| 03-04-2023, 01:33 PM | #11507 |
Rep 2,615
For iDrive controllers that have up and down and left and right vs those that only have left and right.
| 03-04-2023, 01:49 PM | #11508 | |
Rep 360
It starts in black or no signal, but after it automatically reboots, it all works fine. |
| 03-04-2023, 03:30 PM | #11509 |
Rep 6
My screen is tiled. Does anyone know how to fix this? I unplugged all the wires from the box to require it through the glove box and after plugging everything back in the screen is tiled. I see two full screens and two half screens. Perhaps I flipped one of the toggle switches? I only have 4 flipped to on. Any help is greatly appreciated.
| 03-05-2023, 09:59 PM | #11510 | |
Rep 1,143
| 03-06-2023, 03:20 AM | #11511 | |
![]() 54
Rep 63
If u want help on a forum, please provide more info!!!
Did my post help you? Please appreciate post.
| 03-06-2023, 03:23 AM | #11512 | |
![]() 54
Rep 63
The CarPlay "HeadUnits" are trash. I stopped selling them because of all the problems and the mirror(screen). The microphone is also really bad, it's internal and very bad quality. Andream even told me not to buy them anymore because of the problems they have, and my returns had cost them too much. I suggested to stop selling that crap but they say most people don't complain... I suggest returning it and buy an MMI to work on ur original screen. If you do want a big screen/touchscreen, buy an Android screen with built-in Apple CarPlay or upgrade to 8,8"/EVO ID6.
fe7565967.00 |
| 03-06-2023, 06:09 AM | #11513 | |
![]() 54
Rep 63
She has been my salesperson for almost 3 years and is willing to help. I explained that the 90 degree cable is wrong and they should send 180 degree cable: +86 156 8339 0715
| 03-08-2023, 10:11 PM | #11514 |
Rep 21
| 03-09-2023, 10:11 AM | #11515 |
Rep 476
HI Guys,
Do you any of you have issue where you get out the car to get fuel and then when you come back it just won't connect? Leave it for an hour an it just connects. It's like bluetooth/wifi just don't want to reconnect that quickly..
F25 X3 35d - F30 335i - |
| 03-09-2023, 12:39 PM | #11516 | |
Rep 2,615
Question: is your phone with you when you are out of the car for a short time? Ad if yes, are you far enough from the car to break the bluetooth and/or wifi connection? Edit: I think the reason it reconnects fine after a longer time is because the car goes to sleep and powers down the MMI as well...breaking all connections. When you enter the car again, it reboots from scratch and connects OK according to the designed MMI protocol sequence. But, when you only leave for a short time but far enough to break the bluetooth and wifi connections while the MMI still stays powered up...the MMI's internal software protocol may not connect back to the bluetooth and/or wifi automatically. That's because the Chinese clowns that designed the software did not properly test for all situations. And they did not make the source code available in an open source format so people can fix it. Quality is not the #1 priority when you have enough dumbasses (like me) to buy their half-ass products. One thing that could be done is to do some tests to confirm if the bluetooth and/or the wifi loss leads to a "no-reconnect" problem in all cases. Since we cannot get into the MMI firmware (I think Firefly1337 managed to hack it in the early versions) to fix the crap MMI coding, instead could use an Arduino or else to detect when the bluetooth and/or the wifi is disconnected from the MMI and then force a reboot of the MMI which will also fire up the re-connect-protocol next time it detects your phone in range.
Domih54.00 |
| 03-10-2023, 05:01 AM | #11517 | |
Rep 476
Also, deleted the connection to the car with oem bluetooth.
| 03-10-2023, 05:26 AM | #11518 | |
Rep 2,615
| 03-10-2023, 09:13 PM | #11519 | |
Rep 21
Domih54.00 |
| 03-11-2023, 03:19 PM | #11520 |
![]() 12
Rep 53
Carlinkit update
Hey guys, sharing the last update for Carlinkit. After the last Google Auto update my system was super slow. This update resolved connectivity issues and the slowness.
version of 9.6.9.yl.b https://drive.google.com/file/d/1__8...ew?usp=sharing |
| 03-12-2023, 01:13 PM | #11521 |
Rep 9
Hey guys, I have an Andream MMI box for NBT but have been struggling with android auto audio settings.
1. Whatsapp voice notes are very soft, overshadowed by to music playing. Need to mute it to be able to hear voice notes. 2. Maps audio directions and alerts are very loud. Not sure if there are any specific settings in android ir in the unit itself that need to be changed. Thanks |
| 03-12-2023, 05:39 PM | #11522 | |
Rep 2,615
| 03-12-2023, 06:54 PM | #11523 |
Rep 17
Hi all, question, got a andream mmi, when I start my car and put it in reverse to soon - within 10 seconds (automatic with pdc) the MMI crashes and gives a black screen, only a reboot will get it back online. does anyone know a solution to counter this? and is it possible to start the cars own system instead of the MMI when starting the car, like when it has to go to the dealer?
Thanks |
| 03-13-2023, 03:57 AM | #11524 | |
![]() 54
Rep 63
What's your firmware version? An update might solve it. The car only starts from MMI when the phone connects, so at the dealer it won't switch to MMI. Also, most dealers don't mind. They like the MMI. One Dutch dealer is even my customer.
| 03-13-2023, 08:30 AM | #11525 | |
Rep 15
And if the are not set correctly, big chance Google syncs them over all your phones. Go to your phone settings, search android auto and select android auto settings, then check what is set under Day/Night stand for maps, it should be set to auto. That wasn't the case for me with default setting, which is strange indeed, but now I set it to auto works fine, as soon as my car lights go on, I got night mode. |
Domih54.00 |
| 03-13-2023, 08:36 AM | #11526 | |
Rep 15
| 03-13-2023, 12:04 PM | #11527 | |
Rep 2,615
| 03-13-2023, 08:28 PM | #11528 |
Rep 9
Hello,
I'm looking for the latest MCU update for my MMI (Andream B-Version [NBT EVO ID5/ID6]). My current status is: SDK Version: 25.0.0.7.0.0.2.0 CUST Version: E_V1.6.7_n MCU Version: 20.11.30.21 HW Version: BMW_EVO According to several posts, there should be an updated MCU version 21.3.22.20 (or greater). Does anyone know where to get the latest version? Thanks! |
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
