| 03-24-2023, 05:27 PM | #11551 |
Rep 2,615
What did you do in Bimmercode? What lines did you code?
| 03-25-2023, 08:12 AM | #11552 |
Rep 18
| 03-25-2023, 01:31 PM | #11553 | |
Rep 2,615
CDMM_AUX_HU and set to AKTIV CDMM_ANALOG_AUX and set to AKTIV CDMM_AUX_SIMPLE_1 and set to AKTIV Also, do you have MOST? If yes, did you transfer them?
| 03-26-2023, 07:14 PM | #11554 | |
Rep 5
Strangely the HW Version changed following the upgrade of my unit, so I'm not sure how relevant this is. |
| 03-27-2023, 06:59 AM | #11555 | |
Rep 2
While driving, the box seems to lose connectivity to the iPhone. What fixes it, is to enter the bluetooth settings on the iPhone, disconnect from CarPlay from the device and connect again. This happened 4-5 times already while driving. |
| 03-27-2023, 01:04 PM | #11556 |
Rep 20
Hi All! I ordered a Carplay box from Ebilaen store in Aliexpress for BMW F10 with NBT, it behaves strangely. The sound and image disappear, it seems to be rebooting. What can this be related to? Maybe there's a new firmware version?
https://youtube.com/shorts/UL1PfVrs72A?feature=share
B47
| 03-27-2023, 05:39 PM | #11557 |
Rep 21
Hello, so I finally got everything installed and it seems to be working correctly but I was wondering if there was a way to to play music through bluetooth instead of through the MMI (aux)? I'm using Android Auto and I tried searching through this thread and am reading but that some people are able to do this to utilize their HK systems? I can't seem to locate any settings in the MMI or on AA on my phone that would allow me to do this.
Thanks |
| 03-27-2023, 06:35 PM | #11558 | |
Rep 1,143
i used to do this on my iphone and worked fine but if you do this, then some settings will not work - ie - having txts being read - siri (iphone). |
suremang3.50 |
| 03-28-2023, 04:19 AM | #11559 | |
Rep 26
| 03-28-2023, 08:41 AM | #11560 |
Rep 2
DIP Switch Settings
I have a 2012 X3 F25, which for some reason has CIC I-drive Software but the screen and Head Unit have NBT connections... I think my car was produced in the middle of a face lift or something.
![]() I just installed a Chinese MMI box from Streamline Coding and the Dip Switch settings for either set up (CIC 0001000 or NBT 11000000) did not work, but when used a combination of the two (11010000) the thing started working! Then found I can make it work with 01010000! SDK: 25.0.0.7.0.0.2.0 Cust Ver: EW_B2_1.6.9R3_n MCU: 22.10.10.110 HW: B_N2_1_G I have no clue what I need to do to make sure that is isn't screwing something up in the car ![]() Last edited by bates_1986; 03-28-2023 at 08:46 AM.. Reason: Added MMI detail |
| 03-28-2023, 09:55 AM | #11561 | |
Rep 2
Turns out my car is CHAMP2, but the MMI box is still working |
| 03-28-2023, 10:12 AM | #11562 | |
Rep 20
B47
suremang3.50 |
| 03-28-2023, 11:52 AM | #11563 | |
![]() 54
Rep 63
There are problems with iPhone X and XR. There still hasn't been a solution...
Did my post help you? Please appreciate post.
| 03-30-2023, 10:45 AM | #11564 |
Rep 47
Is any one know how to fix a little flatened ratio on original wide screen on Android auto with mmi box?
| 03-31-2023, 03:15 PM | #11565 | |
Rep 2,615
If you have a retrofit OEM screen, you may not have the proper screen resolution. There are two resolution settings in the BMW coding for the 10in OEM screen. Another possibility is the MMI box DIP switch settings. The manual is not always correct. You need to check your MMI brand name and model number. Like here: https://f30.bimmerpost.com/forums/sh...ostcount=11653
| 04-01-2023, 01:35 AM | #11566 | |
![]() 54
Rep 70
They're found in the MMI "Carplay" settings, I think. I will check on my car later at home to see the exact numbers I have for each of those. |
Domih54.00 |
| 04-04-2023, 05:05 AM | #11568 | |
Rep 26
Settings - Bluetooth, delete the previous Bluetooth pairing records, The pairing record before setting-general-carplay-delete. Phone Settings - General - Reset - Reset Network Settings, and then restart the phone. It can be completed by re-pairing Bluetooth on the main interface of the system. |
| 04-05-2023, 02:30 AM | #11569 | |
![]() 54
Rep 63
I have spent many many hours on the problem, and there hasn't been a fix yet. It's only on iPhone X and XR. Other phones work perfectly, on the same MMI. People don't really have iPhone X and XR anyways anymore
| 04-05-2023, 05:54 AM | #11570 |
![]() 2
Rep 65
So, I have developed a fault after the box has been working pretty well over many months. I cant seem to connect to the box automatically anymore. I have to reboot my phone, not sure if its down to the latest android auto update or what, Once I restart my phone then the screen will flick over and I get a connection. Prior to me restarting the phone I can see that the phone (google pixel 7) has connected to the box EW-xxxxxxxx in Bluetooth but I just don’t get the screen flicking over from the BMW menu like it used to. If I flick over manually by pressing the menu button the screen just has the MMI menu displayed indicating that a successful connection has not taken place. Has anyone had a similar problem ?
Many thanks. |
| 04-05-2023, 06:01 PM | #11571 | |
Rep 28
It looks so bad, that I'm going to get rid of the camera and go back to the stock display. |
| 04-06-2023, 01:22 AM | #11572 | |
![]() 54
Rep 63
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
