| 04-14-2023, 02:05 PM | #11595 |
Rep 1
DIP switches combination
Hello guys,
I ordered from android-car-dvd.de, a MMI box for a BMW 320D F31 with NBT. I received the box few days ago and I managed to install it in my car. Now everything woks fine, but I had an issue when I was installing it. I have assumed that the dip switch combination is 11100000, but the screen was black when CarPlay was active. I asked Tang from ewaygps.com to help me and he told me that the dip switches combination is wrong, the correct one is 00000010. The box model is EW-LBMCP-NBT02B and this is the firmware version: SDK Version: 54.0.5.0.2.0.0.2 CUST Version: yŚ_v1.15 MCU Version: 1c0315 Have any of you seen this firmware or this dip switches combination? |
| 04-15-2023, 02:23 AM | #11596 |
![]() 54
Rep 70
I have a setting of 40 for each of the Left and Right Scrap options, looks good to me. I have the 8.8 inch screen.
| 04-15-2023, 03:34 AM | #11597 | |
Rep 6
Hope yours worked out too. ![]() |
| 04-15-2023, 01:10 PM | #11598 |
Rep 4
Hello, I need some help.
Apologies if the answer to this is somewhere within this thread, I did a search but did not get any information. I have a 2015 F31 with ID4 NBT EVO. I have just temporally installed the MMI box and did a power up test. The Idrive all works as normal however when switching to the MMI via the long press via the Menu button all it says is NO SIGNAL Key points F31 ID4 NDT EVO MMI Unit EWM-BMCP-EVO-A (on the cardboard box) EVO-LS-G-NS (on the actual unit) Switch setting currently at 123 ON the rest OFF My concern is the MMI unit is not compatible with my car configuration and the next question is there anything that can be done if this is the case? Any help or pointers are greatly appreciated. Thanks Rory Last edited by Roryuk; 04-15-2023 at 07:34 PM.. |
| 04-16-2023, 02:45 PM | #11599 |
Rep 18
| 04-16-2023, 02:50 PM | #11600 | |
Rep 43
| 04-16-2023, 08:40 PM | #11601 | |
![]() 54
Rep 70
But the reason that I have the high numbers there are to correct the stretched perspective look of Android Auto. Instead of just 'scrapping' the pixels it seems to actually reduce the resolution / number of pixels available for Android Auto to display, so it can fix the stretched / incorrect perspective look. If you don't have any of the issues above, all of the scrap settings should be at zero, I think. |
| 04-16-2023, 08:55 PM | #11602 |
Rep 85
![]() Probably a mute (pun intended) point, since its likely a hardware limitation, But is it possible to get the volume indicator to show up over the CarPlay screen? |
| 04-16-2023, 09:16 PM | #11603 |
Rep 1,143
| 04-17-2023, 09:49 AM | #11604 | |
Rep 4
All, looking into this some more I think the box I have is for ID5/6, although I cannot seem to get the code I quoted above match any information. Can I do anything to make it work, I.E is it a difference in wiring or hardware/software? Thanks for your help |
| 04-17-2023, 10:34 AM | #11605 |
Rep 36
Drives: BMW 328XI and X7 M50i
What do I need for Update ? Help!
| 04-17-2023, 11:59 PM | #11606 | |
![]() 67
Rep 81
Your software is relatively old , and under normal circumstances, you do not need to update it, and it may cause system abnormalities.![]() |
| 04-18-2023, 09:43 AM | #11607 |
Rep 21
I'm sure this has been covered but 530+ pages...
Wife's phone has a known issue with Bluetooth and BMW systems (pixel 7). Lots of possible solutions posted to improve but no real "fix". With an MMI unit, does the phone connect to the MMI only or does it still connect to the factory Bluetooth for sound? Also, is there a current preferred vendor on Ali Express or are they all basically the same? |
| 04-18-2023, 08:37 PM | #11608 | |
![]() 54
Rep 70
If you have newer versions available, could you please make them available here? |
| 04-18-2023, 11:49 PM | #11609 |
Rep 12
Does anyone know how to route the audio through main car Bluetooth? The audio on aux sounds horrible.
There is a setting which allows you to route calls through main car Bluetooth. Surely there must be a work around to route main audio through car Bluetooth as well? I am using android auto |
| 04-19-2023, 01:24 AM | #11610 | |
![]() 54
Rep 63
Wire harness is the same. There is no way to make it work
Did my post help you? Please appreciate post.
| 04-19-2023, 01:47 AM | #11611 |
![]() 54
Rep 63
I have the upgrade file to enable HDMI on the new MMI's
It can be find in the same folder as other updates I've collected over time. Don't forget: Updating is on your own risk. Be cautious with updates. There isn't much quality control and it's not monkeyproof. https://102435.sharepoint.com/:f:/s/...960Xw?e=fEgw5m
| 04-19-2023, 03:47 PM | #11612 |
Rep 4
| 04-19-2023, 11:35 PM | #11613 |
Rep 15
Hey friends,
I have bought NBT box for my BMW F30. Everything has been fine since installing the box. After adding the carplay function, it is much more convenient than before. I love so much. But lately I've been running into a problem a lot...sometimes my iPhone 13 won't connect to the box automatically. I need to connect manually. I don't know if I need to set something. I thought if someone had this problem, they might be able to help me. Have to mention that I really like the mirror link of the box. Like a car computer. Umm... the only problem is the connection, everything else is fine. Yes, I would still recommend andream's products, also called ewaying.de. |
| 04-20-2023, 06:08 AM | #11614 |
![]() 11
Rep 35
| 04-20-2023, 06:11 AM | #11615 | |
![]() 11
Rep 35
| 04-20-2023, 06:12 AM | #11616 | |
Rep 26
| Bookmarks |
| Tags |
| andream, android, android auto, apple, carplay, mmi, retrofit |
| Thread Tools | |
