| 06-24-2020, 12:36 PM | #2795 | |
Rep 280
But nothing else, though ![]() //Edit: Just noticed that Bimmertech changes the '20...' in the MCU version to '10...' automatically. Weird. |
| 06-24-2020, 12:40 PM | #2796 | |
Rep 1,219
| 06-24-2020, 12:47 PM | #2797 | |
Rep 843
Previously when I soft bricked my unit with the later bimmertech updates, I could not get into the settings screen, the unit just would not respond. Usual message is Invalid Update, so you have changed something ![]() |
| 06-24-2020, 12:50 PM | #2798 | |
Rep 289
| 06-24-2020, 12:53 PM | #2799 | |
Rep 289
"This latest BIN is justified from another binary pushed into your ARM nand memory. If I remove anything from this BIN will make the device bricked if flashed." Or something like that at least.... |
| 06-24-2020, 01:19 PM | #2800 |
![]() 1481
Rep 2,684
Here's to hoping carlinkit can get the fix too
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
muniz_ri438.50 |
| 06-24-2020, 01:29 PM | #2801 | ||
Rep 1,219
| 06-24-2020, 01:30 PM | #2802 | |
Rep 24
| 06-24-2020, 02:59 PM | #2803 | |
Rep 280
We could just add our own script at the beginning and terminate ('exit 0') before anything is written or destroyed. That way we could dump the whole partitions from nand. https://www.denx.de/wiki/DULG/UBootCmdGroupNand Getting all environment variables, 'nand dump' and even 'dd' is available, and then write that to the USB drive for further analysis. |
| 06-24-2020, 03:06 PM | #2804 | |
Rep 843
Thus turning Andream units into Carlinkit or Bimmertech units and vice versa. |
x-m4n146.50 |
| 06-24-2020, 03:59 PM | #2805 | |
Rep 1,219
| 06-24-2020, 04:50 PM | #2806 |
Rep 1
Hi everyone, I've read the post and I can't see the solution to my problem. Firstly apologies for posting in this forum as I have a 2013 F06 not an F30.
I purchased the Andream mmi interface and fitted it, however the idrive doesn't control the unit. The car has a CIC stereo, however Andream advised to use the F30 loom that came with the unit. Everything else works, and I can toggle between the unit and the stereo using the 8 button, or use the phone to control CarPlay. Andream suggested using the CIC wiring loom when I approached them with the problem with the idrive however the car doesn't like it when the idrive T wire is installed and it gives loads of errors in the car. I hoping someone on here will have some ideas. Thanks |
| 06-24-2020, 06:28 PM | #2807 |
![]() 9
Rep 55
I know this thread has gone down the software development rabbit hole but....
Does anyone know if these units have a GPS antenna in them? Does CarPlay use it or always the phone GPS? Sometimes Google maps gets a bit behind and the accuracy circle around the pointer grows. It seems to get better if I move my phone, but that might just be coincidence. If the unit has GPS in it then I might try and move it, it’s currently shoved in a slot behind the dash with quite a lot of metal around it. |
| 06-24-2020, 06:36 PM | #2808 | |
Rep 289
| 06-24-2020, 06:38 PM | #2809 |
![]() 9
Rep 55
| 06-25-2020, 03:20 AM | #2810 | |
Rep 280
It doesn't :/ |
| 06-25-2020, 12:40 PM | #2811 | |
Rep 15
| 06-25-2020, 12:55 PM | #2812 |
Rep 1,219
| 06-25-2020, 01:14 PM | #2814 | |
Rep 28
I am trying to recreate the bin with the correct isp script. |
| 06-25-2020, 01:50 PM | #2815 | |
Rep 280
Took them from the original .bin. You have to look for start and end of each partition and extract them with dd. //Edit: Only xboot. Uboot2 comes from the extract function and is identical with uboot0 and uboot1, so just make copies. xboot1 and xboot2 are also identical, so just extract that with dd from the original .bin and you should be fine. |
x-m4n146.50 touchmynappa58.50 |
| 06-25-2020, 04:23 PM | #2816 |
Rep 23
Just installed my box, so far everything is working well. But I still have to test phone calls.
Does anybody know if the sequence of the apps in CarPlay can be changed? |
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
