09-21-2018, 04:39 PM | #419 |
Rep 2,382
Only time that happens is if you click "Request Update" and you've communicated beforehand that the tuner has to touch your file.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
Solidjake945.00 |
09-21-2018, 05:01 PM | #420 | |
¯\_(ツ)_/¯
945
Rep 1,762
09-26-2018, 07:04 PM | #421 | |
Rep 482
Drives: 2014 Glacier Silver F30 328i
http://www.bootmod3.net/log?id=5bac1735d10b435c56a387f7 http://www.bootmod3.net/log?id=5bac165bd10b435c56a387f5 http://www.bootmod3.net/log?id=5bac1605d10b435c56a387f3 http://www.bootmod3.net/log?id=5bac155ed10b435c56a387f1 And of course I always log my data in Mexico City, Mexico
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
09-26-2018, 07:32 PM | #422 | |
Rep 3,680
And, in my non-expert opinion, it looks good data wise for the most part too. AFRs are good, timing isn't perfect but it rarely is, and most other critical values look good. There's just one thing I'll comment on: you are a little bit further from the boost target than what I think is ideal. Naturally you won't be at target all the time, but you should be within 1-3 psi at more or less all times. Your MAP pressure is pretty consistently between 15-17 which is about 5-7 psi below target. It's really easy to visualize this if you click on all other values at the bottom to remove them to leave just rpm, boost target and MAP psi. You can also look at the boost deviation to get exact numbers. I'd hesitate to say it's an issue, but we'll let others chime in and see what they have to say Other than that, I can't find any big problems (not that that's a big problem).
09-26-2018, 07:37 PM | #423 | |
Rep 482
09-26-2018, 08:56 PM | #424 | |
Rep 3,680
At this point I don't think there's anything remedying for you to do, as there's most likely a tune or hardware issue. My first guess would be boost leak, but it looks like at points you do come close to the target, which I would imagine is impossible with a boost leak. However, it still would be a good idea to check FMIC connections, and pretty much all other charged air pathways for obvious malfunctions. Take a look at your turbo housing too just to be extra careful, but I highly doubt you'll find anything there. So that said, it could be either a tune or hardware issue, I'm really not sure... I don't want to guess at what it is so as not to mislead you, so hopefully someone will chime in with some answers.
09-26-2018, 09:07 PM | #425 | |
Rep 482
09-27-2018, 06:23 AM | #426 | |
Rep 3,680
09-27-2018, 07:41 AM | #427 |
Rep 482
I know that about the condenser LOL
rjd_F301999.50 |
09-27-2018, 09:03 AM | #428 |
Rep 2,382
Yeah... May want to look for a leak. You can always request an update from PTF just in case, but your log looks like everything is in place to make target.
09-27-2018, 09:10 AM | #429 |
Rep 482
09-27-2018, 09:11 AM | #430 | |
Rep 2,382
You can email PTF and open a ticket as well. Let them know what you're seeing and see what they have to say.
09-27-2018, 09:24 AM | #431 |
Rep 482
09-27-2018, 09:46 AM | #432 |
Rep 1,397
I too was doing logs last night, but noticed an error pop up mid stream. Little did I know it would not continue logging. Wasted ten minutes, got frustrated, quit.
While I was eyeballing (more passenger than I) I saw boost often reaching 19.7 lbs and IAT's at WOT were 9-11 degrees above ambient. Pretty pleased. |
09-27-2018, 09:59 AM | #433 | |
Rep 482
“Stock turbos taper a lot in upper rpm range (I’m not a n20/26 expert tho... maybe they are different) the ots maps target higher boost up there but my understanding is that your logs look 100% normal and you don’t have a boost leak because you hit target boost in lower/mid range and actually overboost a bit, and your map psi matches pre throttle psi. If you want to hold bigger boost all the way to redline you may need to look into a bigger turbo.” |
09-27-2018, 10:24 AM | #434 | |
Rep 3,680
Can't hurt to see what PTF has to say too. |
09-27-2018, 11:51 AM | #435 | |
Rep 482
rjd_F301999.50 |
09-27-2018, 12:23 PM | #436 |
Rep 2,382
There is definitely an issue here. You shouldn't even be in the 16psi range. Stock turbo should only drop to 18psi range.
Here is one of my logs (Yes, not pretty but focus on the WOT area): http://www.bootmod3.net/log?id=5b1bf2dad10b437faba93c3f This was logged pre-big turbo and as you can see, I'm in the 19s/high 18s up top. You should be well above your target, making around 21psi and then dropping to 18 at the very top of the gear. Not sure who that comment was from but being 3-5psi under target is not normal.
rjd_F301999.50 |
09-27-2018, 02:54 PM | #437 | |
Rep 3,680
Here's one of my stage 2 logs, just so you have a little more to compare with: http://www.bootmod3.net/log?id=5b633b12d10b43626a89e7b0 Just keep in mind that you and I are on 93 tunes while Bunker is on a 91 tune, so his boost target will be lower and easier to hit. Same principles still apply, but something to keep in mind. On my log, you'll notice that the lowest MAP psi gets is ~18.5psi, and that's at almost 7k rpms. That's as low as it should ever get, and even that's pretty low for a boost target at 22psi, so 15-16 is really far too low.
09-27-2018, 04:08 PM | #438 | |
Rep 482
09-27-2018, 04:41 PM | #439 | |
Rep 3,680
Go to protuningfreaks.com, bootmod3 drop down menu, contact support, login, tune support, fill in the form and then in the comments section that will pop up after you submit your form, tell them about what's going on. While they'll probably just tell you to check for leaks like we have, it certainly can't hurt to get their opinion. Let us know what they have to say!
09-27-2018, 06:52 PM | #440 | |
Rep 482
bm3, bootmod3 |
