BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Potentially got Easy seat entry coded in F36
European Auto Source (EAS)
      09-09-2015, 09:44 AM   #23
RSnic
RSnic's Avatar
Drives: 2014 328i
Originally Posted by squidlyboy View Post
I haven't tried any other values, as the 4cm is fine for me, but from that other thread:
So maybe try bumping up the value of EAH_VERFAHRWEG_SLV_PHYS to a larger value. I'm currently at 0x28 (4cm). Maybe you can make it go back to the default value 0x3c (6cm). Too much, though, and the feature will disable (if you encroach within the off-limits area). Let us all know if that works.
I would like the seat to move more forward when I start the engine, but haven't been able to figure that out. I tried setting the memory seat position thinking it works by going back to M#1 position when the engine starts, but it doesn't appear to.
SquidlyBoy,
Finally got around to make an adjustment. Wanted to get seat back so that the outside lumbar support is behind the door post, but not too far that it either inactivates thie REALLY GREAT feature or I can't reach clutch to start car (since I'm only 5' 11").
I ended up changing EAH__VERFAHRWEG_SLV_PHY to 00,37 which is 55mm -- works great for me
Al
2014 328i |Premium| Technology| HK Stereo| Manual|
Mods: Rear spoiler| DRL, Amber turn signals & Back-up LEDs| Rear & Side cameras| Front & Rear PDCs|
BMW CCA
      11-04-2015, 06:30 AM   #24
sunqichang
Drives: f30 328im
Hey guys, this works on my 2015 328im, if I want to move back 8cm, what value should I use?
      11-04-2015, 10:01 AM   #25
tboooe
tboooe's Avatar
826
Drives: F36 428i GC, E36 M3 - gone :(
New Behavior:
Turn off the engine and open the door: Seat automatically slides back a few inches, allowing easy exit
Turn on engine : Seat automatically slides forward a few inches, getting your seat into driver's position
I am little confused by these comments. They seem contradictory. Do the seats move forward when you enter the car and turn on the engine?
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      11-04-2015, 10:10 AM   #26
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
i think you missed one word ... it moves forward, but not as far forward as i would like it, so i have to manually adjust the seat a little bit more to get it to where i want it.
      11-04-2015, 10:13 AM   #27
tboooe
tboooe's Avatar
826
LOL!! Sorry man. So the seats dont move all the way forward to the memory position?? So you have the manually hold the seat memory button to get the seats to move back to the driving position?
My build thread
      11-04-2015, 10:18 AM   #28
squidlyboy
squidlyboy's Avatar
it doesn't appear to move all the way to the memory position that I set it to, but maybe that's just my perception. but to me, its just a small nit pick thing given this super cool feature that was unlocked!
One of my top 5 fave/coolest "hidden" coding features IMO...
      11-04-2015, 11:03 AM   #29
tboooe
tboooe's Avatar
826
Got it...anyone else notice that the seats dont move all the back to the memory position?
My build thread
      11-04-2015, 12:57 PM   #30
TMD29
Don't care
TMD29's Avatar
Drives: 17 SO M3 ZCP
On my 435 it seems to be going back to the memory position that I had programmed when I shut the door.
      11-04-2015, 02:02 PM   #31
tboooe
tboooe's Avatar
826
Thank you. I have an F36 so hopefully this will work for me too.
      11-29-2015, 08:39 AM   #32
G4BR13L
G4BR13L's Avatar
Belgium
422
Drives: BMW M4
Was someone able to make it also work for the passenger seat? I guess that this needs to be done in SM2(e6) module but there is no option to change the EINAUSSTIEGSHILFE to MODUS_FA_SLV
And I think that the FA stands for Fahrer (driver) and there should be an BF for Beifahrer (co-driver).
      11-29-2015, 08:58 AM   #33
G4BR13L
G4BR13L's Avatar
Belgium
422
Drives: BMW M4
To answer my own question I set EINAUSSTIEGSHILFE in the SM2 (6e) module to werte=03 and now the passenger seat also returns to the last position.
      11-29-2015, 10:33 AM   #34
tboooe
tboooe's Avatar
826
That's great! Can you please post the exact code you changed?
My build thread
      11-29-2015, 10:38 AM   #35
G4BR13L
G4BR13L's Avatar
Belgium
422
Drives: BMW M4
This is how I coded it, both my wife and I are 5"7 so you have to change the values what works best for your height.
In the SM2 (6d) module:
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV
3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64
3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00
In the SM2 (6e) module:
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = UKNOWN, WERTE=03
AK41595.00
      12-16-2015, 03:19 PM   #36
BooGooBird
BooGooBird
BooGooBird's Avatar
Drives: 2012 BMW F30 335i
can anyone confirm if this works on 2012 F30s as well?
      01-28-2016, 07:40 PM   #37
hsk1610
Drives: 2013 328i xDrive
I have a May build of 2013 and could not get it to work. Plus the CAFD files are missing on mine such as 2 SM2 (6d and 6e)- mine only had 1 SM.
      01-28-2016, 07:46 PM   #38
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
So you set your seat memory to #1 and then you set a parameter of how far back you'd like it to go, when you turn off the car it moves back and stays back till you turn it back on so its easy to get in and out? Is this the jist of it?
Edit: My 1,000th post
      02-04-2016, 09:18 AM   #39
RSnic
RSnic's Avatar
Drives: 2014 328i
Kromix,
That's about right; take a look at my post above (#23) for an idea of how far back
Hope that helps!
Al
BMW CCA
      02-20-2016, 03:15 PM   #40
Beowulf65
Beowulf65's Avatar
118
Drives: 2016 435i xDrive Gran Coupé
I had a quirk with the memory seat settings not restoring properly once the car was started. My wife shut off the engine and got out of the car with the settings for her profile and the seat moved back for egress, but she did not lock the car. I got in with my fob and when I started the car, the seat returned to her memory settings. So, it seems that the car must be locked with the active fob and then unlocked with the other fob for the respective profile seat memory to activate.
      02-20-2016, 11:33 PM   #41
Jason954x
Jason954x's Avatar
90
Drives: 435i xDrive
When engine turns off and door is opened my seat goes all the way back to the end of the rail since I don't use the back seats, and when door is closed the seat goes to M1/2 (depends on profile setting). from there I can clutch and start engine.
      05-01-2016, 08:05 PM   #42
bucawke
Drives: 2015 BMW x5
Just tried to code this on my 01/13 production date 328i and no luck since the files are missing as hsk1610 stated. :c
      05-16-2017, 05:25 PM   #43
AW F30
AW F30's Avatar
Drives: F30 340i
Thought I would bump this post just because of how awesome this feature is. Thanks squidlyboy
I can confirm that this does in fact work in my 2016 340i and exactly how you would expect it to! Seat goes back when engine is turned off and door is opened and seat goes back to memory when the ignition is turned on or when the engine is started!
This is awesome!
      07-16-2017, 02:46 PM   #44
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i
2018 GMC Acadia  [0.00]
2014 BMW 428i  [5.00]
Fellas... I just can't get this to work all the way.
If I get out of the car, push the "back" button on the top of the seat to move it back, it then moves forward to the correct position when I get back in the car and shut the door.
But I can't for the life of me get it to move the seat back automatically when I shut off the car.
I've coded it as such:
3012 -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28
3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C
I'm only 5'10" so these entries should suffice, yes?
I've browsed so many of these threads here and on other sites for hours to no avail.
Does anyone else have any ideas?
___________________
2014 F32 428i 8AT M-Sport
