07-18-2018, 03:30 PM | #1850 |
Rep 40,761
Pull DE File from NBT, feed DE File to FSC Gen using parameters 0xA9 0x32.
FlorinQCK-2.50 |
07-20-2018, 02:36 PM | #1851 |
Rep 87
appreciate your help so far. got my dads car to update his maps and he has ROAD MAP EUROPE PREMIUM 2010. I see that there are currently 2018-1 version, however split is West and East. Do I update it to both versions (West and East) or just one?
FlorinQCK-2.50 |
07-20-2018, 05:19 PM | #1852 |
Rep 40,761
You can only load one or the other. U.K. is West.
FlorinQCK-2.50 |
07-29-2018, 12:50 PM | #1853 |
Rep 12
Hi guys, I read in the previous page that the FSC code to update Route Map on HU_EntryNav must be bought from dealer because ASAP access is needed. Something changed or this is the only way to get an activation code for this map? Thank you.
FlorinQCK-2.50 |
07-29-2018, 01:04 PM | #1854 |
Rep 40,761
There is no public FSC Generator for ROUTE Map Update, so you cannot do it yourself. But you do not need to pay Dealer. PM sent.
FlorinQCK-2.50 |
07-30-2018, 06:01 PM | #1855 |
Rep 269
Drives: ///M6 GC
Just wanted to thank all those who posted instructions & what worked for them Most difficult part for me was getting the VIN to show up in E-Sys. Below are the order of steps I think worked for me.
Prerequisite: disable all firewalls, Antivirus & WiFi. Set Ethernet to DHCP (not static) 1. Connect ENET cable to OBD port 2. Connect ENET to laptop Ethernet port 3. Start vehicle (DO NOT step on the brakes, engine does not have to be on) 4. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig 5. Ensure you have 169.254.xxx.xxx IP address for Ethernet 6. Launch E-Sys Launcher (NOT E-Sys) 7. Select Connect 8. Select appropriate Target (based on I-Level) Note: Don’t use _DIRECT 9. Select Connection via VIN 10. Select Connect 11. Click Expert Mode 12. Select FSC Extended 13. Diagnostic Address (hex) = 0x63 14. Click Identify 15. Application Number (hex/dec) – 0xDE 16. Upgrade Index (hex/dec) – 0x1 17. Scroll down & select StoreFSC 18. Select Add to the batch button (>>) 19. Select Read 20. Select Save 21. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc Note: XXXXXXX is the last 7 of your VIN >>> Generating FSC code for map updates <<< 1. Copy NBT.EXE + XXXXXXX_000DE001.fsc to C:\EC-APPS folder 2. Open command prompt & go to C:\EC-APPS folder Type: NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt Ex: C:\EC-APPS> NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt This will create a file called code.txt with the map FSC code inside I used the FSC file as is, did not have to use BASE64 or decode the file. Out of laziness, decided to use a batch file that I used to generate FSC for my CIC Ex: batch file. Note: replace XXXXXXX w/ the last 7 of your VIN ECHO OFF CLS IF NOT EXIST NBT.exe ECHO File NBT.exe NOT FOUND! IF NOT EXIST XXXXXXX_000DE001.fsc ECHO XXXXXXX_000DE001.fsc does NOT EXIST! c:\EC-APPS\NBT XXXXXXX_000DE001.fsc 0xa8 0x32 XXXXXXX > code.txt IF %ERRORLEVEL% EQU 0 ECHO File code.txt was created successfully! PAUSE Place & run batch file in C:\EC-Apps where NBT.exe & your FSC file is located. NBT.exe I have is dated 7/1/2015 (77KB). Seems to be newer than what I found in the ZIP files posted by others. Uploaded all the files I use here if anyone wants it: https://drive.google.com/drive/folde...Nl?usp=sharing >>> Determine Region & Map sequence code <<< Note: requires HxD application: https://mh-nexus.de/en/hxd/ Region & Map sequence code - located in the 1st folder of the map files File path = 1\INFO_MAP_NANT_#####\Info_Map.imp North America NEXT: |
FlorinQCK-2.50 |
08-02-2018, 04:20 PM | #1857 |
Rep 40,761
What is meaning of "sync maps FSC"?
FlorinQCK-2.50 |
08-02-2018, 04:42 PM | #1859 |
Rep 40,761
PM sent.
FlorinQCK-2.50 |
08-04-2018, 08:05 AM | #1860 |
Rep 269
Drives: ///M6 GC
Just curious as to what everyone's procedure is that always shows "Connection via VIN"? vs being grayed out.
I tried this same exact procedure on an 2013 F10 M5 & after 3 tries, it was still grayed out. 1. Connect ENET cable to OBD port 2. Connect ENET to laptop Ethernet port 3. Start vehicle (DO NOT step on the brakes, engine does not have to be on) 4. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig 5. Ensure you have 169.254.xxx.xxx IP address for Ethernet - 1st try the door was left unlocked (everything off) & has been sitting for an hour while the key was at least 100 ft away - 2nd try I locked the door and waited 2 minutes, key 3 ft away - 3rd try I locked the door and waited 5 minutes, key 3 ft away Was in a hurry so I didn't try locking the doors for a longer period of time before trying again (sleep mode) Is that 15 minutes or 30 minutes to enter sleep mode? My initial testing was on a 2015 M6 GC Thanks |
FlorinQCK-2.50 |
08-11-2018, 05:48 PM | #1862 |
Rep 40,761
FlorinQCK-2.50 |
08-12-2018, 11:46 AM | #1864 |
Rep 40,761
Europe is A9, not A8, so 0xA9 0x32.
FlorinQCK-2.50 |
08-18-2018, 07:50 AM | #1866 |
Rep 40,761
0x28 0x32
FlorinQCK-2.50 |
08-19-2018, 07:32 AM | #1868 |
Rep 40,761
PM sent.
FlorinQCK-2.50 |
