BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      03-13-2023, 09:11 PM   #11529
RAAF12
Netherlands
83
Drives: 320i
Originally Posted by dmeerpa View Post
I went for Tomtom Amigo on Android, free, good route graphics much better voice directions, and yes most important for me speed alerts (and also red light camera's, mobile camera, route traject speed controls, ...). I several times tried Waze, but no even they have a larger followers, I don't like the interface.
True Tomtom is the best, navigation, speech quality and owns Teleatlas maps. Forget Waze, Google and Apple Maps. If you want the best avigation it's Tomtom. I do the paid version for Carplay.
      03-13-2023, 10:24 PM   #11530
F87source
F87source's Avatar
Drives: Bmw M2
How stable is the android auto connection on the mmi? and how is the latency?
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh....php?t=2038326
      03-14-2023, 03:54 AM   #11531
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
I use CarPlay now, but used Android Auto for a while. The only latency I notice in my old F30 is when I do voice commands like "Hey Google!" or "Hey Siri". But that latency is there when I do voice via bluetooth (calls) on the OEM. So, I do not think there is any noticeable latency introduced by the MMI on the navigation voice and graphics when it runs.
CarPlay is stable for me. I do not recall any stability issues with AA (for me). At times it may not reconnect after the car was shutdown for a shorter period of time. I suspect it to be lousy coding in the MMI. Some people have issues with crashes, depending on brand, firmware version. Cannot tell you what percentage. But I assume people post here when they have a problem and not when it works fine. If you are deciding if worth the $240 and install effort: depends on what you have. If you only have OEM nav and it's NBT then yes, by all means, it's worth it.
F87source8590.50
      03-14-2023, 04:39 PM   #11532
Anonymousbanana
Drives: BMW X5
Does Siri and navigation voice not work if you use the HK hack? Music plays but I can’t here Siri or voice directions.
      03-15-2023, 09:53 AM   #11533
eltech
Russia
Drives: BMW X1 F48
I rolled back the firmware on my POCO X3 PRO and got android 11. The problem of disconnecting the phone from the MMI in places of a bad mobile network has gone away.
      03-15-2023, 11:22 AM   #11534
mauritsje
Netherlands
Drives: BMW 420i (10/2015)
Originally Posted by Domih View Post
Hey,
What's your firmware version? An update might solve it.
The car only starts from MMI when the phone connects, so at the dealer it won't switch to MMI.
Also, most dealers don't mind. They like the MMI. One Dutch dealer is even my customer.
Hi, im running: EW_B2_V1_1.6.9R2_n Cust and 21.9.13.122 MCU on a AN-BMCP-NBT04X - Ive had this issue on previous MCU and FW to
      03-16-2023, 04:29 AM   #11535
Jenly Tang
Drives: BMW F30
Talking
When using carplay, you need to turn off the Bluetooth of the original car, otherwise, when you call Siri, the call may be transferred to the Bluetooth of the original car, and you may wake up the voice navigation of the original car, so Siri cannot Your voice has been recognized.
Domih54.00
fe7565967.00
      03-16-2023, 04:36 AM   #11536
Domih
Drives: 2016 BMW F21 118i
Originally Posted by Andream-Vera Hu View Post
If your car is an EVO system, you only need to connect the USB audio box to get the audio, no need to encode the AUX function.
Coding AUX is easyer than running the USB-AUX cable.
Did my post help you? Please appreciate post.
      03-16-2023, 05:05 AM   #11537
Willy6215
Drives: BMW 535D
Can anyone share or DM me please with settings for the MMI box plz like the pic attached
Ie
The mic , sound settings Ect Ect I want to make sure mine is set up correctly
TIA
      03-16-2023, 05:10 AM   #11538
Sally63
Drives: BMW f30
I bought their MMI for my F30. Both carplay and Android auto connections are stable without any lag, great experience.
      03-16-2023, 05:20 AM   #11539
Sally63
Drives: BMW f30
Originally Posted by scheregroup View Post
Hello,
i am on the way to order a MMI for BMW i3 2019 EVO ID6.
AUX is coded with bimmercode and visible to select in the menu.
Which box oder sw-Version is working "without" AUX cabling?
Thx in advance
From what I understand, the EVO box don't seem to work through AUX. Instead, via a USB audio box. My friend bought their EVO box.
      03-17-2023, 02:29 AM   #11540
BugginCarlos
Drives: 2015 BMW 428i Convertible
Even if you are talking about the HU and not the MMI, I had the same issue, and believe it or not it was the phone settings like Andream tells you ...
And if the are not set correctly, big chance Google syncs them over all your phones.
Go to your phone settings, search android auto and select android auto settings, then check what is set under Day/Night stand for maps, it should be set to auto. That wasn't the case for me with default setting, which is strange indeed, but now I set it to auto works fine, as soon as my car lights go on, I got night mode.
Thank you for the tips.
I have tried all combinations of the AA phone day/night/auto settings and Andream unit day/night/auto settings. I even set my AA into developer mode and set the developer settings to allow the phone to control day/night mode. I can set both the Andream unit and phone to night mode and when I start the car, it displays day mode. When i go into the menu on either my phone or the Andream screen, they show that night mode is set. I have to toggle to day or auto, and then back to night to actually get night mode.
I have set all of my brightness settings to 89/100 per some advice else where...
I have just given up on having a fully functioning experience.
And everything works great on my other car with Android Auto.
      03-20-2023, 07:56 AM   #11541
rzorsan
Drives: BMW X1 F48
Good morning friends, since I put the MMI Box on my X1 I have these problems that I can't solve:
*My car has a parking assistant, there is no way for it to work since I connected the MMI, since pressing the assistant button leaves the rear camera and prevents seeing the instructions.
*Phones automatically connect, be they iPhone or Android, to the module's BT and if I'm out of it, I can't listen.
*The music from the iPhone and Apple Watch start to play on their own, without hitting anything.
Does anyone have a solution to any of these problems?
Many thanks friends.
      03-21-2023, 10:46 AM   #11542
GENAU
Drives: 2018 BMW 440i GC
I'm a bit lost on the variety of upgrades and/or updates to these systems. If under system information I find:
SDK Version: 25.0.0.7.0.0.2.0
CUST Version: E_V1.5.10
MCU Version: 21.3.22.20
HW Version: BMW_EVO
Can anyone narrow my search in the update log? I purchased my MMI from DroidUK in 2021
Edit: while I'm here does anyone have the issue of their screen blacking out occasionally. Mine likes to turn off during Android auto and not come back unless I pull the power plug on the box or shut the car off for a few minutes. I can return to the MMI menu and then back to AA but at that point the screen is black. Unplugging and plugging back in my phone or even restarting it does nothing. The phone sees that AA is active but nothing on the car screen....
It's usually random but today it was happening every 5 min or so while I waited in line at the car wash listening to a podcast. Very strange.
      03-23-2023, 10:48 PM   #11543
Jenly Tang
Drives: BMW F30
HW Version: BMW_EVO
Hello mate,
Download link(EW_E_V1.6.9R1):
https://mega.nz/file/uJBn2LJQ#18M1fn...mF8uFBE0Anms6w
You can use the above file to upgrade and try it.
The upgrade password is 2863 or 5025
Domih54.00
      03-24-2023, 02:24 AM   #11544
Paul0417
Drives: F30
Originally Posted by usta83 View Post
Hi all,
this is my first post here.
I have got the Roadtop Box for my F20 116. Works so far great.
2 questions:
- Should I keep the iDrive BT connection?
- How can I "boot" directly in Carplay? For now the iDrive starts. Then I have to press menu and select Carplay.
Please try to turn off the Bluetooth of the original car, reset the Bluetooth connection record, and see if it can connect automatically.
      03-24-2023, 08:11 AM   #11545
Anonymousbanana
Drives: BMW X5
Still looking for help with this. I use the HK hack to get audio through the bmw Bluetooth since the quality is way better, but my iPhone wants to prioritize the CarPlay connection for spoken directions on maps and Siri voice. Anyone know how to get it to prioritize the bmw Bluetooth connection instead? The music will play fine, but I can’t hear spoken directions ever and the Siri voice is about 50/50.
      03-24-2023, 09:25 AM   #11546
SeBiDE
Drives: Mini Cooper D F56
Hi.
Just bought the Box from RoadTop, it's the B2 Version with Firmware 1.69R3 installed - it's latest, right?
So far it's running fine, except:
Yesterday, the box didn't seem to loose power after locking my car - any1 experienced that? My phone still found the CarPlay from inside the house although my car was locked/disabled.
Second "issue": When connected through Airplay, I can mirror my iPhone wirelessly, but when I switch to e.g. YouTube, the video doesn't have the right aspect ratio. It's not wide enough. Sending a video directly from the YouTube app through airplay seems to crash the airplay on the box..
Got the 6.5" screen, btw.
      03-24-2023, 09:40 AM   #11547
Ernstjan
Drives: BMW 435d F36
I don't have an iPhone. But you can try this:
https://discussions.apple.com/thread/251342441
      03-24-2023, 12:40 PM   #11548
n3985
Drives: a car
Originally Posted by n3985 View Post
Tried to install my Andream box today and ended in failure.
Car is 2013 F10 5 series pre-LCI with NBT and 10.2" screen.
After everything was plugged in, my native iDrive screen looks like attach picture, only top 2/3 showing and with serious flickering.
The Andream is an EW-BMCP-NBT04X, which is a B2 model for NBT.
Green/optical plug fitted, dip switches 1,2,3 ON.
Weird thing is the Andream settings menu and CarPlay looks great, only native iDrive screens are messed up.
Suggestions? Thank you
2.5 year update, finally found the time to install new MCU from Andream and reinstall this MMI box.
In case anyone else with F10 and 10.2" screen see flickering and only 2/3 of the screen for native iDrive screens, you need MCU 21.6.7.116.
Migz717.50
      03-24-2023, 02:04 PM   #11549
eunzaro
Drives: BMW X1
Hello, I have bought an andream mmi for my F48, the car does not have an aux output, I have tried to activate it with the bimmer code but the option does not appear, is there any way to make it work?
      03-24-2023, 03:39 PM   #11550
Cavia
Drives: F20
A recap of my experience
Originally Posted by Cavia View Post
Hello,
I'm looking for the latest MCU update for my MMI (Andream B-Version [NBT EVO ID5/ID6]).
My current status is:
CUST Version: E_V1.6.7_n
MCU Version: 20.11.30.21
HW Version: BMW_EVO
According to several posts, there should be an updated MCU version 21.3.22.20 (or greater).
Does anyone know where to get the latest version?
Thanks!
Ok, after fighting a lot with the customer service of my MMI, I managed to obtain some updates. But first, some interesting info.
I strongly believe that all the Andream clones belong to this group: https://www.ewaygps.com/
The reason is, my MMI was purchased from 'TLPXAUTO Official Store' (an ex-aliexpress vendor). Now, if you visit their webpage on AliExpress, they will ask you to contact Daisy [at] ewaygps.com in case of additional support.
Note that on https://ewaygps.com/downloads/firmware-downloads/", they have a password protected repository of updated firmwares. Probably the Eldorado we are all looking for.
Anyway, the first update I manage to get is the latest (according to the official support of Ewaygps) MCU for my BMW_EVO hardware.
This is version 21.8.11.15 and it installed flawlessly.
https://mega.nz/folder/CVZFXYIL#ZIjAFlPFuO2VqOl294SqvQ
I simply copied all files (excluding 'recovery110#') on my FAT32 usb and launched the MCU update from the MMI.
After that, I installed the CUST they suggested: EW_E_V1.6.9R2_n.
This version has been posted already on this board, but I'm providing the same link they gave to me.
https://mega.nz/file/eYgnDRxb#bgq5UA...1A-JXHj3QXpNLI
I just copied the two files in the USB and launched the system update.
After that, I completely re-paired my phone with the MMI (full reset of bluetooth, WiFi and Android Auto). The system was really responsive. This is the final result.
Note: after the update, my hardware version changed from BMW_EVO to B_E. I guess this is the new denomination for the EVO hardware in modern MCUs.
I hope this was helpful.
fe7565967.00
andream, android, android auto, apple, carplay, mmi, retrofit
