| 02-04-2023, 12:58 PM | #11353 | |
Rep 2,615
Having echoes seems to be an issue for some, and not for others. Some of it could be related to OEM Bluetooth being used for audio and telephone or one instead of the other. Or using the MMI Bluetooth settings for audio or telephone, or a mix of these two. But before looking at those settings, I would recommend going in the MMI menu and set up your microphone echo configuration. I forgot how it works, but I know that when you are making adjustments it will tell you how much of your microphone is being picked up by the MMI and it will give you a percentage. Adjusting it so it measures 100% is what that menu helps you do. Also, although not related, it seems that if you set the Loudness from 800 down to 400 it eliminates some of the distortion.
| 02-04-2023, 01:04 PM | #11354 | |
Rep 2,615
If you don’t see an HDMI icon along with all the other default MMI menu icons it’s possible that a non-HDMI CUST version firmware is installed on your MMI somehow.
| 02-04-2023, 01:54 PM | #11355 |
Rep 21
Hmm I dont have that hdmi icon in the main menu. I bought the box a week ago from https://www.android-car-dvd.de
Is there a newer firmware I can try and install? Or maybe a older one? |
| 02-04-2023, 02:04 PM | #11356 | |
![]() 18
Rep 89
Any way to tell for sure which F/W I have and If I can flash a newer one? I know it's an Andream, and the code on my box reads: EWM-BMCP-EVO-A which is different than those in the first page. My resolution is somewhat stretched width wise, which means square icons/circles are not perfect squares/circles. PS. I was hoping I could keep using the touch screen but it doesn't seem to work, only via iDrive controller. |
| 02-04-2023, 02:13 PM | #11357 | |
Rep 2,615
For now: You could try to plug in an active HMDI signal and reboot the MMI and see if it registers. This is similar to what it should look like in your menu: View post on imgur.comLast edited by fe7565; 02-06-2023 at 06:59 PM.. |
| 02-04-2023, 02:31 PM | #11358 | |
Rep 2,615
I would post some photos of your box, your menus, especially the one that shows your firmware...and see if anyone chimes in. Here is another EVO with similar model number:https://f30.bimmerpost.com/forums/sh...ostcount=11215 Follow his resolution. The stretching can be from MMI DIP settings. I know that for 8.8 and 10.25" the DIP should be the same with NBT setup, but maybe EVO is different? And check in Bimmercode under Expert mode what your OEM resolution is set. There may be a difference between 8.8" and 10.25" in EVO because of the possibly higher resolution screens vs NBT OEM screens. For example 800x480 vs 1280x 720 vs 1920x 980 (these are just numbers I pulled out of a hat). Last edited by fe7565; 02-04-2023 at 02:43 PM.. |
| 02-04-2023, 02:43 PM | #11359 | |
![]() 18
Rep 89
If I want to use the OEM BT, does that mean I will need to have my phone paired with 2 devices simultaneously every time? I also noticed I could not answer a call from the steering wheel Phone button, only via iDrive. Is that due to not using OEM BT? Here is a screenshot of my F/W screen: ![]() |
| 02-04-2023, 04:16 PM | #11360 |
Rep 26
2 years after I installed Roadtop module in my car I started getting similar errors on my dashboard. I had passive safety system error and sometimes central air condition and radio panel stopped reacting or turned off. I haven't update the module for longer time. Does it mean the module is broken or is it somehow fixable? After disconnecting the module from the car everything is working fine in the car.
| 02-04-2023, 05:13 PM | #11361 | |
Rep 2,615
Andream B2-Version [1] [NBT] [GEMINI_PACK.BIN] Model: EW-BMCP-NBT04X Note: There are two B2-Versions for 'NBT'. Their updates are not compatible with each other. B2_V1.1.5 (PIN: 5025) (Not cross compatible) B2_V1.2.0_t (PIN: 5025) (Not cross compatible) B2_V1.2.5 (PIN: 5025) (Not cross compatible) B2_V1.5.0 (PIN: 5025) (Not cross compatible) B2_V1.5.5 (PIN: 5025) (Not cross compatible) B2_V1.5.9 (PIN: 5025) (Not cross compatible) B2_V1.6.2 (PIN: 5025) (Not cross compatible) MCU 20.10.22.16 (Cross compatibility unknown) MCU 21.09.13.122 (Cross compatibility unknown) Last edited by fe7565; 02-04-2023 at 05:40 PM.. |
| 02-04-2023, 05:29 PM | #11362 |
Rep 2,615
[QUOTE=ringo9;29807801]According to the instructions for this model year F20 the correct DIP switch settings are still: First 3 ON, the rest OFF so I guess it's not that.
If I want to use the OEM BT, does that mean I will need to have my phone paired with 2 devices simultaneously every time? I also noticed I could not answer a call from the steering wheel Phone button, only via iDrive. Is that due to not using OEM BT? Here is a screenshot of my F/W screen: Check your OEM screen resolution settings in your car's coding. The default obviously works for your OEM screen, but may have issues with what the MMI is looking for. Do not think you can answer phone calls via the steering wheel button if you are in MMI mode. Assuming your phone is paired BLE in OEM mode already, I think you should be able to answer phone calls via the steering wheel button, if you are in OEM mode, or switch to OEM mode either with your BACK (or some use the MENU) iDrive Controller buttons. May be able to use a shortcut button for "telephone" using one of the 1-8 OEM user preset buttons. Some people set "audio" only and not "telephone" in config settings for the phone device in OEM mode, or vice versa. Some also set OEM BLE mode in the MMI settings as well. The BLE is murky for me in many cases, so may want to ask others to chime in. What I know: the BLE on a device allows connections to up to about 8 devices simultaneously, but the OEM BMW OS and the MMI would have to have that implemented. I do not think the Chinese bothered to put that extra effort in the design. For us morons buying their half-ass devices finding work-arounds for the shortcomings are good enough. I think the BMW OEM allows at least two phones (devices) simultaneously connected, but again, the MMI does not seem to have that enabled. The MMI is using the BLE phone call passed on to it by the OEM head unit and vice versa. The MMI at times uses the BLE cannel between the MMI and the OEM HU for sound, phone, alerts, etc ....and at times uses the direct AUX-IN channel (but not for the phone). Again, feel free to ask others who have a better understanding of this half-ass setup. (Looks like you have a firmware that is new and not listed or posted here. So, if you do any upgrades/changes, the only way to revert back if you have a back up or if you try another already posted version. Or ask the Chinese seller or their distributor to send you a copy. You may get lucky and after selling your kidney, they may have mercy and send it to you) Last edited by fe7565; 02-04-2023 at 05:54 PM.. |
| 02-04-2023, 05:38 PM | #11363 | |
Rep 26
| 02-04-2023, 05:45 PM | #11364 | |
Rep 2,615
After MCU update, make sure you clear your error codes with ISTA or some code reader to see what (if any) was solved. Last edited by fe7565; 02-04-2023 at 05:50 PM.. |
| 02-04-2023, 06:14 PM | #11365 | |
![]() 18
Rep 89
[QUOTE=fe7565;29808287]
I will play around with settings tomorrow now that the unit is basically working OK, looks like there are a few options to experiment with. |
| 02-04-2023, 06:23 PM | #11366 |
Rep 9
I have the andream mmi box for my BMW F15, I like it but…. Doesn’t have touch screen as my F15 is pre 2016.
I also have the Andream BMW e70 CarPlay kit (non Android), but screen only and it’s a touch screen.. hands down a much better unit and a lot easier to install than MMI. Only if they had this for F15 |
| 02-04-2023, 06:56 PM | #11367 | |
Rep 2,615
[QUOTE=ringo9;29808412]
Also, if you have AA running on the MMI and long press the steering wheel button, Google Assistant should come up. Or you can just command "Hey Google/ OK Google" and it should appear as well. Feel free to ask others here for tips, there is a lot of good info and work arounds that others came up with. |
| 02-04-2023, 07:02 PM | #11368 | |
Rep 2,615
In my old F30, I have updated my Entry HU to NBT and my 6.5" OEM screen to a 10.25" F-15 OEM screen and I have zero reflection in even the strongest sun light. https://f30.bimmerpost.com/forums/sh...168747&page=23 |
| 02-04-2023, 07:26 PM | #11369 |
![]() 4
Rep 79
Anyone able to tell me which manufacturers software I should be using?
Bavarian automotive current software is; SDK Version: 25.0.0.7.0.0.2.0 CUST Version: CHL V1.6.6 MCU Version: 20.12.1.18 HW Version: BMW_CICHL |
| 02-04-2023, 07:51 PM | #11370 |
Rep 3
Firmware upgrade advice
Hi folks,
I've just picked up an Andream unit from Ebay (at least, that's what the listing said it was) and have installed it today. I'm looking for some advice on a couple of things; 1. What's the correct model for my unit and what firmware should I install? 2. I didn't have an awful lot of time to play around with it after the install as it took me longer than expected to get the unit in place! But what I did notice is that the only way I could access the MMI menu was by holding down the "back" button for 3 seconds, and not the "menu" button. Is that normal? FYI, here are the details from my unit; SDK Version; 25.0.0.7.0.0.2.0 CUST Version: B_V1.2.5 MCU Version: 20.10.22.16 HW Version BMW_NBT Many thanks in advance for your advice! |
| 02-04-2023, 09:30 PM | #11371 | |
Rep 1,143
Andream B-Version [NBT] [GEMINI_PACK.BIN] Model: EW-BMCP-NBT02B |
MacBullyBoy0.00 |
| 02-05-2023, 10:51 AM | #11372 |
Rep 71
It is possible to answer a call with a button on the steering wheel, for this it is necessary that the phone is connected via Bluetooth with the OEM system of the car and with the MMI. The connection to AA is wireless via WIFI. At the first moment, both Bluetooth connections will be activated, then only the connection with the OEM will remain, with the MMI there will be a connection via WIFI. In this case, I have the opportunity to answer calls (mobile only) from the button on the steering wheel. Calls from whatsapp, telegram, Viber have to be activated from the phone. This is how it works for me - X1 F48 entrynav (equivalent to NBT)
With this scheme , audio connections occur via Bluetooth with the OEM system and the call passes through the OEM . Through MMI only management. There was a moment when the connection with the MMI was lost (the AA interface was changed to the MMI interface), but the call was not interrupted. Regarding the stretched icons and the lack of screen separation on the 8.8 display On my POCO X3 PRO phone, everything works as it should. I recently conducted an experiment - I flashed an old phone to android 11 and connected it to MMI (only through a wire since the phone did not have wifi 5GHz), so there was no screen separation with this phone and the icons were disproportionate. I do not know how to explain it. Last edited by eltech; 02-06-2023 at 01:50 AM.. |
fe7565967.00 pacstealer0.00 |
| 02-05-2023, 01:35 PM | #11373 | |
Rep 1,219
With a wireless connection, Google Assistant works when the car is not moving but does not work when the car is in motion. It works with no issues when using a wired connection. I looked extensively for a solution but no luck. My workaround is to use a Motorola MA1 and works fine. |
| 02-05-2023, 01:54 PM | #11374 | |
Rep 26
yes, it's because you have to use OEM BT to use the steerihg wheel controls use that to live better trust me |
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
