| 06-22-2020, 06:49 AM | #2707 |
Rep 289
| 06-22-2020, 06:52 AM | #2709 |
Rep 289
| 06-22-2020, 07:56 AM | #2710 | |||
Rep 256
that way we could diff all the changes between the the software versions and pull in all the changes to apply |
x-m4n146.50 |
| 06-22-2020, 07:58 AM | #2711 |
![]() 9
Rep 55
It’s not really unreasonable is it? He’s got the skill/knowledge and you don’t. Maybe it only takes him 5 minutes but he will have spent plenty of time learning how to do it.
| 06-22-2020, 08:03 AM | #2712 |
![]() 35
Rep 93
You are right, that he is able to take whatever he wants for the job, but if this should be done on every single update from Andream, then that makes it too expensive for most.
| 06-22-2020, 09:01 AM | #2713 | ||
Rep 771
$20 if the developer could edit the tilt right/left idrive behaviour so it can skip/back songs on Andream /CarPlay |
nitsuj1756.00 |
| 06-22-2020, 09:44 AM | #2714 |
![]() 9
Rep 82
I'm happy to also pay $20 to just get it working with the proper resolution, I'm not really interested in any new features, it's got some other issues but I can live with those and I doubt they'll ever be fixed by Andream/carlinkit now.
| 06-22-2020, 09:58 AM | #2715 |
Rep 2
Hello guys,
I just signed up on bimmerpost and there are so many useful information about bmws here! Okay, so I just installed the Andream box. Everything works good except the audio doesn't play on all of the speakers. I don't hear anything on the driver's side speakers. (Only passenger side speakers are working). When I switch to BMW Idrive, then all of the speakers are working just fine. Not sure what could be wrong... |
| 06-22-2020, 10:42 AM | #2716 | |
![]() 9
Rep 55
Do you have the Aux cable with 3.5mm headphone jack connected? If not try that under your arm rest Aux in socket. Or if you have anything else you can plug that in to so you can test it, like a pair of computer speakers etc that you could take out to your car. I guess even earphones should work if you have a male to male adapter. Edit: Just thought you can probably plug it into your phone and record it then playback. Might need a second phone and an app that shows a wave form of each channel. Last edited by phil5556; 06-22-2020 at 11:22 AM.. |
| 06-22-2020, 10:45 AM | #2717 | |
![]() 9
Rep 55
The steering wheel buttons however would be awesome to get working. It’s the only thing that would make me try an update. |
| 06-22-2020, 12:04 PM | #2719 |
![]() 9
Rep 55
I have a question about multiple iPhones....
How does it deal with switching / deciding which phone to connect to? I’ve done a quick test with my wife’s phone this afternoon. We have both phones now listed on the Wireless Devices screen, i switched to her phone manually and then reboot the unit using the back button and it reconnects to her phone. If I then connect to mine and reboot then it starts back up connected to mine. Does it always reconnect to the last used phone or did I just get lucky? I assume if she gets in the car it will connect to her phone (unless mine is in range at home). I’ll see what happens over the next few days but just wondered if anyone knew how it behaves. I did notice her XS runs quite a lot more smoothly than my 6S too... |
| 06-22-2020, 12:07 PM | #2720 |
![]() 9
Rep 55
| 06-22-2020, 12:37 PM | #2721 |
Rep 28
Hi all,
I edited the XML and I can change it in the bin file. If the .bin file is not signed, is a very simple process. Only problem is that I don't have the unit to test it myself. |
| 06-22-2020, 12:44 PM | #2722 |
Rep 289
| 06-22-2020, 12:53 PM | #2723 |
Rep 1,219
| 06-22-2020, 01:02 PM | #2724 |
Rep 28
binwalk, I extracted the squashfs file, changed the XML and re-created the squash file and inserted into the .BIN
There are some weird thing that might make it to not work. We will see. |
| 06-22-2020, 01:04 PM | #2725 | |
Rep 280
Would like to know this as well
![]() Tried it myself on the weekend but my resulting .bin wasn't flashable. I used binwalk to identify start and end of the partition and extracted it with dd. After making the changes I wrote it back into the .bin (the size hasn't changed): Code:
mksquashfs squashfs-root spsdk.squashfs -comp lzo -Xalgorithm lzo1x_999 -Xcompression-level 9 dd if=spsdk.squashfs of=ISPBOOOT.BIN bs=1 count=50941952 seek=14186496 status=progress conv=notrunc I checked and extracted the modified .bin and everything looked okay, but the unit didn't accept it and said 'Failed' during the flash. Probably something else needs changing as well or I made a mistake along the way. I'll probably remove the md5 hash checks completely during the next try, but don't expect anything. //Edit: Quote:
And like I wrote above, you still need to account for the md5 checks in the ISP flash script at the end of the .bin. And I also noticed that the extracted squashfs files using binwalk are a little bit bigger than when you do the same with dd. Last edited by Firefly1337; 06-22-2020 at 01:10 PM.. |
touchmynappa58.50 |
| 06-22-2020, 01:24 PM | #2727 | |
Rep 843
Unpack the original bin again, then repack it (without changing anything). Then repack it with the changed xml (don't correct any md5's). Then do a hex compare and you should find the lines in the bin file that were changed. Then edit the original bin with that change and save it (again don't fix any md5's). See if that works (file length should be exact still that way). |
| 06-22-2020, 02:03 PM | #2728 | |
Rep 28
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
