| 04-22-2016, 09:52 PM | #1079 | |
Rep 20
It's perfectly safe to leave the car only with ignition on, since even if the car goes to sleep mode update will continue where it stopped once the power is restored. |
FlorinQCK-2.50 |
| 04-25-2016, 07:47 AM | #1086 |
Rep 48,899
0x47 0x27
![]() 2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
FlorinQCK-2.50 |
| 04-25-2016, 07:54 AM | #1087 |
![]() 68
Rep 263
We have a BMW with CIC in the family and 64Bit Win7 computer. I'd like to update to 2016-2 map.
Which program is best choice? I've already tried FSC.exe, but it didn't work as it probably needs 32Bit computer system. I already have the car's FSC grabbed via Esys. Is it still not possible to have Premium Europe West + East maps at same time on CIC? |
FlorinQCK-2.50 |
| 04-25-2016, 07:57 AM | #1088 | |
Rep 48,899
No, you can only have either West or East installed at any given time.
FlorinQCK-2.50 |
| 04-25-2016, 10:34 AM | #1089 |
![]() 68
Rep 263
Thanks Shawn!
FSC.exe really works on 32bit Windows? Hmm, have I done something wrong? Got orig. FSC via Esys, saved as xy.fsc in same directory as fsc.exe is. Then DOS input: C:>fsc.exe xy.fsc 0028 0x27 [7-digit VIN] |
FlorinQCK-2.50 |
| 04-25-2016, 11:02 AM | #1090 | |
Rep 48,899
If program runs without error, then it is compatable with Operating System. Now if you run program and get no code, or wrong code, then the issue is something with your process, and not the program itself.
FlorinQCK-2.50 |
| 04-25-2016, 12:30 PM | #1092 |
Rep 48,899
No idea then. It should work just fine.
FlorinQCK-2.50 |
| 04-26-2016, 11:07 AM | #1093 | |
Rep 2
I have a E87 with 2010s maps which i would like to update. I've already downloaded the maps but am unable to pull the fsc-file from the car. For diagnosis etc. i am successfully using ediabas / inpa with the obd connector. From what i've read online i can only pull the fsc through an ENET cable, which i have purchased and tried. I have made according changes to the ediabas.ini (both manually and with a configurator software). I have tried several different IPs, the closest i could get to accessing the cars computer was an error message, that password or username was incorrect. But what puzzles me is this: In windows, under network and adapter settings it says that i don't have network connectivity. Is there anything else i need to make sure? Something more basic, like only allowing for ipv4 and not ipv6, setting the LAN network in some specific way? I feel like my problem is in the network settings, since even itoolradar doesn't show any IPs. I hope you can help me out, i have tried to access the fsc through browser, filezilla and the SWID software, additionally tried it under linux, but no luck. Maybe you can give me an idiots step-by-step instruction on how to get this file? That would really help me out!!! ![]() Many thanks in advance! |
FlorinQCK-2.50 |
| 04-27-2016, 05:47 AM | #1095 | |
Rep 2
One question: You said you generated the 1B File for your F30, but in the SWID software you checked E-Series. Is that right or do you actually have an E-Series BMW? In both cases: What were your network settings in windows? (e.g. in adapter settings did it show you were connected to a network? was it a private 'home' network or anything else? In what order did you set it up to achieve connectivity: Plug in cable -> turn on engine -> turn on LAN?) Many thanks in advance for your help and greetings from Germany! |
FlorinQCK-2.50 |
| 04-27-2016, 05:25 PM | #1096 |
Rep 3
Hi Guys, I have the 1B file for my 2013 F30 CIC and I used base64 to convert it. When using CIC/NBT FSC code generator I get the 20 character code followed by two vertical bars that look like ||
The code does not work for Premium NA 2016 maps, wondering if I have a corrupted utility or lookup.xml? |
FlorinQCK-2.50 |
| 04-28-2016, 07:08 AM | #1097 |
Rep 11
Do I need to edit any files before the software works? SWID and Esys both don't seem to be able to connect to the car. I bought the ENET cable and I'm running a 32bit windows XP in VMWare ( mac osx). In OSX I see the ethernet cable has a self assigned IP.
FlorinQCK-2.50 |
| 04-29-2016, 02:36 AM | #1100 |
Rep 11
I've made progress: was an misconfiguration in VMware.
Used Esys and was able to Store FSC. Afterwards I opened DOS and used 'nbt.exe xxxx.fsc 0xA8 0x27' I got a code, but however the car says it's wrong.. Updated yesterday, (no code asked), but when starting the car this morning it asked for a code. I noticed there was a lookup.xml file in that folder as well( where nbt.exe is). However I did not change anything in that file. Do I need to make changes there too beforehand? Is 0xA8 and 0x27 correct? For Europe Next 2016-2 |
FlorinQCK-2.50 |
| Bookmarks |
| Thread Tools | |
