BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding error. CAFD not found
      02-20-2019, 07:23 AM   #155
atzebmw
Drives: BMW 335XD F30 LCI
Originally Posted by Giampi.bll View Post
Hello to everybody! I need CAFD file "CAFD_00001EF6_006_27_002" for NBT Evo coding, could someone help me to find it?
I tried with PSdZdata 63.3 and full PSdZdata 4.15.31
Thanks in advance
Choose a new CAFD by detecting CAF for SWE.
So „detect caf for swe“ and code the NBT Evo.
      02-20-2019, 08:55 AM   #156
Giampi.bll
Drives: BMW 318d (F30)
I tried following your suggestion but after clicking on "Detect CAF for SWE" button Esys give an error message, as per attachment
      02-20-2019, 09:45 AM   #157
atzebmw
looks like this was a retrofit?
I searched all my psdzdata collection and didn't find these CAFD.
So the only solution for you is to flash the HU_NBT2.
      02-20-2019, 01:44 PM   #158
Giampi.bll
Yes, the head unit is for retrofit.
I didn't flash before and I hope to be able.
Before flashing HU_NBT2 do I have to flash the ZGW at the same I-Step level I will use for NBT-Evo?
I will use a bench for coding/flashing with an ZFW2 from an F10
      03-07-2019, 08:02 PM   #159
Carlezzy
Drives: BMW F30
Originally Posted by Adamantio View Post
All the other ECU read them quietly, only Dkombi does not read, can someone help me, please?
Did you get your kombi to work I’m having a similar issue.
With the 6wa to 6wb
Esys can find caf from swe.
      05-09-2019, 02:04 PM   #160
Rspec
Drives: 2016 BMW X5 M
same exact issue. how do i update pzdata?
      05-12-2019, 10:56 AM   #161
Freebeeman
Netherlands
Drives: BMW F30 320i
Hello all,
I had retrofit the reverse camera, hardware wasn't an issue, camera was working after VO coding 3AG and coded the rest of the ECU's. only the ECU of the TRSVC couldn't find the correct CAFD, in fact he didn't had any CAFD file.
I tried this option:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired TRSVC => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
But there was the KIS error CAFs for "swf1_00000468-013_002_001 not found, so I looked for the latest PSDZdatabase V4.17.11 Full version and still no CAFD file available.
Can I reset the ECU of the TRSVC or inject another CAFD so I don't have this camera error message on the dash?
      05-14-2019, 07:34 PM   #162
Rin
Drives: 2013 335iX
Hey Shawn new F30 owner, I'm attempting to do some basic Esys coding and am getting the same error as above, would you mind helpng me out with the current PSdZData files?
Thanks so much in advance.
      05-14-2019, 11:19 PM   #163
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by Freebeeman View Post
Hello all,
You need to flash TRSVC.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      05-14-2019, 11:20 PM   #164
shawnsheridan
PM sent.
      05-15-2019, 02:39 PM   #165
Freebeeman
Netherlands
Hello Shawnsheridan,
I tried now for two days to flash, every time there is an error like "VCM isn't updated", then I went 3.32 to E-SYS 3.27 next error "SVK-Ist does not match". So I think I used a wrong I-step.
I'm worried that when I push to far I brick my car.
But thank you for your help.
      05-15-2019, 02:44 PM   #166
shawnsheridan
"VCM isn't updated" is unimportant soft warning. Click past it.
This "SVK-Ist does not match expected SGBMIDs for ecu..." means you have chosen an improper I-Step Shipment when you made your SVT Target (SVT_soll). The problem is that this ECU is not factory original, so ECU I-Step Shipment is different then your car's actual I-Step Shipment, and you have no way of knowing what the right I-Step Shipment is for this ECU.
So, redo flash, but this time after you calculate SVT Target (SVT_soll), check the box that says "HW-IDs from SVTactual" and then Save it. If HWEL is Black only, no Red / Blue HWEL, then you can proceed to flash it.
If HWEL is not Black only, the only thing you can do is try different I-Step Shipment dates until hopefully one works. This is simply Trial and Error.
      05-18-2019, 07:18 AM   #167
Freebeeman
Netherlands
Hello shawnsheridan,
Thank you for the new information.
I tried with almost 10 versions of I-Step (ship), ticket "HW-IDs from SVTactual" and everytime I calculated the I-Sep version without succes.
It's taking almost 5 minutes per calculation and there are at least 30-40 I-step versions, so yes it's trial and error.
I tried without calculating anly ticked "HW-IDs from SVTactual" but I think this not checking if it's the correct version.
I'm going to return the unit and try to find another one that will work.
Thank you very much for your support and effort you put into this, keep up the good work.
      05-18-2019, 07:32 AM   #168
shawnsheridan
OK, good luck.
