BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      06-25-2025, 12:59 AM   #13663
arsenal6
Drives: bmw 428xi
2015 bmw 428xi  [0.00]
Are there newer boxes with more features now? I got mine about 2-3 years ago
      06-25-2025, 03:46 AM   #13664
F10Rub
Drives: BMW F10
Originally Posted by F10Rub View Post
Hi, today I installed mmi from carlinkit to my 2016 f10. All is working pretty good. The only issue I have is loosing the sound from bluetooth while entering the AA. So for example I am listening to a song in youtube with bluetooth, after entering the mmi interface its still playing, but when entering the AA the sound disappearing. I guess newer models using cars bt for sound, but not able to do so on my car. Searched a lot, but cannot find any info. Attaching the version of soft of my mmi.
I checked the forum and other people also facing the same thing. Someone was able to resolve this issue? I checked my mmi and there is only use phone BT which is switched to on, but still cannot use BT audio for songs, but able to use car BT for calls
      06-26-2025, 05:34 AM   #13665
JankyLV
JankyLV's Avatar
Drives: F34, i3
Had a similar problem a few times - in my case it resumes playing if i press the media source (mode) button on the steering wheel 2 times. It switches from bluetooth to fm radio and back, and then it works.
      06-26-2025, 11:54 AM   #13666
F10Rub
Drives: BMW F10
Thank you for response. I will try it, just wanted to understand if my mmi software has BT audio support or not, cause in the manual also it is saying to put the channel to AUX IN, but oem BT calls are working ok. Also does Carlinkit has newer soft version that I have?
      06-26-2025, 03:40 PM   #13667
F10Rub
Drives: BMW F10
I tried, but didnt work that way also. Seems it has no BT audio option. Can someone please share newer CUST than mine for Carlinkit? (Mine is 9.6.8.yl.b2) are there a version to activate BT audio also along with BT calls?
      06-27-2025, 03:42 AM   #13668
feralejav
Drives: BMW 535iA xdrive (F10)
Your version is current and allows Bluetooth connection.
You have to connect the car's Bluetooth with the phone, connect the phone via Bluetooth with the mmi box, configure the two options in the mmi box menu to "on", and select the bluetooth multimedia channel in Idrive. Then press "back" for two seconds to restart everything and it should work.
regards
      06-27-2025, 05:50 AM   #13669
F10Rub
Drives: BMW F10
regards
Many thanks for the response, the connections are the same way as you described, the only thing is that in MMI settings there is no 2 options for bluetooth. Its only one saying "Use car BT phone" which is ON and I guess it should be also present "Use car BT channel" something like this which I am not able to see. I tried to put as off the first one and restart so the second option appears (noticed that way in the forum), but thats not the case it is not appearing
      06-27-2025, 07:05 AM   #13670
F10Rub
Drives: BMW F10
So I just tried the way you told. First I unpaired all connections then connected to cars BT after that connected to MMI BT and selected ON the only bluetooth option in mmi. After that choosen the multimedia BT and by pushing back button restarted everything. In phone bt connection settings it is showing that both car and mmi connected for calls and audio, but still cannot hear the sound ( I also tried the same with mmi bt option off and in that case not able to choose calls and audio for mmi its only calls possible to choose without audio on the phone bt settings). When changing the source in car to aux in the sound appearing immediately. Please let me know if I am doing something wrong
      06-29-2025, 07:25 AM   #13671
mamudo
Thanks this will help
      06-29-2025, 01:15 PM   #13672
muniz_ri
Drives: BMW 320I
I messaged Carlinkit last year about the option to use BT for media instead of Aux. They confirmed that they have not implemented that feature.
      06-29-2025, 01:47 PM   #13673
F10Rub
Drives: BMW F10
Got you, thanks for the response. At least now I know why it is not possible. I guess no chance they will send any update anymore.
      06-29-2025, 10:17 PM   #13674
muniz_ri
Drives: BMW 320I
Yep. I got the impression they weren't really interested in supporting their unit anymore.
      07-01-2025, 06:02 AM   #13675
SuspecTARX
Drives: BMW F30 330d
Wondering the same thing, anyone got any info on this?
      07-05-2025, 01:47 AM   #13676
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Yes, Carlinkit is MIA. Seems like they abandoned the MMI and went balls deep with dongles to convert wired factory CarPlay and AA to wireless.
      07-05-2025, 02:04 AM   #13677
fe7565
fe7565's Avatar
I think the latest supported/updated/improved MMIs in the $200-300 range are Andream. Check out their website.
      07-05-2025, 02:17 AM   #13678
fe7565
fe7565's Avatar
I have a Carlinkit 9.6.9r1 for the B2 version, but I cannot vouch for it nor do I know what new features are on it, if any. So if you try it, install at your own risk. Read the thread for the install procedure and the risks involved. Use a quality/brand name USB drive FAT32. I had issues with a PNY Attache USB drive, and do not use it anymore for this.
https://mega.nz/file/VgZEgDZZ#hstPjQ...LHRR1djymhSrVw
      07-05-2025, 02:43 AM   #13679
fe7565
fe7565's Avatar
Originally Posted by londospark View Post
Hi, does anyone know which box I have based on the software? I bought it form BM Performance and they installed it for me so I don't know which I have. Are there any updates and is there anything that my garage would have to do to get a service to update on my car?
I do have access to the USB port (and there is HDMI in case that makes a difference) if there are any updates.
Many Thanks
Based on the first page of this thread, you have:
Andream B2-Version [2] [NBT]
Model: AN-BMCP-NBT04X
Based on the first page, the earlier B2 version 1 and version 2 were not compatible with each other, but if I remember correctly, that latest firmware is the same for the "n" and the no "n" version of the CUST firmware.
lcbmw2e_n客户版EW_B2_1.6.16R4_n
There may be newer ones, but this is the latest one I have. This one has full bluetooth instead of AUX-IN for audio. Install at your own risk. Read the thread for the install procedure and the risks involved.
Use a FAT32 formatted quality/brand name USB drive, 32GB or less. Use the ISPBOOT.bin file on the root directory.
https://mega.nz/file/M9YDAQYL#4z-Zfb...GnH79kcvzDLb_I
      07-05-2025, 09:44 AM   #13680
Truthrider
Drives: BMW F36 440i
Originally Posted by audibert View Post
I have his latest MMI v7 unit on my F31
I thought this MMI only works in an i3? Are the buttons at the iDrive controller working as well? That seems to only work with BimmerTech's MMI so far, not the chinese ones.
      07-05-2025, 11:11 AM   #13681
fe7565
fe7565's Avatar
Andrean has some me sort of a new DSP amplifier that is losless and directly interfaces to most BMW’s. They claim it’s worth $1000 but free if you buy one of their MMI products.
https://www.android-car-dvd.com/_t/c...iOg_vOy1LdZg==
      07-09-2025, 03:51 PM   #13682
F10Rub
Drives: BMW F10
Thank you very much, generally I am happy with my unit, the only thing I wanted is the bluetooth audio which seems not possible to have on it based on some comments here and as carlinkit told it directly.
      07-10-2025, 02:44 AM   #13683
SuspecTARX
Installed a firmware update on my RoadTop mmi box yesterday, definitely some new options have popped up, haven't checked them all, however I am now able to hear Waze directions/alerts when listening to music through BMW BT, don't have to set it to AUX anymore and loose the sound quality. My mmi box is also around 3 years old and I am using Carplay
      07-10-2025, 03:21 AM   #13684
arsenal6
Drives: bmw 428xi
Yeah I think andream had that feature a while back. But it had mono audio, did you have that problem?
andream, android, android auto, apple, carplay, mmi, retrofit
