08-28-2019, 09:37 AM | #331 | |
Rep 1,105
Please provide a part number for clarification.
08-28-2019, 03:11 PM | #332 | |
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
08-28-2019, 03:12 PM | #333 | ||
Rep 928
08-28-2019, 08:18 PM | #335 |
Rep 2,357
I am sure the community would only be interested in the HPD6 pump so that is what I will try to source.
Does anyone have information about what part numbers are the HPD6? The one that Thomas is using is 13518631642.
(A Dane in China) |
08-28-2019, 09:31 PM | #336 | |
Rep 1,105
Good luck with your sales but perhaps obtain all the information about the product your hoping to unload to the forum members. |
08-28-2019, 11:18 PM | #337 | |
Rep 2,357
I thought about doing this mod myself and (if possible) help my forum peers also. So the state of this at the moment is "research phase". Is it ok with you that I use the forum to gather info into whether this is feasable at all or do you just want to kill the initiative???
(A Dane in China) Last edited by harkes; 08-28-2019 at 11:24 PM.. |
08-29-2019, 12:04 AM | #338 | ||||
Driver
200
Rep 516
Pittcrew34.00 |
08-29-2019, 12:45 AM | #339 | ||
Rep 4,516
https://www.bosch-mobility-solutions...pressure-pump/ According to realoem - part no 13158631642 can be found on the following bmw / mini models:- https://www.realoem.com/bmw/enUS/par...;q=13518631642
Current '22 X3M LCI.. |
08-29-2019, 09:37 AM | #340 | |
Rep 1,105
No need to get your panties in a bunch over a discussion but yes, you have my blessing to research as much as you need lol! Best of luck with your sales!
09-01-2019, 02:42 PM | #341 |
Rep 282
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
e46m3to335i171.50 |
09-01-2019, 04:22 PM | #342 | |
Rep 153
09-02-2019, 01:54 AM | #343 |
Rep 14
If you made a plug and play for 800usd i would definitely buy one from you harkes
I guess the HDP5evo anyhow would support this map targeting 18.7psi: http://www.bootmod3.net/log?id=5d570723c090c644c52e055e But i rather buy the HDP6 with plug&play from you for 800usd which supports more than the HDP5evo, which costs about 500EU + tax and shipping from Sweden. Currently this map works on stock fueling, but pretty close to missfire on a chilly day. Currently I am running the BM3 OTS Stage 2h where you can also see that the fuel pump is having a hard time: http://www.bootmod3.net/log?id=5d570b1ac090c644c52e0568 Just out of curiosity, when seeing the logs from MHD, i can see that target fuel pressure is 2030psi, but in my logs target pressure is 2884psi. Are these different parameters in mhd and bm3? |
09-02-2019, 03:09 AM | #344 |
Rep 282
they dont come pnp , you will need to adjust the flange since orientation is different and make two slots for the bolts . also depending on your cars build year you might need a different connector , third , if you dont adjust the connector and intake manifold you will create a lot of stress on the connector itself . with this pump you can use oem fuel lines , but have to adjust them slightly because in and outlet are a few mm up compared to oem .
09-02-2019, 04:16 AM | #345 | |
Rep 14
As i understand from your two DIY guides retrofit to HDP6 is a lot more complicated than the HDP5evo? Guess HDP5evo would be the best choice as I will be running 98/93 oct pump gas as I dont have access to ethanol. After reading through this thread I understand that HDP5evo is capable of supporting up tp 19PSI on pump gas. I just want to run 20 more HP, and i will certainly not pay XDI 2000EU + tax(25%) and shipping for that. Nice work on this thread Thomas Last edited by Zadikiel; 09-02-2019 at 04:23 AM.. |
09-02-2019, 04:30 AM | #346 |
Rep 282
the evo pump has better orientation of the connector , but work to the flange is the same as with hdp6 . if you are planning to do it , i would go for hdp6 anyway . its only a bit work extra but far more worth it , the test speaks for itself , ive tried e20 on the evo pump but that didnt work at all . i would also recommend a custom tune and some monitoring software to see what your rail pressure is doing hdp6 can go a lot higher
09-02-2019, 04:38 AM | #347 | |
Rep 14
I have Bootmod3, with 1 ots tune and a custom tune from HCP where fuel pressure drops a lot: http://www.bootmod3.net/log?id=5d570723c090c644c52e055e I guess this should be the hdp6: |
09-02-2019, 04:41 AM | #348 |
Rep 282
i found that page a few weeks ago too , requested some info ,
but no answer , i hope you have more luck . i was lucky to find one on ebay shortly after .
09-02-2019, 07:43 AM | #349 | |
Rep 14
Sent him an inquiry so lets see Any tips on how to figure out where to drill holes in flange? |
09-02-2019, 07:59 AM | #350 | |
Rep 4,516
I guess in summary for n55 EWG:- HDP5evo - is more PnP (flange/boot hole tweaks) improves stock flow by ~ 10-15% and requires zero coding HDP6 - needs fuel pipe tweaks in addition to HDP5evo adjustments but delivers an extra ~10% over HDP5evo. Requires coding to cap 350bar down to say 250bar. BP
09-02-2019, 09:08 AM | #351 | ||
Rep 288
09-02-2019, 09:10 AM | #352 | |||
Rep 4,516
