BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      04-28-2020, 04:00 PM   #1673
cossie1
Drives: 2015 F82 M4
Originally Posted by muniz_ri View Post
Thank you for this.
For everyone's knowledge...it seems that Bimmertech began locking down their updates with this version (10.2.18.15). I changed the MCU name to upgrade.bin and flashed it onto my Carlinkit unit. The screen turned black and the unit became completely unresponsive.
Flashed back to the latest available Carlinkit MCU and all is good once again.
Well that saves me a job of trying it then
x-m4n146.50
      04-28-2020, 04:09 PM   #1674
Minims
Drives: F54 Cooper S
Ok So it seems the last BimmerTech MCU update we can use on an Andream Unit is the one from 4.1.2020 ? Or this for Carlinkit only ?
      04-28-2020, 04:12 PM   #1675
cossie1
Drives: 2015 F82 M4
It's the same as the carlinkit mcu and yes you can use it on the andream unit.
      04-28-2020, 04:24 PM   #1676
muniz_ri
Drives: BMW 320I
Originally Posted by Diirek View Post
Soooooo.... I loaded the update, connected to iDrive bluetooth, reset everything and made my first successful phonecall with no echo. The call is being routed through the iDrive but is still being controlled through AA.
Say what you will about Bimmertech, but we've been troubleshooting this issue for almost a week now. The best part is that they're taking my input/suggestions and we've come to a working resolution.
I only had a few minutes to test but so far didn't run into any bugs. Link to the download is here:
https://drive.google.com/drive/folde...CAFsdAcMzohc6Q
I'm probably not supposed to be sharing this beta update, so please use at your own risk. Once again, this is for the Bimmertech MMI Prime running the latest MCU I shared a few pages back.
Do you know if they completely disabled the mmi's bluetooth signal or somehow just gave the iDrive bt priority over the mmi's bt signal?
      04-28-2020, 04:29 PM   #1677
corduroy
Drives: '16 X5 xDrive40e (F15)
How can you tell if the phone call is going through idrive and being controlled through AA? I want to try something and just want to be sure. Thanks!
      04-28-2020, 04:50 PM   #1678
Diirek
Diirek's Avatar
147
Drives: E93 M3, G05 X5 xDrive50i
It seems like they disabled the autoconnection of the bluetooth that happens when you connect via usb (or wirelessly).. I deleted the mmi from my list of bluetooth devices and it no longer connects.
Looking at my phone when I'm connected, the only bluetooth connection is to my iDrive.
corduroy115.00
      04-28-2020, 04:53 PM   #1679
Diirek
Diirek's Avatar
147
I tried to make a call before reconnecting to the idrive bluetooth to see if it would work over usb, but it only gave me an option to use speakerphone on my phone.
Once i connected BT to my idrive, it worked through my car audio again.
Also, when i was making calls before with the echo, the sound quality was not great - it popped and cracked. Now it sounds much better, just like it did before i installed the mmi.
      04-28-2020, 05:01 PM   #1680
muniz_ri
Drives: BMW 320I
That makes sense. I was wondering if the bt "auto-connection" was an android function or a function of the mmi. Sounds like it's a function of the mmi which is how they were able to turn it off.
I had my mmi in a faraday bag for a while but it apparently wore out and stopped blocking the mmi's bt signal. While it worked, I was able to make and receive calls exclusively over the iDrive bt connection and control the phone using either the iDrive menu or the mmi. It worked very well which sounds like your experience now with this beta update.
      04-28-2020, 05:05 PM   #1681
Len_Beach
Drives: 435d
Has anyone tried to update the Boot and/or CarPlay logos?
I was playing with settings today and noticed the options in settings.
      04-28-2020, 05:11 PM   #1682
corduroy
That's great, thanks! I just tested it on my phone and while connected via USB, I disconnected the Bluetooth from AA and it made the call with idrive and showed in AA (also said that Bluetooth was disconnected). But yeah, AA kept on reconnecting Bluetooth. Hopefully this makes it to the other units (I think it will).
      04-28-2020, 05:18 PM   #1683
Unspec
Unspec's Avatar
1481
Drives: 2015 BMW 535xi
Thank you for this.
How did you force update the MCU?
      04-28-2020, 05:23 PM   #1684
muniz_ri
Drives: BMW 320I
Thank you for this.
To flash back the compatible mcu you insert the usb stick and press and hold the back button until it reboots. It will automatically flash the mcu file from usb.
      04-28-2020, 05:27 PM   #1685
Unspec
Unspec's Avatar
1481
For me it just goes straight to "Invalid update" screen :/
      04-28-2020, 05:28 PM   #1686
Diirek
Diirek's Avatar
147
I tried your recommendation of the faraday bag but couldnt find a good way to seal it with all of the cables and it def didn't block the BT connection. There was no way I was pulling out my glovebox again unless it was to pull the mmi out to return the f$cking thing...
      04-28-2020, 05:30 PM   #1687
muniz_ri
Drives: BMW 320I
You likely have to wait until the car goes to sleep or pull out then plugin the can/power plug from the mmi before rebooting.
      04-28-2020, 05:32 PM   #1688
muniz_ri
Drives: BMW 320I
The faraday bag wasn't the ideal solution. The extra heat will likely shorten the life of the mmi's components.
      04-28-2020, 05:47 PM   #1689
Unspec
Unspec's Avatar
1481
If all we're doing is cycling the power it seems much easier to just pull the battery for a hot sec. Gonna try that before I rip my dash apart
      04-28-2020, 06:04 PM   #1690
muniz_ri
Drives: BMW 320I
That should work. Insert the usb stick before plugging the battery back in then turn on the car and hold the back button for about 5 secs.
      04-28-2020, 06:11 PM   #1691
Unspec
Unspec's Avatar
1481
Same deal unfortunately. I suspect my device is well and truly bricked.
      04-28-2020, 06:14 PM   #1692
muniz_ri
Drives: BMW 320I
I doubt it. I have soft bricked after flashing both the Bimmertech ispbooot and mcu and have been able to recover every time. But it sounds like you will have to take apart your glove box.
Also, try reformatting the usb stick and try again.
      04-28-2020, 06:14 PM   #1693
cossie1
Drives: 2015 F82 M4
Power the car off, let it shutdown (you will hear the MMI click when it powers down).
Then put the usb stick in, and then press and hold the back button before you turn the ignition on.
Wait until you hear the unit click and then release.
BTW I could only get this method to work using a 16gb usb stick, it wouldn't do it with my 32gb or 8gb stick.
      04-28-2020, 06:28 PM   #1694
Unspec
Unspec's Avatar
1481
How did you recover? I updated to the last working versions of bimmertech software and mcu before updating to the new locked MCU, I wonder if that makes a difference.
andream, android, android auto, apple, carplay, mmi, retrofit
