BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 OEM Alarm Retrofit (320i/328i)
      05-20-2019, 06:49 PM   #199
anon10
Drives: looking
Originally Posted by david51 View Post
it's because it's activated on the horn and not the siren just activate the siren and deactivate the horn
David51 - Can you explain what you mean here? Is this a coding change? I didn't see anything in the coding that addressed where to activate the alert output, but I'm a coding newbie.
I'm still trying to track down why I get no output from my siren (output to the horn works). I did some additional diagnostic today, and tried a different siren, but that didn't fix it. I still get the fast blink for the first 10 seconds after arming. I am now wondering if I did my siren harness correctly, in terms of whether the wires are in far enough? I've attached a picture. They do click in place, and don't come out, but it also seems like they could go farther in. Is the siren harness like the roof module harness (pic attached) where you have to open the harness up to allow the wires to go all the way in? Using pin probes inserted into the siren harness I do get 12V on pins 1&3 and continuity from pin 11 of the roof module harness on the signal wire.
Thanks!
      05-30-2019, 07:55 AM   #200
BMEU
Drives: BMW 328i
Instruction with photos?
Hello roxxor,
I would like to try out this project myself and wonder if you can send me an instruction with photos.
I see that the posting is referring to pictures, but somehow I don't see them.
Thank you again for a great DIY instruction and hope to hear from you soon.
      05-31-2019, 02:40 PM   #201
BMEU
Drives: BMW 328i
Anyone has this instruction with photos?
Please help!
      06-02-2019, 10:24 AM   #202
BMWMPR
BMWMPR's Avatar
Puerto Rico
77
Drives: 2016 LCI F80
Please help!
Sent to your email. Let me know if you receive it.
      06-02-2019, 12:40 PM   #203
anon10
Drives: looking
Please help!
The photos in the first post still work for me... maybe try a different browser or computer? Here's a direct link to the photos on photobucket:
http://s180.photobucket.com/user/rox...?sort=3&page=1
If you decide to take on the retrofit and need a siren, I've got an extra one that I used for testing. I'll give you a great deal on it, private message me.
      06-04-2019, 04:10 PM   #204
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thanks!
hello
tried to remove the green part to properly engaged the wires
if it is badly nibbled the info is sent to the horn and not the siren
      06-14-2019, 09:33 AM   #205
428iSoCal
428iSoCal's Avatar
Drives: 2014 428i F32
2014 BMW 428i  [0.00]
Hello DIYrs, has anyone completed this alarm retrofit on an 2014 F32?
Also does this DIY include the sonic sensors inside the vehicle?
Purchased an did not know it did not come with an alarm
      09-01-2019, 11:58 AM   #206
Bikbmw07
Drives: 2006 BMW 330i
Excellent DYI sir. I'm currently adding shock sensor to my F80 2016. I have question about pin 11 on 16 pin connector in roof junction. So is the pin 11 the trigger wire? I see that voltage of 13 volts is always present in that wire and on mine it's red wire with black strip and I do have motion sensor from factory already. Also, do you know if there is constant 12v that's always present except the pin 11 on 16 pin connector? I have sunroof as well on the car. Any guidance will be appreciated sir.
      09-09-2019, 03:30 PM   #207
AlbertoSONIC
Drives: 318d F30 LCI
Hi everyone, I'm trying to find the sockets for the wiring to the sunroof plug. (61130005199) I have found 1 on ebay, just 1 for about 10 dollars.
I don't think that it's a bmw proprietary socket, so do someone know where can I find a generic one that fits?
      10-10-2019, 08:58 PM   #208
agilbert314
Drives: F30 328i xDrive Sport 2013
You may go to a BMW dealer for parts. I usually buy them at a better price on ECS Tuning.
      02-27-2020, 10:49 AM   #209
kingofudupi
Drives: F30 328i
BMWMPR Can you please send me the full instructions with the picture as well. I also dont see the pictures in the original Post and the Photobucket link above appears to be not organized per the instruction set.
      02-27-2020, 11:51 AM   #210
kingofudupi
Drives: F30 328i
Hi Guys,
Great forum and I see great detailed work, thank you all. I would like some help with the coding part. Would
roxxor
BMWMPR
Would you be able to help with me with remote coding and I can pay you guys for this. I plan to do this once summer starts here in Michigan. Kindly let me know please?
I see David is in helping out a few folks but he is in France so I am not sure if the coding will be same or similar for cars in US,.
      03-20-2020, 07:04 AM   #211
Siki78
Siki78's Avatar
136
Drives: F30,G30
Hello! Someone has all fdl coding? Or just for nbt because I don‘t want to lose all my coding...
Thanks in advance
      03-22-2020, 03:43 AM   #212
Siki78
Siki78's Avatar
136
Drives: F30,G30
I don‘t have a sunroof but schuld I have connection on pin 1 (ground) and 2( power via F62 30A)on16 pin connector or not? Thanks
      03-22-2020, 06:58 PM   #213
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013, E46 325i 2005
the power supply (slot 2) and the negative one (slot 1)
Gabo
      05-02-2020, 05:48 PM   #214
HanksF32
Drives: 2015 BMW 428i
Need a little help -- installed everything and went to code in e-sys (3.27.1), read and activated the FA, Read the SVT, and found the FZD. The new FZD appears to be several years newer and isn’t playing nice. I have everything wired up and the CAFd files show everything enabled, but I can’t even get the clown nose to blink. Any help would be deeply appreciated.
      06-08-2020, 07:40 PM   #215
Ajdly00
Originally Posted by Gabrielisimous View Post
Yes I got the one you told me and now I'm selling the other which is for a car with sunroof
Originally Posted by Jhnblckwood View Post
Did u end up getting that roof module I sent the link for?
Either way glad u got it working bro
would either of you be able to share the part number for the roof module? i’ve only been able to find ones with the sunroof switch.
      06-08-2020, 07:48 PM   #216
Gabrielisimous
Sure! I'm out of town now but tomorrow I'll check for you
Gabo
      06-09-2020, 02:29 PM   #217
Gabrielisimous
Ok I have this from my module (F30 without sunroof) make sure the module has the sensors as show
Gabo
      06-09-2020, 02:36 PM   #218
Ajdly00
would either of you be able to share the part number for the roof module? i've only been able to find ones with the sunroof switch.
thanks!
      06-09-2020, 02:38 PM   #219
Gabrielisimous
thanks!
You're welcome!
Gabo
      12-08-2020, 05:49 AM   #220
valex
Bulgaria
Drives: BMW F31 330 xdrive
Hello guys,
Do i need this alarm sensor to do this retrofit. Or just need the Roof Function Center, alarm siren and the cables.
Thank you in advance
