |
Rep 1,500
Drives: F36 435xd
Hi there
I have written about my experience with both the 6 speed and the 8 speed in another thread. Seek and you shall find. But you are right....most difference before and after was on the 6 speed. It's like the 8 speed just gets a bit more refined with the tune. A while ago the shop did a complete software update on my car and overwrote xHP and the trans was back to OEM. It took me a few days to flash it again and I noticed the difference before and after again. I can only recommend to use it. Btw I run stage 2 as it is my dd
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
ChrisFulton227.50 |
06-03-2020, 01:58 PM | #3 |
Car Hypochondriac
335
Rep 901
I too, run stage 2 as a daily. There are no downsides besides the cost. It also gives you a lot of control you won't get as stock or with the BM3 tune.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
ChrisFulton227.50 |
06-03-2020, 01:59 PM | #4 |
Rep 1,105
I use stage 3 and am also daily driving with no issues at all.
I would highly recommend it if you have the means to purchase. |
ChrisFulton227.50 |
06-03-2020, 02:11 PM | #5 |
F36 GC
143
Rep 259
Stage 2 daily driver. Noticeable improvement in all driving modes. Transmission seems sharper and more refined. Would highly recommend.
ChrisFulton227.50 |
06-03-2020, 02:15 PM | #6 |
Rep 600
Just saw this post
Please allow me to place my question also here. Having the AA stage 1 flash for about 2 years, I just additionally flashed the 8HP with xHP Stage 2 a few days ago. Even when xHP config is set to use 2nd gear from a standstill in Comfort/Sport mode, the car seems to always drive off in 1st gear. (Dashboard also displays 1st gear (D1) when in standstill. ) So I flashed xHP back to "stock" just keeping the gear info the dashboard. Even then, D1 is shown in standstill Comfort mode. So now I am confused and wondering, if AA tune has an impact on that?! I didn't pay any attention to that before the xHP flash. Does your 8HP drive off in 2nd gear in Comfort/ Sport mode, when flashed in xHP? Thanks
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
06-03-2020, 02:35 PM | #7 | |
Rep 7,591
If you are tracking, you can try out the new stage 4 for 8AT, which is stage 3 with aggressive shift maps designed specifically to keep the car in auto on the track. Last edited by thejeremyman9; 06-05-2020 at 01:46 PM.. |
ChrisFulton227.50 |
06-03-2020, 04:13 PM | #8 |
Rep 301
Is the stage 4 included in the map pack? On the xHP website it just says stage 1,2,3. Could be old info?
06-03-2020, 04:35 PM | #10 | |
Rep 7,591
Info on website is old. I thought manual is updated but not entirely sure. I am 100% sure there is stage 4 though, i just flashed last month and saw it as an option. As far as stage 2 vs. 3, the wording XHP used to have on their website (which i believe has since been changed) made it sound like stage 3 was a bit more aggressive in terms of shift "feel", although they emphasized this was totally safe and was no indication of increased wear or anything like that. I debated doing stage 2 for fear that stage 3 would be too much for DDing, but stage 3 is fine and i didnt really find it too aggressive at all. I honestly noticed very little change in D/comfort mode at all (maybe a little smoother and faster, gear indicator added, etc), but a significant difference in S/sport+ (shifter to the left, sport + driving mode). Thats where you can really tell the difference with stage 3, whether in auto or manual (again, with shifter to the left). My recommendation is jump in with both feet and go straight to stage 3 - that will allow you to experience the most dramatic change vs. stock and IMO makes it feel worth the money the most. If for some reason its too much, dial back to stage 2 or 1. Finally, i did not get the popup when i flashed, but they used to recommend driving around for 50 miles after flashing before really getting on it (you will see in DIY videos if you watch them). Lots of city driving, shifting, coasting, etc, to let the trans adapt. May not be 100% required but i did it. |
ChrisFulton227.50 goodguyf3354.00 |
06-04-2020, 12:22 PM | #12 |
Rep 237
I flashed stage 3 a few weeks ago. Zero regrets. Refined the behavior, sped up manual shift response, D in comfort is actually usable now, shifts in sport+/dsc off are faster when your leaning into it. Upshift blips are faster. Stage 4 is for track duty where you want S auto mode to go to redline before shifting in every gear. You want stage 3. I also selected option start in 2nd but it doesn't want to do it. I would want to make sure I flashed it with the option correctly before saying it doesn't work, though I selected show gear # in auto mode at the same time and that worked fine. Highly recommend, the stage 3 really polished off the 8hp and makes it the best it can possibly be, plus shift point editor etc if you want that functionality
ChrisFulton227.50 |
06-05-2020, 09:50 AM | #13 | |
Rep 600
I also need to investigate more, the behavior of shifting gears down with the paddles when in "comfort" and D. Sometimes the car stays in the manually selected gear unless moving the shifter to the left (S) and back to normal (D). (It wont go back to D after a few seconds) Sometimes it moves automatically back to D just as with stock flash
06-05-2020, 11:07 AM | #14 | |
Rep 7,591
Are you sure this isnt what you are experiencing? |
06-05-2020, 12:41 PM | #15 |
Car Hypochondriac
335
Rep 901
No, there's a new option in the app. You have to click on the start in second option and enable the two sub-options in addition.
06-05-2020, 01:32 PM | #16 | ||
Rep 114
ChrisFulton227.50 |
06-05-2020, 01:34 PM | #17 | |||
Rep 114
06-05-2020, 01:47 PM | #18 |
Rep 7,591
06-05-2020, 01:58 PM | #19 |
Rep 963
is there any proof or testing to validate the claim that there is no additional wear and tear from these maps?
i flashed the bm3 trans update to remove the torque limiter, but i find the shift speed to actually be slower than stock. its getting kind of annoying. XHP is on the list, but I am worried that 50k miles later, my trans will be shot or something
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
06-05-2020, 02:16 PM | #20 | |
Rep 7,591
I mean, its the same idea as a DME flash. The "proof" is essentially the widespread use. |
06-05-2020, 03:00 PM | #21 | |
Rep 237
