BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Problem coding esys error c157
      12-13-2014, 02:41 AM   #1
r0b3r
Drives: Bmw F20 Pack m
Hi, I'm trying to code my car with enet cable and esys + esys premium program with token generated, and gives me the following error
Used eSys (Includes E-Sys v.3.26.1 & E-Sys Launcher Premium 1.05 (w/ Builtin Token Generator) & Guides) and v.54.1_PSdZData_Lite. Used windows XP Professional.
I am not able to encode to leave the error, is there any solution?
A greeting and thanks in advance
It is a bmw 1 series f21
      12-13-2014, 04:42 AM   #2
HFW003
HFW003's Avatar
Australia
1549
Drives: MY19 LBB M2 Comp
I think you will you find you haven't pointed Esys to your token.
From memory, go to the options settings in Esys, go to the token tab and make sure the path to your token is correct.
Viola, I hope
      12-13-2014, 09:37 AM   #3
r0b3r
Hello, I have token path correctly configured on the esys. a greeting.
      12-13-2014, 06:46 PM   #4
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
It is a 1 series f21
You need to open E-Sys now using the Desktop Icon for E-Sys Launcher, not the Icon for E-Sys directly.
      12-13-2014, 10:44 PM   #5
r0b3r
Hello, if I double clicked the icon esys launcher, not the esys never opens, and even reinstalled case and not finish ever opened the esys launcher.
      12-13-2014, 10:49 PM   #6
shawnsheridan
Well, you cannot launch E-Sys directly, as the E-Sys Launcher program manages E-Sys use of the .EST Token, so without it, E-Sys has no working Token solution. Contact TokenMaster for support with his E-Sys Launcher program:
http://www.bimmerfest.com/forums/pri...newpm&u=350398
      12-14-2014, 06:35 PM   #7
r0b3r
Solved , install other version.
Thanks
      12-14-2014, 06:51 PM   #8
shawnsheridan
Thanks
      01-08-2019, 02:40 PM   #9
dario_st
Drives: BMW 318d
Hi my friend , I have same issue pls how you fix this ?
Thank you!
      05-18-2019, 01:22 PM   #10
analizer
analizer's Avatar
Greece
Drives: BMW F30 318d 150HP 2016
Hi Same issue here.
Please help if you have a stable version.
Thanks
