BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Using Insta instead Esys for coding
      05-18-2019, 09:07 AM   #1
doctor80
Drives: F30, 328 Xdrive
Hi guys.
I don't really trust the bimmercode app and the Esys doesn't seem to work reliably either.
I'm wondering if its possible to code VO and FDL through ISTA?
What is the reason no one is using it and there are no tutorials?
Is this not available option? I tohught that ISTA is also used for programming, that should also include coding.
Please explain me.
Because from what I see, it's either Esys or Bimmercode for coding?
Car in question: F30, 328i, 2016
      05-18-2019, 11:40 AM   #2
atzebmw
Drives: BMW 335XD F30 LCI
Because it's not possible with ISTA..
ISTA is for reading the error memory or you can flash ecus, but you can't code with it.
chr4.50
      05-19-2019, 07:36 PM   #3
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M3 / AH3
Hi guys.
Please explain me.
Hi guys.
Please explain me.
Esys works reliably.
Only time it doesn't is operator error
Stable: F80 / AH3
Past: F80 ZCP / F22 M235i / E89 35is
      05-19-2019, 09:05 PM   #4
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
This begs the question what does BMW code with? I know dealers don't, but the factory must.
      05-20-2019, 02:02 AM   #5
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
51
Drives: BMW 320d
Dealer/factory uses ISTA.
ISTA programs/codes to factory settings for that particular car.
For example: if you have choosen Speedlimit info in option list, ISTA programs the default settings for Speedlimit info to work properly set in every ECU that is necessary.
But factory/dealer does not use ESYS to program startstop default off.
Hence itís not even possible in ISTA to program that.
